I need help finding a driver for a wireless pci adapter
Discussion in 'General Hardware' started by ShRoOmAlIsTiC, Dec 5, 2009.
  1. ShRoOmAlIsTiC
    ShRoOmAlIsTiC
    Sep 29, 2004
    859 (0.23/day)
    164
    Palm Desert, CA
    this is the adapter I have
    http://www.airlinkplus.com/wireless/awlh3025.htm
    I cant seem to find a driver for vista 64bit anywhere. only xp and older, if someone could please help me find a driver that will work I would realy realy apreciate it.
  2. sonnytiger
    sonnytiger New Member
    Dec 30, 2009
    204 (0.11/day)
    10
    Lower Sackville, NS
    try a program called driver detective
    ... pirates
  3. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    20,429 (6.08/day)
    6,431
    It seems that AirLink never made a 64-bit driver for that card, or most of their other cards, so I would say you are screwed.
    I'd just spend the $20 on a new wireless card that you know supports Win7 and 64-bit.
    Crunching for Team TPU 50 Million points folded for TPU
  4. Depth
    Aug 7, 2009
    606 (0.30/day)
    139
    Or....
    Install a virtual machine with windows xp, install the (old) drivers there and route the connection from the host through the guest system. :toast:
  5. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    42,629 (11.31/day)
    9,882
    if you find out the specific texas instruments chip it uses, you can search for a driver that way.
    From a vague memory of researching this in the past, Ti are bad at releasing x64 drivers - you may be screwed.
  6. newtekie1
    Nov 22, 2005
    20,429 (6.08/day)
    6,431
    Virtual machines don't work that way.
  7. Depth
    Aug 7, 2009
    606 (0.30/day)
    139
    Ah. I remember something similar from a few years back.. Probably something else, dilemmas seems to come in buckets whenever I'm around those things.
Share This Page
