I Changed my bios and now my pc will not work please help ASAP!!!
Discussion in 'General Hardware' started by simbawoomba, May 23, 2005.
  1. simbawoomba New Member
    May 23, 2005
    5 (0.00/day)
    0
    hello
    This is quite urgant, i changed some things in my bios about 10 mins ago such as some ddr setting which was on auto and the setting below was 200 i changed it to limited and 400 there were a couple of other things that i changed too.
    now my pc will not boot properly, nothing at all appears on the screen when i put it on and i dont know how to get it to work again,
    can anyone please help
    just post on this or email me at simbawoomba@hotmail.com
    thanks!!!
  2. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.74/day)
    1,383
    Reset the bios. If you can enter it load defaults. Otherwise use the jumper on your board (look it up in the manual)
  3. simbawoomba New Member
    May 23, 2005
    5 (0.00/day)
    0
    i can not enter anything, i have a map of my mother board here so i will look for the jumper thanks.
    the screen is just black and i dont think it even sends a signal to the monitor
  4. simbawoomba New Member
    May 23, 2005
    5 (0.00/day)
    0
  5. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.74/day)
    1,383
    Can't find a manual for your board atm, take off all power and remove the small round battery on your board, put it back after 1-2min, cmos should have cleared then.
  6. simbawoomba New Member
    May 23, 2005
    5 (0.00/day)
    0
    ok ill try, i do have a manual in pdf format but i dont know how i would send it to you its 6.58 MB
  7. gR3iF
    gR3iF New Member
    Mar 26, 2005
    1,807 (0.51/day)
    35
    Hamburg
    it should be the jumper over the battery and
    there should be letters like this: clear_cmos
  8. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.74/day)
    1,383
    Just take out the battery, the settings won't be remembered without a powersource.
  9. gR3iF
    gR3iF New Member
    Mar 26, 2005
    1,807 (0.51/day)
    35
    Hamburg
    on my board this takes about 5 hours to delete with battery
  10. simbawoomba New Member
    May 23, 2005
    5 (0.00/day)
    0
    yay thanks am back on now it took a while cos i had to re install some drivers and i had to find them, the batrey thing worked really fast : )
  11. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.74/day)
    1,383
    Never took me longer than a few min... Though it worked for simba, so that's good. Now don't mess up your BIOS again ;)
Share This Page
