- Oct 9, 2007
- 46,277 (7.69/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Expanding your water block options is Koolance, out with water blocks for NVIDIA's GeForce GTX 295 and GeForce GTX 285 graphics accelerators. The blocks by Koolance use nickel-plated copper, acrylic, the block for GTX 295 comes with built-in lighting for better aesthetics. Both blocks are monolithic, full-coverage by design.
The GTX 295 block (model: VID-NX295) measures 20cm x 12cm x 3cm and weighs around 1 kg (2.25 lbs). As with other blocks in its class, the block remains sandwiched between the business-ends of the two PCBs holding a GPU system each. The block for the GTX 285 (model: VID-NX285) measures 15.9cm x 14.6cm x 1.6cm and weighs 680g (around 1.5 lbs). Both blocks come with standard fittings, with fittings for SLI systems being optional and compatible. The Koolance VID-NX295 has started selling for US $159.99 a piece, with the VID-NX285 being priced at $99.99 at the Koolance store.
