I'm going water cooling- advice needed
Discussion in 'Overclocking & Cooling' started by viczulis, Mar 3, 2009.
  1. viczulis
    viczulis New Member
    Dec 29, 2007
    891 (0.32/day)
    69
    Ohio
    I read every thread here on water cooling. And searched on google. I'm going to list parts that I'm thinking about getting and I'm hoping for some input. All I'm looking for to cool now is CPU.
    But I'm also trying to look ahead in case I want to do video cards. so any help would be appreciated. :toast:
    D-Tex Fusion V2 CPU Block
    http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=210
    Bits Power Water Tank Z Plus reservior
    http://www.frozencpu.com/products/6...ng_Reservoir_-_Tank_Z_Plus.html?tl=g30c97s166
    Swiftech MCP655 Pump
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835108082
    Danger Den- Black Ice GTX Xtreme 360 Rad
    http://www.frozencpu.com/products/5...treme_360_Radiator_-_Black.html?tl=g30c95s161
    Hopefully this is a good Start
    Also would it be worth doing my North Bridge ? I would have to take parts off mother board.
    My specs is what I'm wanting to water cool.
  2. Paulieg
    Paulieg The Mad Moderator Staff Member
    Feb 19, 2007
    11,957 (3.91/day)
    3,034
    Wherever I can find the iron.
    The Dtek Fusion v2 or the Apogee GTX is a better option. I'd also go with a Black Ice GTX or Thermochill rad. Good choice of pump and Res. Though you could get a Swiftech Micro res that will do the job nicely, and it's cheaper. The v2 is on sale at sidewinders. Here's a link:
    http://order.store.yahoo.net/cgi-bin/wg-order?sidewindercomputers
    viczulis says thanks.
  3. Binge
    Binge Overclocking Surrealism
    Sep 15, 2008
    6,981 (2.81/day)
    1,753
    PA, USA
    I have had great experiences with my GTZ, but I am about to sell it. It's not a bad block by any means.
  4. Paulieg
    Feb 19, 2007
    11,957 (3.91/day)
    3,034
    No, its a good block from what I've read, but I believe the Fusion v2 is a couple of degrees better, and generally you can find it cheaper.
  5. Binge
    Sep 15, 2008
    6,981 (2.81/day)
    1,753
    PA, USA
  6. Paulieg
    Feb 19, 2007
    11,957 (3.91/day)
    3,034
  7. viczulis
    viczulis New Member
    Dec 29, 2007
    891 (0.32/day)
    69
    Ohio
    Updated Parts list Thanks Paulie :toast:
    I really like the look of that D-tex V2 . Binge sorry man I'm going to go with the V2.
  8. SerenadeRB
    SerenadeRB New Member
    Jun 30, 2008
    183 (0.07/day)
    33
    Whitestone, NY
    What RPM fans do you plan on using with your rad? Silent/low RPM fans work perfectly with the swiftech rad, as well as the thermochill, but swiftech is more user-friendly. Also, I think a 3 fan radiator is overkill by a long shot for a 45nm Core 2 duo.
    They are spec'd at 65W, and only give off about 150 OC'd like yours is. A Swiftech MCR 220 http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=3653
    with fans in pull < 1350 RPM would be more than sufficient for your needs. Also the Fusion V2 is a very low restriction block, so a DDC3.2 pump would also suit you well.
    PM me if you wanna discuss some WC fun =]
  9. phanbuey
    phanbuey
    Nov 13, 2007
    5,225 (1.87/day)
    991
    Miami
    go for the 3 x 120 rad just because once you've had watercooling... wou will want to watercool EVERYTHING. Ive gone through 3 rads now, and wished i got the 3x120 to begin with.
    Im so glad the gpu's are under water now... they are so much colder.
  10. viczulis
    viczulis New Member
    Dec 29, 2007
    891 (0.32/day)
    69
    Ohio
    Yea Phanbuey I think your right :toast: Now I'm thinking about doing chipsets ( I'm trying to see if blocks are the same from Rampage extreme to Rampage X48 not having to much luck) But then I'm thinking of getting rid of my crossfire and just use the one video card and water that one. :D Starts out small and turns out big. I guess if your going to go for it you mine as well go all them way.
    No wonder why my wife gives me shit. :D Dam alot of learning on water cooling. But this is the set-up which I'm going to try to match.
  11. aspire
    May 27, 2007
    290 (0.10/day)
    30
    I would go for a Laing DDC 3.2 with an XSPC top instead.
    It'll give you better performance in a smaller package.
    And an XSPC RX360 for the rad. Which will give you excellent performance for a great price and not require high cfm fans to accomplish it.
  12. viczulis
    viczulis New Member
    Dec 29, 2007
    891 (0.32/day)
    69
    Ohio
    Aspire thanks I'll look those up, dam every time I think I'm ready to order something new comes up. LOL Hey but at least I found water block for my NB-SB .
  13. Pete1burn
    Pete1burn
    Feb 5, 2009
    835 (0.36/day)
    70
  14. viczulis
    viczulis New Member
    Dec 29, 2007
    891 (0.32/day)
    69
    Ohio
    Thanks but none in stock
  15. viczulis
    viczulis New Member
    Dec 29, 2007
    891 (0.32/day)
    69
    Ohio
    OK after alot of reading, this is what I came up with. Hopefully this will be ass kicking.:)
    Also later on I might do a video card. After/when I get next card. Which I'll probably just get a single or double rad and run a new loop. That would probably be the way to go. I THINK.
    Just made my last order. Whats the good and bad ?
    1) XSPC Reservior Top (Laing DDC) Petras
    2) Laing DDC 3.2 18W Swiftech MCP355 Inline 12v Pump Petras
    3) PTS Ultimate Radiator PTSURC-MC320 Combo MCR320 OP Edition with Yate Loon Med Petras
    4) Swiftech MCB 120 Rad Box MCB120 Blk Rev2 Petras
    5) 10 - G1/4 Fat Boy 1/2" fittings Danger Den
    6) 15 Ft Primo Flex Pro LRT UV Red Tubing 3/8s Jab Tech
    7) D-Tex V-2 CPU Block Side Winders
    8) Bitspower Black Freezer Chipset Block Sidwinder
    Am I missing anything ? :D
    Thanks for all the help and threads :toast:
  16. Tatty_One
    Tatty_One Senior Moderator Staff Member
    Jan 18, 2006
    17,516 (5.07/day)
    3,286
    Worcestershire, UK
    Some nice choices there, I have ben vonsidering H2o for a while now and most of what I have been considering is on your list! How much will that lot set you back?
  17. viczulis
    viczulis New Member
    Dec 29, 2007
    891 (0.32/day)
    69
    Ohio
    $435.00 Everything, that includes shipping :eek: Going to be hard to hide this one from the wife :D
  18. Tatty_One
    Jan 18, 2006
    17,516 (5.07/day)
    3,286
    Worcestershire, UK
    Think yourself lucky, it costs more than that in UK £ here :cry:
  19. viczulis
    viczulis New Member
    Dec 29, 2007
    891 (0.32/day)
    69
    Ohio
    Okay got all my parts. Got a couple pics here. I think I took the pussy way out but this being my first time I decided to test outside my case.
    First took everything apart and cleaned with distilled water and a soft toothbrush. Reassembled and hooked up out side the case. Been running now for four hours no leaks.
    Dam is there an easy way to get 3/8 hose on 1/2 inch barbs ? What a pain in the ass. :banghead: ( I bought xtra hose so I could do this)
    I'm assuming it dosent matter what side of rad you start with ?
    Rad > CPU> Chipset > Rev > Rad Thats my loop that should be the best for my system right ?
    Anyways heres pics so far. If something can be done better let me know. :D
  20. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,418 (6.40/day)
    4,495
    Youngstown, OH
    **subscribed**
    Can't wait to see the final product. Depending on how yours turns out I may turn to water also.(We discussed this already ...)
  21. viczulis
    viczulis New Member
    Dec 29, 2007
    891 (0.32/day)
    69
    Ohio
    Yea we did so far so good. Seems pretty easy hardest thing so far was just getting tubing on barbs. :laugh: Sad thing is I got to head to MI for a couple weeks dont think I'll finish tomorrow :cry:
    I'm really trying to take my time dont want to screw up my board. :D
    Also was looking for GPU block cant find one for my Sapphire 100259 1 GL GDDR5 seems not compatible with that card. Damit Bobbie
  22. douglatins
    douglatins
    May 15, 2008
    2,869 (1.10/day)
    273
    Brasil
    Nice! I want.... Drool
  23. BumbleBee
    BumbleBee
    Mar 6, 2009
    5,290 (2.29/day)
    1,668
    Cybertron aka Canada
  24. viczulis
    viczulis New Member
    Dec 29, 2007
    891 (0.32/day)
    69
    Ohio
    Thanks BB I guess problem was I was looking at full cover blocks. lol Still a noob at water cooling.
  25. BumbleBee
    BumbleBee
    Mar 6, 2009
    5,290 (2.29/day)
    1,668
    full coverage water blocks will cool hot spots on a video card that a gpu coverage water block can't but because of the amount of surface they cover, tend to be more restrictive and reduce flow rate they are also more expensive and incompatible with other current or next generation video cards. a gpu coverage water block like the Swiftech MCW60* will cool the gpu more efficiently, it's inexpensive and is compatible with all current and next generation video cards (unless they change drastically) so what about the memory? it's not in trouble in fact the 4870 uses thermal pads so aluminum or copper in this case which has twice the thermal conductivity of aluminum will be more than enough.
Share This Page
