Laptop Drive problem - help please
Discussion in 'General Hardware' started by Mussels, Feb 27, 2012.
  1. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    44,264 (10.68/day)
    11,432
    Australalalalalaia.
    Short version:
    I have a HP DV6304TX laptop. the primary sata port is dead, and no power goes to a hard drive in that slot.
    the DVD drive works fine however, to launch an OS or bootable CD/DVD.
    What i've done is acquired an adaptor to let me put a 2.5" HDD in the ODD bay and used a USB stick to install windows 7 - and it worked fine.
    the problem is that the laptops BIOS refuses to see the hard drive as bootable in the DVD bay.
    Now it DOES have an SD card slot, so if i can get the bootloader onto that, i can use that as the boot device and load the OS off this hard drive. does anyone know how to do that?
    10 Year Member at TPU
  2. streetfighter 2
    streetfighter 2 New Member
    Jul 26, 2010
    1,658 (0.82/day)
    732
    Philly
    Howdy Mussels, long time no see. I see your avatar hasn't changed much :D
    Could you use something like plop boot manager?
    You might be able to get it to load from an SD card using plop boot instructions:
    Dunno if it'll work, but it is easy to try.
    Personally I'd grab a soldering iron and get to fixing the primary drive connection. ;)
  3. Mussels
    Oct 6, 2004
    44,264 (10.68/day)
    11,432
    Australalalalalaia.
    the primary port has no visible damage, so i cant fix it. its just that the damned BIOS wont see a hard drive in the DVD bay, while it shows the DVD drive itself fine. stupid limitations.
    turns out the SD reader isnt bootable, but a regular USB stick is. so thats the plan for now.
    will try your suggestions.
  4. temp02 New Member
    Mar 18, 2009
    493 (0.20/day)
    166
  5. Mussels
    Oct 6, 2004
    44,264 (10.68/day)
    11,432
    Australalalalalaia.
    that could work, i'm just new to alternate boot loaders. the one streetfigher linked to is umm... complicated. i'll see how grub goes.
    edit: the links from that page dont seem to work, and they mention files from other sources without links or even naming them.
    edit 2: theres ANOTHER link down lower, for windows users XD
    edit 3: and that method requires you to boot into windows, which i cant do.
  6. streetfighter 2
    Jul 26, 2010
    1,658 (0.82/day)
    732
    Philly
    It's not that bad, but I've never tried it with loading onto a USB or SD so I don't know if it will work.
    Just follow the instructions here. In brief:
    1. Format USB drive as fat32
    2. Download zip
    3. Copy plpbt.bin to the FAT formatted drive.
    4. Run "plpmkboot" with the USB drive letter, ie:
      Code:
      plpmkboot F:
    Let me know if it works :D
    Mussels says thanks.
  7. Mussels
    Oct 6, 2004
    44,264 (10.68/day)
    11,432
    Australalalalalaia.
    step 4 is what throws me off. where/when do i run that? is there an exe or batch file i do that with?
    edit: found the exe hiding in a folder. will figure it out.
    edit 2: it loaded, but god is this a weird manager. half the time it sits on a blank screen with a blinking A, and a menu flashes up. so far no luck booting windows from it.
    edit 3: well duh, i formatted the drive earlier and didnt install windows on it. no wonder it didnt load into windows XD doing that now.
  8. Mussels
    Oct 6, 2004
    44,264 (10.68/day)
    11,432
    Australalalalalaia.
    it worked! bahahaha. the USB shows as "HDA" while the drive is "HDB" so all i need to now is automate it loading from Hard Drive B.
    streetfighter 2 says thanks.
  9. Mussels
    Oct 6, 2004
    44,264 (10.68/day)
    11,432
    Australalalalalaia.
    bumping because i got around to repairing the CPU fan, and now this laptop works just fine ;)
