Intel's upcoming Teraflop CPU to use less than 70W power
Discussion in 'General Hardware' started by Ben Clarke, Aug 16, 2007.
  1. Ben Clarke
    Ben Clarke
    Aug 10, 2006
    4,403 (1.45/day)
    152
    England
    Intel's experimental 1TFlop CPU is currently using 62W of power, and uses less than 1V on a 65nm process. It currently has 3.16GHz on each core, with 80 cores, totalling up to 1.01TFlops. Intel also has 2 more in development. Here is a chart showing what is currently in development:
    Frequency Voltage Power Aggregate Bandwidth Performance
    3.16 GHz 0.95 V 62W 1.62 Terabits/s 1.01 Teraflops
    5.1 GHz 1.2 V 175W 2.61 Terabits/s 1.63 Teraflops
    5.7 GHz 1.35 V 265W 2.92 Terabits/s 1.81 Teraflops
    Source: Intel
  2. tkpenalty New Member
    Sep 26, 2006
    6,958 (2.33/day)
    345
    Australia, Sydney
    Ben = Pretentious :p
    Joking, but, Teraflops = squat.
  3. Ben Clarke
    Ben Clarke
    Aug 10, 2006
    4,403 (1.45/day)
    152
    England
    How can you say that 1TFlop = Nothing?
    Blasphemer!
  4. ex_reven New Member
    Sep 4, 2006
    5,225 (1.74/day)
    171
    Blue Gene does 360 tera-f.l.o.p.s.
    The question is....what do you do with all of them :)
  5. Ben Clarke
    Ben Clarke
    Aug 10, 2006
    4,403 (1.45/day)
    152
    England
    Yeah, but Blue Gene is like 7000 computers in a high-speed LAN, I believe.
  6. ex_reven New Member
    Sep 4, 2006
    5,225 (1.74/day)
    171
    I dont think they would LAN supercomputers.
    That would probably be a bottleneck.
    More like a single massive system with a heap of integrated processors, each with their own ram etc.
  7. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.75/day)
    1,383
    It's called a cluster. Many supercomputers are in fact clusters.
  8. ex_reven New Member
    Sep 4, 2006
    5,225 (1.74/day)
    171
    So the LAN thing was right or wrong :confused:?
  9. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.75/day)
    1,383
  10. ex_reven New Member
    Sep 4, 2006
    5,225 (1.74/day)
    171
    so i was only half right!? :cry:
    Whats the LAN medium/controlling hardware?
    Fibre optic?
  11. zekrahminator
    zekrahminator McLovin
    Jan 29, 2006
    9,113 (2.83/day)
    321
    My house.
    If you want to be a newsposter, Clarke, you should talk to W1zzard ;).
  12. Ben Clarke
    Ben Clarke
    Aug 10, 2006
    4,403 (1.45/day)
    152
    England
    nah, not newspaposter. I don't find that much stuff ;)
  13. ex_reven New Member
    Sep 4, 2006
    5,225 (1.74/day)
    171
    Yay, everyone can therefore spam and increase post count.
    :roll:
  14. Ben Clarke
    Ben Clarke
    Aug 10, 2006
    4,403 (1.45/day)
    152
    England
    Wait, how does me saying I don't want to be a newsposter account for everyone spamming?
  15. Ketxxx
    Ketxxx Heedless Psychic
    Mar 4, 2006
    11,510 (3.61/day)
    570
    Kingdom of gods
    Somehow, it just does it would seem :p
  16. Ben Clarke
    Ben Clarke
    Aug 10, 2006
    4,403 (1.45/day)
    152
    England
    Hmm... in that case, I must be some sort of a demi-god. Wierd.
  17. Sasqui
    Sasqui
    Dec 6, 2005
    7,758 (2.37/day)
    1,482
    Manchester, NH
    Personally, I thought it was a worthy post... you should include the source.
    Demi-God if you think so. My post count just went up by one, but just because I said that some mod will deduct 100 :rolleyes:
  18. Ben Clarke
    Ben Clarke
    Aug 10, 2006
    4,403 (1.45/day)
    152
    England
    OK, source coming up if I can figure out how to make it a word and not the URL.
    EDIT: It's there.
  19. Sasqui
    Sasqui
    Dec 6, 2005
    7,758 (2.37/day)
    1,482
    Manchester, NH
  20. Ben Clarke
    Ben Clarke
    Aug 10, 2006
    4,403 (1.45/day)
    152
    England
    May I just say, the chip is roughly 1 foot x 1/2 foot. Big chip.
  21. kwchang007
    kwchang007 New Member
    Jan 27, 2007
    3,979 (1.39/day)
    185
    Severn, MD, USA.
    So...1.01 teraflops over 80 cores? So each core carries out ~.0126 teraflops. Let's see my computer peaked at 7655 megaflops on scienecmark. Since the SGEMM isn't multi-threaded, that's 7655 megaflops per core. So, 7.655 gigaflops, .007655 teraflops. Now let's take a core 2 at 3ghz, just going on my score and scaling it up by 5/3's. That's ~ .0128 teraflops. Wow, this is a very efficient architecture, I was expecting core 2 to be much more efficient but that's not true. But somewhere they had to get rid of something that makes it work worse, and I bet that's cache. It probably has very little cache per core.
  22. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.75/day)
    1,383
    How much power is required to let several Core2's do the same amount of work? Ah yes that must be the key here.
  23. kwchang007
    Jan 27, 2007
    3,979 (1.39/day)
    185
    Severn, MD, USA.
    Yeah, I was saying somewhere they must've cut something in order to save energy and lower heat dissipation. Either that or Intel has made a similarly efficient architecture with less transistors (since it is 65 nm). My bet is they took out chunks of conroe and which is why it can clock so high. I wonder if this will use CSI so they can really cut down on the cache.
Share This Page
