I'm thinking of buying PC parts again
Discussion in 'General Hardware' started by DaMulta, Apr 6, 2007.
  1. DaMulta
    DaMulta My stars went supernova
    Aug 3, 2006
    16,135 (4.87/day)
    1,459
    Oklahoma T-Town
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131047R
    Open Box: ASUS P5W64 WS Professional Socket T (LGA 775) Intel 975X ATX Server Motherboard - OEM $190.99
    [​IMG]
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819117102
    Intel Xeon 3040 Conroe 1.86GHz 2M shared L2 Cache LGA 775 Processor - Retail
    $200.99
    OR
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115005
    Intel Core 2 Duo E6300 Conroe 1.86GHz 2M shared L2 Cache LGA 775 Processor - Retail $181.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813135024
    ECS KA3 MVP (V1.0A) Socket AM2 AMD 580X CrossFire ATX AMD Motherboard - Retail $124.99
    [​IMG]
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103759
    AMD Athlon 64 X2 5200+ Windsor 2.6GHz 2 x 1MB L2 Cache Socket AM2 Processor - Retail $200.99
    OR
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819105149
    AMD Opteron 1212 HE Santa Ana 2.0GHz 2 x 1MB L2 Cache Socket AM2 Processor - OEM $219.00
    I just don't know what too do wait another month or buy now. I do want 3x PCI-Express slots just because of physics support if I wanted it in the future. But I guess I could do without them at the same time. I backed out of buying at the beginning of January and I'm kinda happy I did and not so.
    What do you guys think of the above?
  2. Zalmann
    Zalmann New Member
    Feb 25, 2007
    910 (0.29/day)
    3
    Perth, Australia
    If I were you, I'd go with the Intel rig and the E6300 right now. Will give you better performance compared to the others.
  3. Polaris573
    Polaris573 Senior Moderator
    Feb 26, 2005
    4,281 (1.12/day)
    718
    Little Rock, USA
    I would go with the Xeon. You're already paying so much, you might as well spend the extra $20 and I bet it would overclock great.
  4. Zalmann
    Zalmann New Member
    Feb 25, 2007
    910 (0.29/day)
    3
    Perth, Australia
    The E6300 is a proven over clocker, the Xeon on the other hand, haven't heard much about, in terms of OC'ing. I would pick the one that is known to OC, if that's what it will be used for.
  5. DaMulta
    Aug 3, 2006
    16,135 (4.87/day)
    1,459
    Oklahoma T-Town
    I'm wondering if its the same chip with a different name.
    Would those 2 AMD chips be faster?
    I guess I need to look up reviews.......
  6. Zalmann
    Zalmann New Member
    Feb 25, 2007
    910 (0.29/day)
    3
    Perth, Australia
    My thoughts would be no. Not this current generation, unless you want to wait for AMD to release their answer to Core2, the K10, which is still a while away.
  7. DaMulta
    Aug 3, 2006
    16,135 (4.87/day)
    1,459
    Oklahoma T-Town
    Yea but its a low end Intel Vs High end AMD
  8. Zalmann
    Zalmann New Member
    Feb 25, 2007
    910 (0.29/day)
    3
    Perth, Australia
    Well yeah, and it means you can upgrade your low end Intel to something a little higher down the track without upgrading your MB.
  9. tkpenalty New Member
    Sep 26, 2006
    6,958 (2.13/day)
    345
    Australia, Sydney
    Correction DaMulta, High end VS High end. E6xxx series is considered high end. E4xxxx is considered High-mid, pentium D = mid Pentium 4 = low Celeron = fuck off, too shit.
  10. Polaris573
    Feb 26, 2005
    4,281 (1.12/day)
    718
    Little Rock, USA
    They're the same processor, only the Xeons are supposedly more stable/higher quality. The only thing that might be different could be the stepping which would come down to luck if he got a 6300 anyway. So if the 6300 overclocks well then the Xeon, in theory, could be better because Intel claims it is higher quality. While I know this doesn't always hold true, for an extra $20 on a several hundred dollar computer isn't it worth a try?
  11. DaMulta
    Aug 3, 2006
    16,135 (4.87/day)
    1,459
    Oklahoma T-Town
    U can a 6300 oc to 6700 speeds right?
    The xeon seems the way to go, but I'm going to look into it more.
  12. FOXCONN1115 New Member
    Mar 30, 2007
    398 (0.13/day)
    8
    Rhode Island, USA
    I think you should just wait till June, which is when the C2D's and AM2's will be uber low priced, along with a lot of other hardware, and just get a core 2 duo e6400 with a decent dfi or asus board, 2gigs of ram, and dual sata 3gb/s hdd's and raid-0 them.. :D
Share This Page
