hot cpu temps,need help choosing cooler
Discussion in 'Overclocking & Cooling' started by snuif09, Jun 7, 2008.
  1. snuif09
    snuif09 New Member
    Nov 29, 2007
    964 (0.41/day)
    66
    hoorn, Netherlands
    My x2 +5200 gets 51c idle and when im gaming like 65c im using amd's stock cooler.
    The point is that when it gets an high temp my pc shuts off first i tought it was my vid card but if im running cod2 at 640x480 its still shutting off so i think its the cpu.
    I was thinking of buying this cooler http://www.azerty.nl/8-81-4585/freezer-64-pro.html
    i can spent about 30 euro so are there any other recomendations?
  2. dark2099
    dark2099
    Feb 20, 2008
    4,377 (1.94/day)
    755
    where everyone wants to be
    That should be fine for what you are doing, will even give a little head room for overclocking, but that is probably the best replacement for stock at the price.
  3. dadi_oh
    dadi_oh New Member
    Jul 18, 2007
    809 (0.33/day)
    77
    Almonte, Canada
    The Freezer 64 Pro is probably one of the best performance per $$$ heatsinks out there. I lapped the base on mine and added an extra 92mm fan on the back (push pull) and was getting very impressive numbers. It was performing better than heatsinks that cost 2 to 3 times as much.
  4. panchoman
    panchoman Sold my stars!
    Jul 16, 2007
    9,595 (3.88/day)
    1,200
    i would get a xigmatek rifle 120mm cooler and a nice s flex or thunderblade fan.. should cost you less then 30 euros
  5. ShadowFold
    ShadowFold New Member
    Dec 23, 2007
    16,919 (7.31/day)
    1,644
    Omaha, NE
  6. dark2099
    dark2099
    Feb 20, 2008
    4,377 (1.94/day)
    755
    He is in the Netherlands, so newegg doesn't help.
  7. ShadowFold
    Dec 23, 2007
    16,919 (7.31/day)
    1,644
    Omaha, NE
    I know but im still suggesting stuff..
  8. [I.R.A]_FBi
    [I.R.A]_FBi New Member
    May 19, 2007
    7,664 (3.03/day)
    540
    c:\programs\kitteh.exe
    xigmatek 128
  9. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.53/day)
    1,748
    Nevada
    The freezer is a very good choice. BUT, the stock cooler should be doing a better job. You can buy the best cooler there is and if the airflow is bad in your case its not gonna help much.
    I would improve the airflow in your case first before getting a different cooler.
    Is the fan on your stock cooler spinning good?
    Are the fins of your heatsink full (I mean REALLY full) of dust?
    Does the comp run cooler with the case side panel on or off?
    Does your case have intake/exhaust fans?
    Can you post a pict of the side view of ur comp?
    snuif09 says thanks.
  10. snuif09
    snuif09 New Member
    Nov 29, 2007
    964 (0.41/day)
    66
    hoorn, Netherlands
    xigmatek isnt an option here cause there no where to find in holland.
    @mkmods:i will make a picture but i dont think airflow is really a problem but who knows.
  11. echo75 New Member
    Apr 11, 2008
    456 (0.21/day)
    46
    Denmark
    Order it from neighboring Germany or Austria, its all EU so u wont pay extra tax.
    Infact , xigmatek has an official office in germany, contact them by email.
Share This Page
