How to hook up HDTV + AV receiver + PS3 together! Using only HDMI connections?
ktr
7,404 (1.12/day)
The reason you are not getting audio through HDMI when plugging in your PS3 to you receiver is because your receiver's HDMI is pass through, not processing.
High-value receiver with an impressive array of features and technologies to enhance the audio/video experience, including HDMI switching with 1080p video pass-through, iPod and Bluetooth audio compatibility, CINEMA DSP, Compressed Music Enhancer, and four SCENE buttons.
Amazon.com's product page says:
The RX-V363 features dual HDMI inputs and one output that can support all HD video formats, including 720p, 1080i and 1080p. This means you can connect two HDMI sources, such as a DVD player and a high-definition set-top box, and enjoy the highest possible quality with HD display (does not support audio signal).
As stated, you have to plug both HDMI and optical from your PS3 to your receiver, then configure both PS3 and receiver to handle multiple-outputs/inputs.
2,684 (0.42/day)
Republic Of Ireland
System Name The Metadis
Motherboard Asrock B650 RS Pro
Cooling MSI MAG CoreLiquid 360R V2
Memory 32GB G-Skill Trident Z5 Neo 6000mhz CL32
Video Card(s) Asus Tuf RX 7900XTX OC 24GB
Storage Crucial P5 Plus 2TB Gen4 nvme + Sabrent Rocket Pro 500GB Nvme Gen3
Display(s) LG C2 42" 4K 120hz OLED
Case NZXT H6 Flow
Audio Device(s) Hifiman Edition XS - Ifi Zen DAC V2 - 7Hz x Crinacle Salnotes Dioko 14.6m Planar Diaphragm Drive IEM
Power Supply Seasonic G12 GM - 850W 80 Plus Gold
Mouse Corsair M65 ELITE RGB Optical FPS Gaming Mouse (18000 DPI Optical Sensor)
Keyboard Redragon K648 90% Wired Aluminium Mechanical - Rock-Solid Metal Board Built-in Noise Absorbing Foams
VR HMD Meta Quest 3
Software Windows 11 64-bit
Ahright that makes sense :(
I put the optical cable back in and set it up in the audio settings.
I then went into the video settings and chaged the BD audio setting to bitstream.
Now when Irun the movie it is linear PCM 4.6mbps.
But the receiver can only handle 2.0. ah well :p
But I am happy that I can change the audio to DD5.1 640kbps.
I can't get DTS to run, I guess the movie does not have it.
Thanks for all the help lads!
I might consider a new receiver in the near future!
3,427 (0.67/day)
System Name My baby
Processor Athlon II X4 620 @ 3.5GHz, 1.45v, NB @ 2700Mhz, HT @ 2700Mhz - 24hr prime95 stable
Motherboard Asus M4A785TD-V EVO
Cooling Sonic Tower Rev 2 with 120mm Akasa attached, Akasa @ Front, Xilence Red Wing 120mm @ Rear
Memory 8 GB G.Skills 1600Mhz
Video Card(s) ATI ASUS Crossfire 5850
Storage Crucial MX100 SATA 2.5 SSD
Display(s) Lenovo ThinkVision 27" (LEN P27h-10)
Case Antec VSK 2000 Black Tower Case
Audio Device(s) Onkyo TX-SR309 Receiver, 2x Kef Cresta 1, 1x Kef Center 20c
Power Supply OCZ StealthXstream II 600w, 4x12v/18A, 80% efficiency.
Software Windows 10 Professional 64-bit
ktr,
That makes perfect sense why HDMI isnt working. But it doesnt explain why he isnt getting DD and DTS using optical.
But you don't need a new receiver for DTS or DD. HDMI was only supposed to be for the HD formats. It's a complete waste if you have no intensions of listening to DTS Masters or DD True HD.
I'm confused, so you managed to get DD 5.1 to work?
2,684 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
Yes I just got it working properly.
Well not the PCM 5.1. But at least DD and DTS are available now.
I had to change the BD audio settings in the movie settings on the XMB menu.
I dunno what I changed.. but I got it as Bitstream.. now DD and DTS are there? odd!
INSTG8R
Vanguard Beta Tester
7,966 (1.12/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
Still not sure why your using an optical at all. If you just ran the setup with the HDMI plugged into the amp as I explained earlier.
Here
The results back from the amp(as I said HDMI is "Smart" and talks to what it's plugged into)
Excuse the size I forget iPhone 4 is higher res than my old 3G
ktr
7,404 (1.12/day)
Here
http://img.techpowerup.org/110205/IMG_0281.jpg
http://img.techpowerup.org/110205/IMG_0289.jpg
His receiver does not do HDMI processing, thus no audio. That is why he has to use optical.
INSTG8R
7,966 (1.12/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
It surely does as I have the same series of amp ;)
He just needs to get the set up right.
ktr
7,404 (1.12/day)
Having the same series receiver doesn't mean the same model.
As stated in the manual (page# 14), and I quote:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor.
2,684 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
@INSTG8R: I was thinking the same man. Why use Optical when I have a HDMI cable for it!
It just does not produce any sound at all :(
As ktr proved, my amp simply does not support what I want done.
Your amp is slightly higher than mine! I probably should have gone for it instead!
If only I knew more!
Well I know the next time I go buying an AMP. I won't go cheap! :p
2,684 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
2,684 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
Bump,
Sorry for the triple post lads.
1,984 (0.35/day)
Processor Intel Core i9 9900k @ 5.1GHZ all core load (8c 16t)
Motherboard MSI MEG Z390 ACE
Cooling Corsair H100i v2 240mm
Memory 32GB Corsair 3200mhz C16 (2x16GB)
Video Card(s) Powercolor RX 6900 XT Red Devil Ultimate (XTXH) @ 2.6ghz core, 2.1ghz mem
Storage 256GB WD Black NVME drive, 4TB across various SSDs/NVMEs, 4TB HDD
Display(s) Asus 32" PG32QUX (4k 144hz mini-LED backlit IPS with freesync & gsync & 1400 nit HDR)
Case Corsair 760T
Power Supply Corsair HX850i
Mouse Logitech G502 Lightspeed on powerplay mousemat
Keyboard Logitech G910
VR HMD Wireless Vive Pro & Valve knuckles
The receiver you've linked on ebay would definately do the job of giving out HD audio (looks to be a pretty nice piece of kit). Don't forget to keep an eye out for the firmware update that enables the 3D passthrough (as the specs say it will be enabled with a firmware update).
I'm not 100% on if it would do it as 5.1 PCM but it supports dolby trueHD and DTS 96/24 formats so you won't go wanting more than that imo.
**edit**
the 3d firmware update is out but I've read it is tricky to install, you may want to check into how easy it is to update if you'd want the 3D functionality for the future.
2,684 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
Sweet!
I'm sure since it supports the HD Dolby/DTS it should support PCM 5.1 tho!!
surely!
1,984 (0.35/day)
Case Corsair 760T
Sweet!
surely!
I'd expect so but I never like confirming anything unless I see it explicitly on a review/spec sheet somewhere (especially when it comes to home AV - sometimes they stupidly miss off features to try and sell more expensive versions).
2,684 (0.42/day)
Republic Of Ireland
Case NZXT H6 Flow
VR HMD Meta Quest 3
AHh that's cheeky of them!
I have not had any luck finding any review or comments about PCM 5.1 tho.
I better just keep researching!
