How is my cable management?
Discussion in 'General Hardware' started by itsakjt, Jan 7, 2013.
  1. 3870x2
    3870x2
    Feb 26, 2008
    4,876 (1.68/day)
    690
    Joplin, Mo
    After they sit for a while, the cables tend to get lazy and drop into places they shouldn't be in:laugh:
  2. drdeathx
    drdeathx
    May 14, 2009
    2,132 (0.87/day)
    479
    Chicago burbs
    It is a base rig, who would waste their time sleeving it? :slap:
  3. animal007uk
    Feb 19, 2009
    1,425 (0.56/day)
    406
    Warwick, Warwickshire, England
    People who get bored or want something else to, Dosen't matter how old or new the pc is does it.
  4. drdeathx
    drdeathx
    May 14, 2009
    2,132 (0.87/day)
    479
    Chicago burbs
    If you think this guy is gonna sleeve his cables your on crack. Just sayin....
  5. drdeathx
    drdeathx
    May 14, 2009
    2,132 (0.87/day)
    479
    Chicago burbs
    If you think this guy is gonna sleeve his cables your on crack. To even mention it makes me think you guys are on crack..... :twitch::twitch::twitch:
  6. animal007uk
    Feb 19, 2009
    1,425 (0.56/day)
    406
    Maybe we don't all think like you, Just because you would not sleave it dosen't mean someone else wont.
    Infact it would be a good place to start if we have never done it before and i would rather try on a basic case than say my NZXT case.
    I also do not take crack or any other shit like that
    itsakjt says thanks.
  7. drdeathx
    drdeathx
    May 14, 2009
    2,132 (0.87/day)
    479
    Chicago burbs
    All this guy did was ask how his cable management was and a debate about sleeving comes up... Gott love this club.....:slap:
  8. brandonwh64
    brandonwh64 Addicted to Bacon and StarCrunches!!!
    Sep 6, 2009
    19,226 (8.19/day)
    6,677
    Chatsworth, GA
    I think it looks very good for a prebuilt case.
    Crunching for Team TPU
  9. animal007uk
    Feb 19, 2009
    1,425 (0.56/day)
    406
    Yeah and someone else suggest something to try and to make things look nicer, I do not see what is wrong with that.
  10. drdeathx
    drdeathx
    May 14, 2009
    2,132 (0.87/day)
    479
    Chicago burbs
    It is a pre built system........ LOL :laugh:
  11. EiSFX
    Jul 10, 2008
    570 (0.21/day)
    124
    Alberta, Canada
    Pre Built or not you can still make it look nice and tidy compaird to what you usaully get from the rats nest of cables in pre built systems.
    To OP your cables look good and out of the way of any possable airflow which is the main reason to do cable managament after that is looks
  12. itsakjt
    itsakjt
    Oct 9, 2010
    1,199 (0.61/day)
    403
    Kolkata, India
    The system is prebuilt and the builder is none other than me. So I am the commandeer of all the operations. :p
    animal007uk says thanks.
  13. karolpl2004
    karolpl2004
    Dec 2, 2005
    673 (0.18/day)
    13
    Chicago
    cant wait for those wireless power supplies haha
    10 Year Member at TPU
  14. Jetster
    Jetster
    Jan 17, 2010
    7,335 (3.31/day)
    3,757
    Oregon
    Think outside the box. Or under the motherboard. cut some holes. sleeve the rest. Yes I said sleeve. Its good practice and heat shrink tubing is cheap and may he wants to waste some time on this project. At least he has the balls to ask
  15. random
    random
    Oct 19, 2008
    3,044 (1.14/day)
    686
    cable tie the bottom half of the motherboard too! When you clean up the cables down there you'll have so much more room for activities lol, but seriously it'll make it look alot tidier.
  16. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.52/day)
    640
    Wangas, New Zealand
    Case modding to make cable management.
    Painting the inside of the case black, cutting some holes, go to the hardware store and get some rubber to slot against the new holes you cut with a dremel.
  17. Frag Maniac
    Frag Maniac
    Nov 9, 2010
    3,868 (2.02/day)
    1,091
    I don't advocate drdeathx's attitude toward low end systems, but I have to agree that sleeving that rig is not only kinda pointless, it could get someone with minimal experience into trouble.
    Proper sleeving takes a bit of know how and dexterity. I've seen countless posts even from people fairly experienced at building systems whom try sleeving for the first time, then end up asking how to get certain cables they've not been able to put back together properly.
  18. itsakjt
    itsakjt
    Oct 9, 2010
    1,199 (0.61/day)
    403
    Kolkata, India
    No I can sleeve. I just need the kits. You know what? I made the connections of the front panel audio myself-Completely with wires, soldered the sockets to the PCB and the wires too, got a jack from an old chassis of a friend and then put the wires properly with the designated contacts. It was not there when we bought the chassis. Yeah I failed the HD audio but I managed to do AC97. For HD audio, I needed a circuit diagram but did not find any on the web.
  19. n3rdf1ght3r
    n3rdf1ght3r
    Feb 17, 2012
    380 (0.26/day)
    293
    The city with the former druggie Mayor
    The cable management looks fine. I'm going to assume there it no side panel window and considering the components currently in the computer, no ones going to open it up to see how pretty it looks. So right now cable management would really be to improve the airflow inside your case by reducing the amount of clutter to allow air to flow to you components better. I feel like i'm a bit late to this conversation :p
    EDIT: You should get a front intake fan, like what Mindweaver said.
  20. Xenturion
    Jul 24, 2012
    131 (0.10/day)
    59
    Realistically, modding the case or purchasing a modern case would really be necessary if you want to improve it further. There's options from Zalman, Antec, BitFenix, and others, all that would allow enthusiast levels of cable management for under $50. A bottom mounted power supply (with room behind the motherboard tray) and storage drive bays in a different orientation would go a long way. The 4 or 8-pin CPU connector is the only real issue that can arise doing cable management in a bottom-mounted PSU case. Sometimes, the connector isn't long enough to reach from the PSU at the bottom, all the way up the back of the motherboard tray, and then over the top to the front of the motherboard. Looking at your pictures, it would seem it'd be long enough.
  21. ZDarryl
    ZDarryl New Member
    Jan 9, 2013
    1 (0.00/day)
    1
    Castle Rock, CO
    Looks fine, could be better, but with what you have to work with, it is decent.
