Internet Speed not going higher 100Mbps
120 (0.04/day)
System Name Silent But Deadly ROB
Processor Intel I5 6600K
Motherboard Asus Z170 Maximus VIII Ranger
Cooling Dark Rock 3 + 1x Silent Wings 2 120MM PWM + 2x Pure Wings 2 140MM
Memory Kingston 16GB DDR4 2666MHz HyperX Fury Black
Video Card(s) MSI GTX 1070 GAMING X 8GB
Storage SSD 850 Evo 500GB + Seagate Barracuda 1TB 7200RPM
Display(s) Dell 27" QHD S2716DG 144Hz G-SYNC
Case Fractal Define S Window
Power Supply EVGA SuperNova G2 850W
Mouse Mionix Avior 7000 - SteelSeries QCK+
Keyboard Ozone Strike Pro
Hello Everyone.
I have a problem here wich is: I have a Asus VIII Z170 Ranger and i'm using Windows 10 and my internet connection is 120 Mbps.
Here's the deal... For some reason i can't get past 97Mbps speed, even when i had my Asus VII Hero i could reach 125Mbps easily... My ISP says it's my network adapter that doesn't go higher than 100 Mbps, wich is impossible because this motherboard adapter shares the same as VII Hero and i always managed higher than 100Mbps on that motherboard...
What could be the problem here? Drivers? Internet Cable? Windows 10 limitations? Or is it really the network adapter from Asus VIII Ranger that doesn't support higher speeds??
Best regards.
OneMoar
There is Always Moar
8,746 (1.70/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Cooling Enermax ETX-T50RGB
Storage ADATA SX8200PRO NVME 512GB, Intel 545s 500GBSSD, ADATA SU800 SSD, 3TB Spinner
Mouse Kone burst Pro
Keyboard EVGA Z15
check and make sure the the link speed is indeed being negotiated at gigabit
may also pay to fiddle with the adapter options in the device manager likely some bit of power saving junk enabled
and your isp's support staff is clearly retarded
3,059 (0.45/day)
Baltimore MD
Processor Ryzen 5900X
Motherboard ASUS Prime X470 Pro
Cooling Arctic liquid freezer II 240
Memory 2 x 16 Gb Gskill Trident Z 3600 Mhz
Video Card(s) MSI Ventus 3060 Ti OC
Storage Samsung 960 EVO 500 Gb / 860 EVO 1 Tb
Display(s) Dell S2719DGF
Case Lian Li Lancool II Mesh
Mouse Logitech G703
Keyboard Logitech G513
Software Win 11
I'm going to bet on cable, you need a decent cat5e cable or cat6 to get gigabit Ethernet over 10ft
  • Like
Reactions: xvi
dorsetknob
9,105 (1.30/day)
Of course how can they make money on call duration ect if they give you the right answers
120 (0.04/day)
If you could be more specific on this please... When i check my Ethernet Connection Settings on control panel it does say "Speed: 100.0 Mbps" something's here limiting my speeds...
OneMoar
8,746 (1.70/day)
Rochester area
Keyboard EVGA Z15
If you could be more specific on this please... When i check my Ethernet Connection Settings on control panel it does say "Speed: 100.00Mbps" something's here limiting my speeds...
device manager> rightclick on the network adapter;properties
if its not negotiating a gigabit link is definitely the issue
now you need to figure out why
start with turning the power saving stuff off under the advanced tab
then check and make sure speed and duplex is set to auto or 1.0Gb/s full-duplex
2,323 (0.52/day)
System Name msdos
Processor 8086
Motherboard mainboard
Cooling passive
Memory 640KB + 384KB extended
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Audio Device(s) modchip
Power Supply 45 watts
Mouse serial
Keyboard yes
Software disk commander
10/8 -> 1.19MB/s
100/8 -> 11.9MB/s
What's your best MB/s download rate?
12,280 (2.36/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
Did you try it without a router. Just trouble shoot it and fined where is not getting the speed. Most likely its your ISP
120 (0.04/day)
it not negotiating a gigabit link is definitely the issue
I get "Intel Ethernet Connection (2) I219-V" On the network adapters list in device manager.
OneMoar
8,746 (1.70/day)
Rochester area
Keyboard EVGA Z15
so right click on and and goto properties then you should have access to the advanced settings
start with the green ethernet and adaptive frame spacing
disable them they are known to cause issues with some routers
120 (0.04/day)
You know what? The problem is solved. My ISP is clearly retarded. They gave me a Cat5 cable wich only support 100 Mbps .... I grabbed a Cat5e from a friend and there you 1.0 Gbps! Dear Lord... And there are a lot of good workers out there that don't have a job, and they send me this :banghead:
OneMoar
8,746 (1.70/day)
Rochester area
Keyboard EVGA Z15
cat5 should have gotten you gigabit I get gigabit over this ....
12,280 (2.36/day)
Oregon
in short runs it will
It was probably just traffic and its cleared up now
  • Like
Reactions: xvi
OneMoar
8,746 (1.70/day)
Rochester area
Keyboard EVGA Z15
thats a 50 foot run though 4 walls and two of those quick-crimpless ends with that junk lol
it really doesn't matter unless you are running >100ft or though a area with a lot of EMI
Aquinus
Resident Wat-man
13,147 (2.94/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Is there any reason why no one has asked the OP about his network setup? Are we 100% certain that both the modem and router support gigabit?
Missed that. Cat5 isn't spec'ed for gigabit. 5e is. It could just be the amount of EMI or crosstalk from the cruddy cable.
  • Like
Reactions: xvi
OneMoar
8,746 (1.70/day)
Rochester area
Keyboard EVGA Z15
because the issues is resolved and his previous setup had no issues getting GBE ....
Aquinus
Resident Wat-man
13,147 (2.94/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
I saw that. I missed the last post. Clearly it's a really sub-par Cat 5 cable.
There is a 5e run at work that runs at 100mbit for one reason or another but I think it due to length. Either way, it's interesting that it was the cable but not entirely surprising.
120 (0.04/day)
Yeah, the problem was my cable. No comments on this.
Well, thank you all guys, situation is solved.
