[Case Gallery] Homemade Transparent Case with water cooling
Discussion in 'Case Mod Gallery' started by rakesh_sharma23, Jun 16, 2008.
  1. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Specs:
    AMD Athlon X2 4000+
    ASUS M2N-E
    2-GB DDR2 667
    160-250-400 GB Sata HDD
    MSI ATI R3450 256MB DDR2 Graphice
    Creative 7.1 Audigy Value
  2. Castiel
    Castiel
    May 5, 2008
    3,319 (1.17/day)
    310
    7/10
  3. johnnyfiive
    johnnyfiive
    Apr 17, 2008
    3,892 (1.36/day)
    876
    Tucson, AZ
    Hrmm.. nice handy work. Is the water kit custom made as well?
  4. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    Yes Water cooling kit is also custom made, Cpu block from Mb-chipset heatsink + acrylic sheets, pump from old printer head motor (HP-640 inkjet)and Radioter from old machinary with some type of oil cooling from local scrap yard.
    Thanks for your reply
  5. echo75 New Member
    Apr 11, 2008
    456 (0.16/day)
    46
    Denmark
    I voted 7/10 because:
    amazing ingenuity!!
  6. pentastar111
    Aug 18, 2006
    993 (0.29/day)
    31
    Los Angeles...U.S.A
    I voted 8/10 because:
    Gave you an 8 for having a set of brass ones...Home made H20? You are braver than me. Nice job
  7. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    Thanks Mr. Pentastar111 and Mr. Echo75
  8. btarunr
    31,302 (10.28/day)
    15,514
    Which coolant are you using? It looks somewhat opaque. Is that an automotive coolant?
  9. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    Yes it is automotive coolant, but concentrated to 50/50 ratio with distilled water.
    Since automotive coolant are good in heatexchange but when concentrated in 50/50 ratio it is best for Water cooling Kits for Pc.
    Thanks
  10. btarunr
    31,302 (10.28/day)
    15,514
    It sure is, just watch out for its corrosive effect on the tubing.
  11. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    My aluiminium heatsink is having "Silver Flash" coating on it. Radiator is full copper. I am using high temp and pressure handing tubes.
    Accouding to Galvanic table and all galvanic corrosion calculations between coolent composition and two metals( aluminium & Copper) results in a lifetime period of more then 70 years.
    long time..................So no worry of galvanic corrosion
  12. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    Here are new updated pic of my rig. With new full copper homemade cpu water block and motherboard water block. with some cable management of fan cable . And side panal fan and power connector brackets.
    hope you like it.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  13. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    Thanks
  14. btarunr
    31,302 (10.28/day)
    15,514
    Wow, that CPU block looks great, have you tweaked the machine yet, what are the temperatures?
  15. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    Thaks Mr. Btarunr
    Here is twesked pic.
    AMD x2 4000+ run at 2.1GHz but i am running it at about 2.9 Ghz and at full load for about a hour you get just 41 c temp.
    [​IMG]
  16. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    DIY Sub-woofer
    Hello to every one.
    I am back with some more mod thing.
    Currently i modded my Sound blaster Audigy Value 7.1. Installed new Op-amps Burr-Brown OPA277 and Capicitor mod.
    It improved sound quality a lot...But now i think i Should have new SUBWOOFER..
    So here i am with my own Power Sub-woofer.
    DIM:-
    14inc X 14inc X 18inc Sealded Encloser made from 1/2 inc thick MFD board.
    12inc - 4ohms - 800Watts Sub- drive
    home-made 450watts amp.
    Have a look
    SUB
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Its very enjoying Playing CRYSIS with this subwoofer.
  17. PP Mguire
    PP Mguire
    Aug 15, 2008
    5,443 (1.99/day)
    831
    Watauga, Texas
    Freakin wow. Thats awesome. 9/10
  18. CyberDruid
    CyberDruid New Member
    Sep 23, 2007
    2,888 (0.94/day)
    1,100
    On top of a mountain
    Loving it.
  19. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    Thanks Mr. PP Mguire and mr. Cyberdruid
  20. computertechy
    computertechy
    Apr 3, 2006
    830 (0.23/day)
    177
    UK, Brighton
    DAMN! you have some skills mate!
    brilliant work!
  21. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    Thanks Computertechy
  22. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    HELLO EVERYONE
    NEw system Update:-
    Samsung 22" LCD
    [​IMG]
    [​IMG]
    Hope you all like it....It's great to watch HD Movies on it...Super...
  23. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    Made a small pump for my Gpu Water block(under progress).
    hava a look on motor , pump unit , armature and small pump running..
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    DIY Reservoir
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    DIY Reservoir Update ... New High Pressure Pump tested ok
    [​IMG]
    [​IMG]
    [​IMG]
  24. rakesh_sharma23
    rakesh_sharma23
    Jun 16, 2008
    49 (0.02/day)
    65
    Jodhpur, India
    At last yesterday I had some free time to clean my PC and water cooling Setup. Here are few pics for the process.
    De-assembling the dusty case.
    [​IMG]
    Components:
    [​IMG]
    Removing the water cooling setup:
    [​IMG]
    [​IMG]
    Dusty radiator. Many members of different forums were asking me about this radiator..Now everyone can see the manufacturer’s logo still alive and speaking loud about the quality of the product.
    [​IMG]
    Re-assembling you can see all the cable management in action with three SATA power connectors in line. No cable mess.
    [​IMG]
    All fans cleaned and radiator washed.
    [​IMG]
    [​IMG]
    [​IMG]
    Radiator and HDD’s in place.
    [​IMG]
    Connecting New pipes and optical drives.
    [​IMG]
    All assembled. The best cable management possible for me…
    [​IMG]
    Night mode.
    [​IMG]
    Hope you like it… If you have any suggestion regarding making this case neater or better say cool, then you are most welcome..
    Thanking
    Rakesh Sharma
  25. pantherx12
    pantherx12 New Member
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Very nicely done.
    You know I'm pretty certain some members would probably buy custom made water cooling parts from you, those who don't have access/can't afford brand parts.
    Perhaps something to think about : ]
