Idea/project chilled water cooling FITS
Discussion in 'Overclocking & Cooling' started by Fitseries3, Jun 15, 2008.
  1. Skitzo New Member
    Apr 3, 2008
    720 (0.29/day)
    86
    glad it's okay:) Insulating could be alot of work, is it worth the effort for part time cooling? Gonna have to come up with a temperary measure. maybe some wicking fabric and hang it cpu down?
  2. Fitseries3
    Fitseries3 Eleet Hardware Junkie
    Oct 6, 2007
    15,509 (5.80/day)
    3,107
    Republic of Texas
    it's not that hard for what i've done so far. when you start going into phase, DICE, and LN2 you need to do a lot more prep work though.
  3. Skitzo New Member
    Apr 3, 2008
    720 (0.29/day)
    86
    someone should do an insulating guide, i planned going liquid but this makes it more interesting.:)
  4. imperialreign
    imperialreign New Member
    Jul 19, 2007
    7,043 (2.56/day)
    909
    Sector ZZ₉ Plural Z Alpha
    it wouldn't be too hard to insulate the lines themselves - but trying to insulate the actual block would be a bit of a chore.
    an idea - take two long spare pieces of rubber hose and place them over the in/outlets, take a piece of duct tape or similar and place over a clean mating surface so it only covers the flat surface itself, trim with a razer. lower the block into a small bucket or cup that's been filled with rubber cement for a minute or two, pull out and let dry thoroughly - remove the tape from the mating surface, trim any excess rubber cement off with a razer, clean the surface to remove any left over glue from the tape - remove the hose off the in/outlets, and that should be quite well insulated.
    perhaps after drying, you could even dunk for a second coat.
    not sure how well it'll work, but it might be worth the experiment ;)
  5. Fitseries3
    Oct 6, 2007
    15,509 (5.80/day)
    3,107
    Republic of Texas
  6. Skitzo New Member
    Apr 3, 2008
    720 (0.29/day)
    86
    yeah, I was thinking liquid electrical tape. What about the cpu, would it too not build up condensation? The lower the temp the farther out the mb would have to be managed aswell would it not?
  7. imperialreign
    Jul 19, 2007
    7,043 (2.56/day)
    909
    well, for really extreme setups, I think the rubber cement idea would work as well - I know in the automotive feild, onboard computer PCBs are dipped before placed into sealed housings - although, I've taken some apart before and found moisture inside.
  8. Fitseries3
    Oct 6, 2007
    15,509 (5.80/day)
    3,107
    Republic of Texas
  9. Skitzo New Member
    Apr 3, 2008
    720 (0.29/day)
    86
    Fitseries3 says thanks.
  10. dark2099
    dark2099
    Feb 20, 2008
    4,400 (1.73/day)
    755
    where everyone wants to be
    Anything new happening here?
  11. Fitseries3
    Oct 6, 2007
    15,509 (5.80/day)
    3,107
    Republic of Texas
    im working on scoring a free window AC and a few other things. you'd be surprised how much stuff costs these days. 15ft of 1/2" coper tubing is $24 now. WOW! that's a lot.
Share This Page
