Introducing picoPSU-60-WI, world's tiniest 6-26V input DC-DC ATX power supply unit
Discussion in 'News' started by Darksaber, Jun 15, 2006.
  1. Darksaber
    Darksaber W1zzard's Sidekick Staff Member
    Jul 8, 2005
    2,684 (0.69/day)
    957
    Gmunden, Austria
    Compact design, less cables. The picoPSU-60-WI is the smallest snap-in 6-26V ATX dc-dc power supply. The picoPSU is compatible with an entire range of mini-itx motherboards as well as regular boards. The picoPSU-60-WI provides a cool, silent 60 Watts/ 80 Watt peak of power for small PC designs using a single 6-26V power source.
    [​IMG] [​IMG]
    By using Patent Pending HyperWatt[TM] technologies , picoPSU-60-WI packs an impressive amount of power relative with its very small footprint. PicoPSU-60-WI has several key advantages over traditional power supplies:
    - Very small, can build ultra-compact PC enclosures and slim server enclosures.
    - Fits any motherboard equipped with a 20 or 24pin ATX connector.
    - 100% silent, fanless, no moving parts.
    - Operates at only 6-26V.
    - Highly efficient design, does not produce a lot of heat.
    - Ideal for low power Intel Core Duo as well as all VIA C3/C7 motherboards.
    Small computer projects start with small power supplies. PicoPSU-60-WI is a crucial key component that unleashes the ultimate power solution for general purpose computing platforms. PicoPSU-60-WI is fully ATX compliant PSU, making it an excellent candidate for any silent, fanless and small 6-26V DC-DC ATX PC power supply project.
    Reduce space. Eliminate 20 unnecessary wires by plugging in directly into the motherboard ATX connector. The picoPSU-60-WI 6-26V dc-dc ATX converter was designed from ground up to fit small form factor ATX boards, allowing enclosure designers to save space while not compromising power requirements.
    Cool power. Operating at only 6-26V, the picoPSU-60-WI dc-dc ATX power supply delivers 60 Watts/ 80Watt peak of power. picoPSU provides plenty of power (via ATX connector and HDD cable harness) for CPU and an entire range of peripherals.
    100% Silent The picoPSU-60-WI mini PSU is a 100% silent fanless dc to dc solution. No fans, no noise, just power for small and silent PCs.
    picoPSU-60-WI is a fully compliant DC-DC ATX PC PSU. It can power VIA mini-ITX boards with C3 or C7 processors, Pentium-M, Core Duo Mobile that gets V(core) from the 5V rail.
    picoPSU-60-WI ATX DC-DC converter is very small, measuring just 31x45x20mm, about the size of two AA batteries, picoPSU-60-WI is also 1U ServerRack compliant.
    Source: Mini-box.com
    10 Year Member at TPU
  2. ChaoticBlankness
    ChaoticBlankness New Member
    May 12, 2006
    492 (0.14/day)
    8
    A small crate floating in the Pacific..
    Not impressed...
    This PSU isn't even up to code as it uses 20-pin connector. Sure, it's not going to be a product widely purchased by everyone.. but it is important to keep with the times. lol
    All in all, a nifty little PSU.
  3. DaJMasta
    Nov 6, 2005
    479 (0.13/day)
    38
    Silver Spring, MD
    Just cause it's compatable with 24 pin mobos dosen't mean it can power anything more than the lowest-end desktop CPUs....
    I've got the 120 Watt version, and for what it does, it's a wonder! Almost no heat, low power consumption (great when running off batteries), and tiny, sticks up less than an inch from the top of the mobo's PSU connector.
    They're a little pricey, but are must-haves for mini-ITX boards.
    ....Hmmmm.... One of AMD's new 35 Watt TDP processors and a passive gpu... you may be able to get by with the 120 Watt version in a real HTPC computer, as long as you don't need more than a couple rotating drives ;)
  4. POGE
    POGE New Member
    Oct 28, 2005
    1,724 (0.46/day)
    35
    In banjo's Goats.
    Doesnt this have to have an external power brick also?
  5. ChaoticBlankness
    May 12, 2006
    492 (0.14/day)
    8
    *sigh*
    I was just teasing man... lol It's ok, and I do find it to be cool.
    Shame there isn't more VIA mini C7's around. One of these could be useful.
  6. Tory New Member
    Jul 16, 2005
    339 (0.09/day)
    2
    If you want to plug it into the wall, yes.
  7. markkleb Guest
    Hi Poge,
    yes it does need a 12V power brick or 12V dc source (car battery). I use a 200 watt version in my Lego comp and its barely bigger than a stick of memory.
    If you take the time to really see how much power stuff draws you will be suprised. You could use the 200 watt one to power a full size desktop with a 7600GS.
    They almost produce NO heat as well.
  8. Debdeep New Member
    Aug 10, 2009
    1 (0.00/day)
    0
    Hello All,
    I am interested in purchasing picopsu for my pesonnal computer. However I am not able to find any distributer or seler in India. Can someone please help me? A picopsu-60wi would be ideal, but a picopsu-90 or picopsu-120 woill also serve the purpose.
