I need power supply upgrade opinion's
Discussion in 'System Builder's Advice' started by Achilles1600, Nov 21, 2011.
  1. Achilles1600
    Achilles1600 New Member
    Jul 5, 2009
    276 (0.11/day)
    13
    edmonton alberta canada
    Hi, im in the mid's of building a pc, and i bought a coolermaster extreme 600 watt, for my rig.
    spec's are
    core i5 2500k
    Ge-force gtx 560 ti
    4gb G-skill ripjaw's
    corsair H60
    500 gb seagate sata 2 hdd
    coolermaster elite 430, with 4 case fan's
    window's 7 home x64
    cooleraster exreme 600 watt
    And i was wondering, if the my psu will handle all that, and also wondering if i should get a corsair psu.?
  2. technicks
    technicks
    Apr 23, 2006
    3,560 (1.00/day)
    257
    Enschede, The Netherlands
    Corsair psu won't do you wrong imo but the one you have atm will do. But if you are planning to run SLI in the near future i would save the hassle and return the Coolermaster and trade it in for Corsair TX 850 or something similar.
    Achilles1600 says thanks.
  3. Achilles1600
    Jul 5, 2009
    276 (0.11/day)
    13
    ty. :)
  4. Achilles1600
    Jul 5, 2009
    276 (0.11/day)
    13
    Do you know the power consumption on my cpu, would my psu handle my cpu and gpu.
  5. Frick
    Frick Fishfaced Nincompoop
    Feb 27, 2006
    12,193 (3.36/day)
    3,428
    Peak power draw would be around... 300W-ish maybe? 350W?
  6. technicks
    technicks
    Apr 23, 2006
    3,560 (1.00/day)
    257
    If you look at my specs i have about the same as you and my psu is more then enough.
    Thought the 2500k uses about 150w on 3.3Ghz.
  7. bbmarley
    Jul 24, 2008
    490 (0.18/day)
    81
    600W should be fine for that rig
    there is a guy around forums using a cm 600w silent pro gold to power a 2500k and x2 6950s
    im using a cm 700w silent pro gold for my rig in system spec < and no problems
  8. Achilles1600
    Jul 5, 2009
    276 (0.11/day)
    13
    Ok ty so much guy's :)
    technicks says thanks.
  9. entropy13
    entropy13
    Mar 2, 2009
    5,034 (1.99/day)
    1,272
    Replace your psu immediately if you have future plans of adding anything, even as "low-power" as a fan or another hard drive.
  10. Achilles1600
    Jul 5, 2009
    276 (0.11/day)
    13
    Ok, should i go with corsair.?
  11. technicks
    technicks
    Apr 23, 2006
    3,560 (1.00/day)
    257
    No need for it. But if it makes you feel better the go for it.
    If the coolermaster is still available for a refund then just send it back and spend some extra to buy a better psu.
  12. entropy13
    entropy13
    Mar 2, 2009
    5,034 (1.99/day)
    1,272
    Depends on many things. Budget, prices, where you're going to buy, etc.
    Anyway, there are a lot more "suck" PSUs from Cooler Master than good ones. Only the Silent Pro series are decent ones, and the new GX series (but only barely).
    That 600W PSU is actually a 450W PSU. And it's not even 80PLUS Standard. Efficiency is 77% at best, 72% at worst.
    EDIT: Just noticed now that it's an H60 for your cooling. Replace that useless PSU. I have mine only as an emergency back-up now.
  13. John Doe Guest
    Real Power Pro's are great units as well as plain Real Power's to a point. UCP series are solid AcBel designs as well. But yeah, most their low end units are junk. Here's an informative post on CoolerMaster's;
    http://www.overclock.net/t/782991/on-coolermaster-refresh#post10094089
    That said, I'd shoot for this one.
    PC Power and Cooling Silencer 760W High Performanc...
    Silencers constantly get rebates and are better than their Corsair equivalents. In fact, they pretty much are the best units you can get at that range. You can easily SLi on it as you can see here
    http://www.guru3d.com/article/geforce-gtx-560-ti-sli-review/14
    http://www.techpowerup.com/reviews/PC_Power_Cooling/Silencer_760W/8.html
    10 Year Member at TPU
