Idea/project chilled water cooling FITS
Discussion in 'Overclocking & Cooling' started by Fitseries3, Jun 15, 2008.
  1. Skitzo New Member
    Apr 3, 2008
    720 (0.27/day)
    86
    well at that rate we just need to figure out the fluids...:)
  2. ZenEffect New Member
    Mar 12, 2008
    622 (0.23/day)
    86
  3. Skitzo New Member
    Apr 3, 2008
    720 (0.27/day)
    86
    just based on the tables i'd go with Propylene Glycol / Water Mixtures because it'll boil not flash. Eventually the dice will be gone so what ya gonna do when the temp rises. you would need a constant supply of dice. we are talking major oc and heat right? it would depend on the thermal properties though
    EDIT: Ok i just realized you're prolly not looking for full time cooling with this, I get carried away sometimes.
    EDIT: we need to get BLKhogan here, he works with heating and cooling.
    her's some more info... http://www.dow.com/heattrans/fsa/silicone.htm#Anchor-Inhibited-47857
  4. Fitseries3
    Fitseries3 Eleet Hardware Junkie
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    attention plz!
    im gonna be posting a ton here in the next hour.
  5. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    ok...
    here's what i have for the build. i'll be taking the fan off of the rad.
    [​IMG]
    and the hardware...
    [​IMG]
  6. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    ok... i used a few 2" screws to elevate the rad from the bottom of the cooler to allow good flow.
    [​IMG]
  7. modder New Member
    Mar 1, 2008
    382 (0.14/day)
    153
    :D i like Sponge Bob
  8. intel igent
    intel igent New Member
    Jun 5, 2005
    4,641 (1.26/day)
    434
    Toronto, Canada
    place the RAD at an angle if you can to improve/promote the convective aspect of cooling ;)
    still waiting........
    spongebob FTW!
  9. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    rad in cooler...
    [​IMG]
  10. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    built the loop... filled and filling ice
    [​IMG]
    [​IMG]
    [​IMG]
  11. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    and results so far...
    [​IMG]
  12. blkhogan
    blkhogan New Member
    Aug 11, 2007
    2,314 (0.80/day)
    648
    If I told u.. I'd have to kill u
    [​IMG]
    This would be a good idea. The a/c system would need to be matched (BTU's) to the amount of water or other cooling liquid used. The evaporator setting in a properly sized pool of water would be like runing a small "chiller" unit. Using copper cooling lines would further increase the abiltiy to cool. The coil on an average a/c window unit runs at around 32 to 40 (to insure no freeze ups) degree coil temp depending on abient suroundings. You can "starve" the coil to potentualy get lower coil temp. This will cause the coil to start to freeze, but in a pool of liquid it would transfer the temp drop to the liquid.
    You have to remember that all things in nature flow from hot to cold. A substance will always "migrate" to the coldest point of a system. Its getting the substance to exit the coldest point is the other factor in a cooling system.
    If I were to do a solution of liquid for cooling I would use a Propylene Glycol set up, but with DICE it will tend to start to gel if droped to real xtream temps. Most of your bar "beer" coolers with "tap" servers will run a Propylene Glycol cooling system along with the beer lines leading to the tap. Beer is usualy served at 31 to 34 degrees at the tap.
    Skitzo says thanks.
  13. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    after it chilled down for a bit i ran a full load test.
    [​IMG]
  14. dark2099
    dark2099
    Feb 20, 2008
    4,420 (1.64/day)
    757
    where everyone wants to be
    Are you just using 1 core for testing?
  15. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    no. this chips got a funny temp sensor.
  16. dark2099
    dark2099
    Feb 20, 2008
    4,420 (1.64/day)
    757
    Ah that could do it. Looks promising now.
  17. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    rad temp....
    [​IMG]
  18. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    this is a totally usefull way to cool your cpu for OCing and benching. i've been running this for almost an hour now and temps are still the same. i only put in half a bag of ice and half a gallon of water.
    idle temps on this setup are as cool as my TEC block. load temps on the TEC are only a few degrees higher then idle though. that has to do with the fact that the TEC is direct die cooling.
  19. intel igent
    Jun 5, 2005
    4,641 (1.26/day)
    434
    Toronto, Canada
    try tilting the RAD on an angle to see if it make's a difference
  20. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    i gave it a cool 10 min try and nothing different. :(
  21. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,237 (2.88/day)
    2,151
    Granite Bay, CA
    What you need is an underwater pump blowing through the rad's fins ^^
  22. Skitzo New Member
    Apr 3, 2008
    720 (0.27/day)
    86
    circulation makes sense, got it on the pc side of the cooling system.
    That makes me wonder about putting the rad in a fountain. :)
  23. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    WARNING!!!
    you MUST insulate your board for any type of cooling that will bring temps below room temp. condensation WILL OCCUR and your motherboard, cpu, etc. may be damaged.
  24. Skitzo New Member
    Apr 3, 2008
    720 (0.27/day)
    86
    this should prolly be at the begining :)
    :eek:I hope your not saying you've had a problem...
    EDIT: Blkhogan are there any fluids that won't cause condensation in the pc loop using the same equipment?
  25. Fitseries3
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    lol
    well kinda but not really.
    after only an hour of use i had a nice puddle of water on my cpu when i pulled the block off.
    i just blew it off with the air compressor and it boot right up again. no problems.
Share This Page
