How I can flashing my graphic card ( increase Temperature fan speed )
Discussion in 'AMD / ATI' started by Mohammed, Jan 24, 2012.
  1. Mohammed
    Jan 11, 2012
    308 (0.25/day)
    21
    Hi every one
    I have NEW HD 4670 512GB GDDR3
    the problem is that Temperature fan speed works less than 20%
    [​IMG]
    Or may not work
    I am always depending on MSI Afterburner program to make that fan work at 50%
    I ask the seller about this problem, but he tell me to flashing my card :wtf:
    So please any help. :respect:
  2. erocker
    Jul 19, 2006
    40,478 (12.51/day)
    15,173
    Flashing won't do anything. You can set a custom fan profile in Afterburner. If the fan sometimes doesn't work, it is defective and should be returned to who you bought it from.
    Mohammed and trickson say thanks.
  3. Mohammed
    Jan 11, 2012
    308 (0.25/day)
    21
    Thanks bro
    Yes it's work when i switch on it manual only by MSI Afterburner .
    But I can't depending on MSI Afterburner.
    I see many people said " Flashing Card" is useful to built your own card
    such as " Overclock, increase Temperature fan speed ....etc"
    So, Is that possible?
  4. m1dg3t
    m1dg3t
    May 22, 2010
    2,254 (1.23/day)
    518
    Canada
    Maybe you can edit the BIOS with some type of program like RBE, if it's still around? As mentioned i can create a fan profile (using CCC) on my 5870 to have the fan automatically ramp up when temp's increase but i made thing's easy for myself and replaced the stock cooler. Now i don't have to mess with fan profiles or the sound of a hairdryer in my case :)
    Mohammed says thanks.
  5. Mohammed
    Jan 11, 2012
    308 (0.25/day)
    21
    Yes bro i have that program
    but I don't know how to use it
    RBE v128
  6. erocker
    Jul 19, 2006
    40,478 (12.51/day)
    15,173
    m1dg3t and Mohammed say thanks.
  7. Mohammed
    Jan 11, 2012
    308 (0.25/day)
    21
    Thanks brothers
    The problem solved by ATI RBE program & ATI Win flash program
    1- Run ATI RBE program
    2- load BIOS
    3- Go to Fan Sittings
    4- put the value . For example as me I do this : T min (c) = 10 Duty Cycle min (%) = 40
    5- Save BIOS
    6-After that I use "ATI Win flash" to do flashing
    After this it came a message tell you that you need to restore PC
    then *** success ***
    Thanks erocker That link was very useful.
    Thanks m1dg3t you are right the problem solved by ATI RBE program.
    m1dg3t says thanks.
  8. m1dg3t
    m1dg3t
    May 22, 2010
    2,254 (1.23/day)
    518
    Canada
    Glad you got it sorted! Thanks erocker for the link :toast:
Share This Page
