How much power does your PC use?
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
A simple collection from people with wall meters, so we can collect data on how much power our PC's actually use and compete for power efficient systems (because i think i'll win ;) )
These stats should be for tower alone, not monitor, speakers etc.
simply run Wprimes 1024M test (run as admin!) and 3dmark11's "performance" test while watching your power meter, and report the results. divide your 3dmark score by the maximum wattage you saw for your power efficiency score. (for reference i'm getting the higest wattage numbers in 3dmarks test 1 in my systems, so i'm focusing on the highest number i get there)
User | PSU | CPU + GPU | Desktop Idle| Wprime 1024 Watts | 3dmark11 wattage + score | 3dmark points per watt | Comment
Mussels | Corsair HX1000 (86-91% efficiency) | i5 2400 @ 3.7GHz + 7970 | 89w | 134w | P9193 301W | 30.54 | Im the bestest
Mussels | Corsair TX750 | 1090t @ 3.6GHz + 5870 | 133w | 246w | P4471 308W | 14.51 | i'm the worstest :(
Mussels | Coolermaster 550W (~65% efficiency, terribad) | Athlon II x2 3.1 @ x4 3.1 + 6470 2GB | 92w | 182w | P1324 167W | 7.92 | i'm disappointing
Mussels | Corsair HX1000 | i5 2400 @ 3.85GHz + 7970 | 84w idle | 139w | P.... W.... | points per watt | new mobo is good :D
Mussels | Corsair TX750 | i3 2130 @ 3.4GHz 1.025v + 4890 1GB | 119w idle | 134w | DX10 card, furmark 720p test 239W - 1423 points | 5.95 *furmark* points per watt | 4890... so.... HUNGRY
Mussels | Corsair TX750 | i3 2130 @ 3.4GHz 1.05v + 1GB Geforce 550 Ti OC | 71w idle | 134w | P2766 184W | 15.03 points per watt | so quiet :D (218W furmark load, 1632 furmark points, 7.48 FPW)
Rampage | Corsair HX750 | i7 3770k @ 4.2GHz + 7970 X-Fire | 64w | 144w | P16835 590W | 28.56 points per watt | daily settings
FordGT90Concept | Enermax Revolution 85+ 850w | 2 x Xeon E5310 @ 1.6 GHz + 5570 | | | | | ~350 watts running BOINC
HammerON | Corsair AX1200 | i7 4770K @ 4.4GHz + GTX 780 (SLI) | 141w | 205w | P19,308 610W | 31.65 | stock GPU's
HammerON | Corsair AX1200 | i7 4770K @ 4.4GHz + GTX 780 (SLI) | 143w | 191w | P21,058 703W | 29.95 | A little more GPU OC
AsRocks | PC Power & Cooling Silencer 750 Quad (80+ Certified (83% 6 years ago haha ) | i7 3770 @ 4.0GHz + 6970 (940\1,440) | 80w |180w | P6255 306W | 20.44 |
Outback Bronze | Cooler Master 800W Silent Pro Gold | i7 990x @ 3.46ghz no HT + 7950 (Xfire) | 145w | 185w | P12443 369W | 33.72 | Everyday Settings.
Finners | Coolermaster silent pro gold 800w | i7 2600k @ 4.4GHz + GTX 680 SLI | 121w | 228w | P15942 526W | 30.31 points per watt
James888 | XFX pro 850w | I7-4770k@ 4.375ghz +7970@ 1050/1850 | 95w idle | 210w wprime | P10923+ 360w | 30.34 PPW | Daily gamer, 213w boinc
James888 | Cougar SX 750w | Celeron G1620 @ 2.80GHz +7870 Tahiti @ 975/1500| 58w idle | 65w wprime | P5649 + 260 | 22.59 PPW | Cruncher/Miner, 65w boinc
Aquinus | Seasonic X1000 Platinum | i7 3820 @ 4.5Ghz + 2x 6870 (Crossfire) | 217w | 340w | P8224 (400w avg/ 445w peek) | 18.4 points per watt @ peek | Stock GPU volts + freq.
Jetster | Corsair RM650 | i7 3770K @ 4.2GHz + 7950 X 2 | 65w idle | 266w | P13505 415W | 32.54 points per watt |
Mathragh| Corsair AX860i | FX-8120 @ 4603 7950 stock | 151w idle | 345w | P7314 413W | 17.71 points per watt | Stock GPU
Mathragh | Corsair AX860i | FX-8120 @ 4603 7950 @1150/6300 1,26v | 124w idle 1 monitor | 484w prime95 | P9259 468W | 19.78 points per watt | prime95 instead of wprime, GPU OC, Idle Single monitor
Nokiron | Corsair AX1200i | i7 3970X GTX 780 1202/7208 | 114W idle | 224W | P13201 398W | 33.16 points per watt
Nokiron | Corsair AX1200i | i7 3970X@4.1Ghz 1.175V - Asus GTX 780 1202/7208 | 121W idle | 226W | P13597 398W | 34.16 points per watt
Nokiron | Corsair AX1200i | i7 4960X@4.5Ghz 1.285V - Inno3D GTX 980 | 135W idle | 241W | P16727 350W | 47.79 points per watt
Jetster | Seasonic G Series 550 Gold | AMD A8-5600K @ 4.0Ghz | 36w idle | 101w | P1385 110W | 12.59 points per watt | lowest @ Idle
manofthem | Corsair HX1000 | i7 4770k @ 4.4Ghz + R9 290 1050/1350 | 89w | 200w | P13833 371w | 37.29 points per watt | BOINC 208w / 3DMark13 412w
manofthem | Corsair AX1200 | i7 4770k @ 4.4Ghz + R9 290 1050/1350 | 73w | 185w | p13737 353w | 38.92 points per watt | BOINC 192w / 3DMark13 382w
ChristTheGreat | OCZ Z-850 | i7 2700k @ 4.5GHz + 7950 1150/1350 | 95.5w idle | 214w | P10427 373w | 27.95 points per watt | Games/BOINC RIG
TRWOV | Seasonic S12D 80+ Silver | i7 3770K @ 3.9GHz + 7970 OC Boost bios #1 | 105w | 169w | P9423 306W | 30.79 | www.3dmark.com/3dm11/7853488
Arctucas | Corsair AX1200 | i7 950 @ 4273MHz + SLi 560Ti @ 875/2050 | 268W idle | 365W | P9015 615W | 14.66 points per watt | Meh...
FX-GMC | Seasonic G-650 | FX-8320 @ 4.6GHz + GTX760 | 97w idle | 249w | P8757 405W | 21.62 points per watt |
jAh76 | Seasonic 300W | i5-2500K @ 4000 MHz GTX 670 @ 1267/1802 MHz | 55W | 115W | P9241 295W | 31.32 ppw | by EnergyCheck3000 230V
FreedomEclipse | Corsair AX860 80Plus Platinum (94% Efficiency@50%) | i7-3930k @4600MHz + Nvidia GTX 680 SLI | 130W | 338W | P17864 566W | 31.56 ppw | Stock GPU + Belkin Conserve Insight power meter
neatfeatguy | CoolerMaster Silent Pro 1000W (85% efficiency) | i5 4670K @ 3.6GHz + GTX 570 SLI | 115W | 158W |P9612 520W | 18.48 | 3 monitors setup, 5040x1050
manofthem | XFX Core 550Pro | i3 2100 @ 3.1GHz + R9 290 1050/1350 | 60w idle | 94w | P8988 360W | 24.97points per watt | BOINC 92W / 3DMark13 341W / F@H 267W
manofthem | XFX Core 550Pro | i3 2100 @ 3.1GHz +7770 | 60w idle | 94w | P3997 140W | 28.55points per watt | BOINC 92W / 3DMark13 142W / F@H 100W
NateDawg | SeaSonic SSP-450RT | i5 3350p @ 3.3GHz + 660 OEM | 48w idle | 74.4w | P6097 141W | 43.24 points per watt | Daily use
FreedomEclipse | Corsair AX850 80Plus Platinum (94% Efficiency@50%) | i7-3930k @ 4.6GHz + GTX 790 SLi | 120w idle | 381w | P22882 627W | 36.39 points per watt | Stock GPU + Belkin Conserve Insight power meter
ChristTheGreat | OCZ Z-850W Gold | i7 4770k 4.3ghz + R9 290 1100/1400 | 95w idle | 205w | P14343 386W | 37.15 points per watt | 7 fan + pump, using dual-screen
Outback Bronze | Corsair AX1200 | i7 5960x @ 3.3Ghz + GTX 980 | 114w | 153w | P18092 336w | 53.845 | Stock Settings.
agent00skid | Laptop brick | Phenom II N830 + Mobility HD 5650 | 21w | 55w | P1014 59W | 17.19 |
Frick | Cooler Master G550M | Pentium G3220 + ASUS GTX 760 OC model | 56W idle | 77W | P5876 238W | 24.7 points per watt | n/a
Nokiron | Chieftec SFX-500GD-C | i7 6700K + R9 Nano | 46w idle | 90w | P15698 240W | 65.40 points per watt | GPU+CPU undervolted.
Nokiron | AX1200i | i7 4960X @ 4.5Ghz 1.25V + EVGA 980 Ti Classified | 181w idle | 265w | P21386 483W | 44.27 points per watt | Including full loop, 14-fans, 8 SSDs etc
format your results in the following so i can find and add them easier
Add my result
Mussels | Corsair HX1000 | i5 2400 @ 3.7GHz + 7970 | 89w idle | 134w | P9193 301W | 30.54 points per watt | i'm the bestest
Mussels
58,412 (7.78/day)
Oystralia
c'mon lads and ladies, buy a power meter and learn edumacational things!
AsRock
TPU addict
19,255 (2.95/day)
UK\USA
Cooling D15
Just downloading 3dmark now
Using 3DMark 11 Basic
Using Zalman fan controller power usage.
AsRocks | PC Power & Cooling Silencer 750 Quad (80+ Certified (83% 6 years ago haha ) | i7 3770 @ 4.0GHz + 6970 (940\1,440) | 80w +\-3w idle |w 180w | P6255 306W |
Updated
6,790 (1.34/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
Which one? To answer this question in full I would have to get my killawatt out and use it on all 4.
Mussels
58,412 (7.78/day)
Oystralia
see the chart. i'm doing it on all of mine. laptop and fiancees PC will be added after work.
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
I dont understand the WPrime part?
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
I don't know about my computer but my server draws ~300w from the UPS 24/7.
FordGT90Concept | Enermax Revolution 85+ 850w | 2 x Xeon E5310 @ 1.6 GHz + 5570 | | | | | ~300 watts running BOINC
Mussels
58,412 (7.78/day)
Oystralia
its a multi threaded CPU benchmark. for now its just 'how much power does your CPU use' as opposed to 3dmarks 'cpu and gpu' result. i'll end up adding something like watts over time (300 seconds + 200W = 60,000 joules of energy used) to determine who has the most power efficient CPU, but i'll have to double check my math on that one after work before i add it in.
6,790 (1.34/day)
Processor 7800x3d
Case ThermalTake P3
Fine I will do it. It will take a few days though.
54 (0.01/day)
System Name Gaming Rig
Processor Intel Core i7-3770k (@3.5Ghz)
Motherboard Gigabyte GA-Z77-D3H
Cooling Corsair Hydro H60 Water Cooling
Memory 16GB Corsair XMS3 (4X4)
Video Card(s) NVIDIA GTX 780 3GB
Storage Samsung 840 Pro SSD 128GB, Seagate 2TB
Display(s) 3x ASUS VS238H 23" Monitors (NVIDIA Surround)
Case Corsair 300R
Audio Device(s) 7.1 Surround Sound
Power Supply Raidmax 850W Gold
Software Windows 7 Home Premium
I have a Raidmax 850w Gold PSU and I feel like I will hardly ever use it all XD I was wondering how much power it is using so finding out would be a good idea
225 (0.05/day)
System Name "Big E"
Processor I5 2400
Motherboard Intel DQ67OW
Cooling Scythe Samurai ZZ
Memory 4 X 2 Gb Kingmax 1333
Video Card(s) MSI RX470 gaming x 4gb
Storage samsung F3 500 GB
Display(s) Acer S271HLBbid
Case "Big E"
Power Supply Gembird 450 W
Mouse Generic
Keyboard Generic
Software W10 LTSC
Benchmark Scores Nothing worthy to mention
Psu Nexus value 430
At Idle About 65 watts in gaming 265 watts
HammerON
The Watchful Moderator
8,402 (1.42/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
HammerON | Corsair AX1200 | i7 4770K @ 4.4GHz + GTX 780 (SLI) | 143w | 205w | P20,852 704W | 29.62 | OC'd GPU's
System includes two MCP655 pumps and five 120 rad fans and two 140 case fans. Rest is in the system specs...
Mussels
58,412 (7.78/day)
Oystralia
added your stock and max GPU OC, didnt think three entries for the one PC was needed.
a note to everyone else: if you dont do it in the right format with the | | | thingies, i wont add it to the OP.
Mussels
58,412 (7.78/day)
Oystralia
i also feel like saying that my meter can actually measure power factor efficiency under a setting called "PF", and it matches up with the numbers you'd expect from PSU's. i see 90+ from my corsairs, and an average of 65% from cheap shite with passive PFC (see my coolermaster PSU in the chart)
if other peoples PSU's/UPS's have a similar reading, i'll add it into the chart.
854 (0.16/day)
If I had a wall meter ide be all over this undervolting the cpu and gpu and northbridge.
Mussels
58,412 (7.78/day)
Oystralia
go buy one off ebay. my goal here truly is to make people compete for power efficient desktops, instead of this race for max MHz.
12,340 (2.21/day)
Oregon
I have an Abacus. Can it enter?
3,014 (0.50/day)
Northampton,UK
System Name Jaffakeik
Processor I9 12900K
Motherboard MSI Pro B660M-A WIFI DDR4
Cooling Arctic Liquid Freezer II High Performance CPU Water cooler- 240mm
Memory Corsair Vengeance LPX Black 32GB (2x16GB) 3600
Video Card(s) 7900XTX gigabyte OC edition
Storage WD Black SN770 1TB SSD M.2 2280 NVME x2
Display(s) TV LG C2
Case Phanteks Enthoo Pro 2 Full Tower Case Tempered
Audio Device(s) Mother board + Sennhiser HD650+ Elgato wave xlr + shure SM7B
Power Supply EVGA 1600w G+
Mouse Glorious Model 0
Keyboard Corsair RBG mini K65 + Steelseries Apex150
Benchmark Scores over 9000
My computer uses about +-100Kwh montly
Mussels
58,412 (7.78/day)
Oystralia
AsRocks | PC Power & Cooling Silencer 750 Quad (80+ Certified (83% 6 years ago haha ) | i7 3770 @ 4.0GHz + 6970 (940\1,440) | 84w idle |w crashes (unexpected error ) | P6255 306W |
EDIT:
run it as admin.
7,111 (1.00/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Mussells, thats pretty awesome power efficiency for a 7970 and a powerful cpu! Just shows modern cpu/gpu scalability. If I still had my xeon I'd probably wreck you guys, 3.5 ghz at .8v full load! Don't have a wall meter though :(
AsRock
TPU addict
19,255 (2.95/day)
UK\USA
Cooling D15
run it as admin.
Updated post. Had fans turned up which coursed a 3-4w difference haha.
By maxing the pwm fans out in bios you can set the ASRock extreme tuner fan speeds to 0 andf they will speed up if temps get higher
Mussels
58,412 (7.78/day)
Oystralia
updated. make sure you dont skip the empty fields, it can mess with the formatting if you dont leave a blank | in there (filled yours in, and did the math for your points per watt)
Mussels
58,412 (7.78/day)
Oystralia
and i must say that hammerON makes me jealous, i gotta get me a gold (or higher) rated PSU one day...
Outback Bronze
Super Moderator
2,198 (0.44/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Razer
Keyboard Corsair
Software Win 11
Outback Bronze | Cooler Master 800W Silent Pro Gold | i7 990x @ 3.46ghz no HT + 7950 (Xfire) | 145 | 185 | P12443 369W | 33.72 | Everyday Settings.
I did go close to 35 ratio in 3dmark 11 but they weren't my everyday settings.
Id love to get my idle down.
Ill have a look see what my HTPC does tomorrow with i3 2100 and 7850.
