Idea/project chilled water cooling FITS
Discussion in 'Overclocking & Cooling' started by Fitseries3, Jun 15, 2008.
  1. Fitseries3
    Fitseries3 Eleet Hardware Junkie
    Oct 6, 2007
    15,515 (5.09/day)
    3,119
    Republic of Texas
    OK...
    it may be a ghetto idea (sorry if that word offends you) but i think this will work out very good if i can just experiment with it a bit.
    here's the initial idea...
    take my lonely old thermochill PA120.1 and suspend it in a old crap cooler and fill it with ice, salt and water.
    it's been done before. i know. oh well.
    now this has led me to think a step further and go extreme.
    if the above setup works good im gonna get dry ice and use antifreeze instead of water in the loop. hopefully i can get this crap setup(not really) to cool better then my TEC block.
    we shall soon see.
  2. intel igent
    intel igent New Member
    Jun 5, 2005
    4,641 (1.19/day)
    428
    Toronto, Canada
    don't forget pascals law ;)
    10 Year Member at TPU
  3. dark2099
    dark2099
    Feb 20, 2008
    4,432 (1.52/day)
    758
    where everyone wants to be
    That sounds really interestingly cool.
  4. Fitseries3
    Oct 6, 2007
    15,515 (5.09/day)
    3,119
    Republic of Texas
    im sure i know of it but remind me again.
  5. intel igent
    Jun 5, 2005
    4,641 (1.19/day)
    428
    Toronto, Canada
    i'm buzzed google is your friend :)
    :toast:
  6. cdawall
    cdawall where the hell are my stars
    Jul 23, 2006
    21,725 (6.22/day)
    3,570
    Houston
    In the physical sciences, Pascal's law or Pascal's principle states that "a change in the pressure of an enclosed incompressible fluid is conveyed undiminished to every part of the fluid and to the surfaces of its container."
  7. intel igent
    Jun 5, 2005
    4,641 (1.19/day)
    428
    Toronto, Canada
    that may be part of it , but not the right part ;)
    :toast:
  8. cdawall
    Jul 23, 2006
    21,725 (6.22/day)
    3,570
    Houston
    lol thats what i got off wikipedia
    this any better?
    A law of physics which states that a confined fluid transmits externally applied pressure uniformly in all directions. More exactly, in a static fluid, force is transmitted at the velocity of sound throughout the fluid. The force acts normal to any surface. This natural phenomenon is the basis of the pneumatic fire, balloon, hydraulic jack, and related devices.
  9. Fitseries3
    Oct 6, 2007
    15,515 (5.09/day)
    3,119
    Republic of Texas
    sorry. my brain is off right now. i haven't slept for 5 days now.
    so your saying that i need some sort of movement in the liquid?
  10. intel igent
    Jun 5, 2005
    4,641 (1.19/day)
    428
    Toronto, Canada
    that not it
    am i so buzzed i forgot what i learned?
    where's ma damn text book's.......
    woops! don't i feel like an ass, youv'e got the right one one i'm wrong :banghead:
    something to do with heat transfer......
    still looking......
  11. Skitzo New Member
    Apr 3, 2008
    720 (0.25/day)
    86
    k inteli are you talking bout the pressure drop due to temp in the closed loop because of the dry ice? i think if the loop was open to allow the coolant to drop in temp without restriction, it might be okay. Close it up when you fire it up and there should be less of a pressure change.
    Is the antifreeze going in the dryice solution or the cooling loop? i guess both would be best
    salt in ice water is the best way to chill a warm beer lol, doesn't the salt make the ice melt faster? how long would it cool effectively.
  12. intel igent
    Jun 5, 2005
    4,641 (1.19/day)
    428
    Toronto, Canada
    no, no pressure drop.
    heat transfer...
    now i'm thinking (NOT good)
    still looking.......
  13. Fitseries3
    Oct 6, 2007
    15,515 (5.09/day)
    3,119
    Republic of Texas
    this is why i posted this before i tried the DICE.
  14. Skitzo New Member
    Apr 3, 2008
    720 (0.25/day)
    86
    viscosity change due to pressure and temp can mean more or less heat tranfers right. is that it FTW?:)
    condensation is a concern with sub-zero cooling.
    a second rad giving a major chill to the intake air would be a big plus. As long as the coolant temp is below ambient it shouldn't hurt
  15. intel igent
    Jun 5, 2005
    4,641 (1.19/day)
    428
    Toronto, Canada
    admittedly i'm lost :nutkick:
    maybe sober time? sooner than i thought?
    something to do with an object of any given temp transfering heat to another object of an equal or lesser temp.......
    someone else chime in and correct me or assist........
    maybe it's just the wording that is making me confused :confused:
    i think it was advanced fuels class or was it A/C :wtf: imperial where you at?
    let this be a lesson to you kid's at home drug's + alcohol are BAD :p
    make that a DBL straight up!
    i'm going for a smoke :eek:
  16. dark2099
    dark2099
    Feb 20, 2008
    4,432 (1.52/day)
    758
    Now someone tells me. :p So sounded cool in theory but now seems like it could end up being bad, and when I read pascal's law, I totally thought of something else.
  17. Skitzo New Member
    Apr 3, 2008
    720 (0.25/day)
    86
    at this point I can't really think clearly so I agree with intel - maybe after i shake off the inner fog.
    I do (waves hand through fog) think your talking about multiple variables. If temps are allowed to balance somewhat before the loop is pressurized it will reduce the effect your talking about. Physiscs is awsome, just dificult to explain sometimes.:)
  18. intel igent
    Jun 5, 2005
    4,641 (1.19/day)
    428
    Toronto, Canada
    woah i'm a dick :slap: pascal's law is in relation to hydraulics theory :nutkick:
    still looking for the one i'm reffering to........
    you got my brain semi working fits, thnx
  19. dark2099
    dark2099
    Feb 20, 2008
    4,432 (1.52/day)
    758
    I thought you were referring to the law (or what ever it is) that states "what ever can go wrong will go wrong."
  20. Skitzo New Member
    Apr 3, 2008
    720 (0.25/day)
    86
    that would be my bud Murphey ... he knows his shit lol:)
    dark2099 says thanks.
  21. p_o_s_pc
    p_o_s_pc F@H&WCG addict
    May 2, 2007
    13,009 (4.06/day)
    2,183
    Newark ohio
    oh really i never knew that
    Crunching for Team TPU
  22. Fitseries3
    Oct 6, 2007
    15,515 (5.09/day)
    3,119
    Republic of Texas
    sneakypeet reminded me of a great idea.
    make the longest coil of copper tubing that i can make and put it in the cooler. then put the DICE and water in the cooler. the coil will cool better with the liquid <-> liquid cooling.
  23. intel igent
    Jun 5, 2005
    4,641 (1.19/day)
    428
    Toronto, Canada
    http://www.efunda.com/formulae/heat_transfer/home/overview.cfm
    these says it better than i do
    i got the theories mixed but dis what i'm thinking........
    that good idea for simple chiller :D
    __________________
  24. Fitseries3
    Oct 6, 2007
    15,515 (5.09/day)
    3,119
    Republic of Texas
    well i figured that dissipating a small amount of heat over a huge area supercooled by DICE would be pretty easy.
  25. Skitzo New Member
    Apr 3, 2008
    720 (0.25/day)
    86
    that's what I was trying to say except with less words that made less sence:)
