Lian Li Announces EATX Supported Chassis with Front Placed PSU - PC-V750
Discussion in 'News' started by btarunr, Jun 25, 2012.
  1. btarunr
    29,156 (10.93/day)
    13,806
    Lian-Li Industrial Co. Ltd, today announces a brushed aluminum EATX supported chassis with a front placed PSU – PC-V750. With the power supply placed in the front, the PC-V750 can hold the hardware that enthusiasts desire while keeping a smaller footprint.
    Shorter than most EATX supporting chassis, the 440mm (17.32”) tall PC-V750 can hold up to six 3.5” hard drives with hotswap capabilities in the HDD cage with one 2.5” at the bottom of the cage. Two more 2.5” drives can be installed if only four 3.5” drives are in the cage.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    For users who don't want an optical drive, an additional 3.5” drive can be put in the 5.25” bay. Two more 3.5” or three more 2.5” hard drives can be placed on the floor on the chassis adding even more storage potential.
    Under the HDD bay a standard ATX power supply can be comfortably placed. A pre-routed cable for the power supply wraps around behind the motherboard tray for plug access in the rear of the chassis. The PC-V750 provides ventilation slits underneath the PSU with a removable pull-out filter to help increase the life and performance of the power supply.
    The PC-V750 has ten expansion slots for future upgradeability. Graphics cards up to 380mm in length can fit, and an arm helps to support longer cards.
    Five well-placed fans keep your hardware at optimal operating temperatures. Two front 120mm fans blow cool air directly on the HDD rack. Dual top 120mm and one rear 120mm fans keep the cool air circulating throughout the case by pulling hot air out of the chassis. Additionally, the Lian Li PC-V750 supports water cooling with two rubber grommet holes.
    On the front I/O panel there are two USB 3.0, one USB 2.0, one e-SATA and HD audio ports providing high connectivity capabilities.
    Because details are important, this elegant brushed aluminum chassis has many features that DIY builders can appreciate such as easy-to-remove pop-off panels for simple installations and upgrades and sturdy aluminum feet with rubber bottoms to reduce vibrations.
    The PC-V750 comes in three varieties: silver (PC-V750A), black (PC-V750B), and internal black with a side panel window (PC-V750WX).
    [​IMG]
    cadaveca and Sir B. Fannybottom say thanks.
  2. Sir B. Fannybottom
    Sir B. Fannybottom
    Jun 4, 2011
    2,980 (2.24/day)
    1,244
    When you said front mounted psu I thought it was going to look retarded with a cae sticking out the front, but this looks kinda cool.
  3. entropy13
    entropy13
    Mar 2, 2009
    4,985 (2.31/day)
    1,225
    It'll probably be at least $250...
  4. Totally
    Nov 21, 2010
    80 (0.05/day)
    13
    Right where I want to be
    Don't see a the point of this case compared to their other offerings. Lot's of cons, too few, if any pros.
    nleksan says thanks.
  5. Vancha
    Jun 18, 2010
    360 (0.21/day)
    62
    I reckon the guys over at Lian Li are just really, really bored.
  6. Shinshin
    Sep 20, 2010
    79 (0.05/day)
    10
    I was puzzled at first, but the design is really nice.
    The point of this is that you can fit EATX motherboards in a smaller case than was possible before....
  7. Comenius
    Comenius New Member
    Jan 27, 2012
    7 (0.01/day)
    0
    Why do Lian Li press releases never mention when their products will be available for sale?
  8. Totally
    Nov 21, 2010
    80 (0.05/day)
    13
    But if you are going EATX, a compact case isn't going to be what you are looking for, and cooling options are going to be very limited.
  9. blibba
    blibba
    Oct 10, 2009
    834 (0.43/day)
    184
    Oxford, UK
    Aren't those front intakes just going to take in hot air from the PSU exhaust?
  10. Jizzler
    Jizzler
    Aug 10, 2007
    3,488 (1.28/day)
    656
    Geneva, FL, USA
    Very nice, another win for Lian-Li!
    Front panel buttons/ports centered, black interior/window options, nice use of space, 10 slot, simple and clean exterior styling.
  11. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.73/day)
    639
    Wangas, New Zealand
    Nothing reminiscent of a transformer.
    I like it.
    Wrigleyvillain says thanks.
  12. radrok
    radrok
    Oct 26, 2011
    2,991 (2.52/day)
    803
    Italy
    Brushed Aluminum <3
  13. Bjorn_Of_Iceland
    Bjorn_Of_Iceland
    Jan 2, 2008
    3,178 (1.23/day)
    376
    deym, I want one
  14. sc
    Mar 18, 2012
    77 (0.07/day)
    17
    Why can't they make a case designed with a real life scenario in mind?
    I am sure there are a lot of people like me that use NAS and don't give a damn about the gazillion 3.5" bays all the cases seem to have nowadays.
    For example I don't need more than two 3.5" bays (SSDs and HDD) but I could use two 5.25" bays for a reservoir/fan controller/whatever, a proper mounted PSU and space to mount a few rads or fans if I were to go on air.
  15. csendesmark
    csendesmark
    Mar 11, 2008
    345 (0.14/day)
    24
    Awwh!!! Very nice case! I love it :)
  16. radrok
    radrok
    Oct 26, 2011
    2,991 (2.52/day)
    803
    Italy
    You know, many cases are modular, especially premium ones like Lian Li... I'm pretty sure you can remove those bays and put a radiator on the front.
  17. theJesus
    theJesus
    Jul 20, 2008
    3,979 (1.67/day)
    865
    Ohio
    I think you're wrong. I'm sure there are people who would like to go EATX, but don't want a large case.
  18. Jacez44 New Member
    Apr 29, 2012
    35 (0.03/day)
    6
    Givatayim
    Can hold 6 HDD's SAFELY. SAFELY, Damnit.
    I can fit 16 in there with aftermarket/DIY brackets..
  19. Assimilator
    Assimilator
    Feb 18, 2005
    637 (0.18/day)
    109
    South Africa
  20. rpsgc
    rpsgc
    Feb 9, 2007
    698 (0.24/day)
    133
    Portugal
  21. fochkoph
    fochkoph
    Nov 23, 2008
    151 (0.07/day)
    13
    Fremont, CA
    I really hate their windows.
  22. theJesus
    theJesus
    Jul 20, 2008
    3,979 (1.67/day)
    865
    Ohio
  23. Vancha
    Jun 18, 2010
    360 (0.21/day)
    62
    [​IMG] ...but it's too late. I've seen everything. I've seen it all.
  24. micropage7
    micropage7
    Mar 26, 2010
    6,279 (3.55/day)
    1,465
    Jakarta, Indonesia
    [​IMG]
    so the psu push the hot air to the front
    interesting :D but it would affect the intake air although a little
Share This Page
