little problem with my HD 4850, HELP please.
CH@NO
901 (0.15/day)
Toluca, Mexico
System Name Thank God you're back!!!
Processor Intel Core i3 2100 @ 3.1GHz (stock)
Motherboard ECS H67H2-M3
Cooling Stock + 1 X 80mm Thermaltake red LED
Memory 1 X 4 GB Kingston 1333MHz DDR3
Video Card(s) coming soon
Storage 1TB Seagate SATAII + 500GB Hitachi USB (External)
Display(s) Samsung 20" LED Widescreen
Case coming soon
Audio Device(s) Onboard Realtek HD 6ch Audio
Power Supply Generic 450W with 20A on the 12v+ rail
Benchmark Scores coming soon
Hi.
The card arrived today, I uninstall the drivers of my 8800GTS, and run DriverSweeper, then install the new Catalyst drivers (9.4 for XP x86)
The installation showed zero probs, but when the system restarted a window saying that the system find a High Definition Audio Device appeared, then I cannot install the device.
Everest show that my card came with a RV770 High Definition Audio Controller, I suppose the audio device that refuse to install is this since under the "audio devices in device manager" doesn't show any Rv770 Audio device.
The card is a Sapphire HD 4850 that comes with DVI/HDMI/VGA connectors.
The card seems to work ok, even I OCKed it already and runed FurMark just fine, I didn't tried 3DMark06 yet, but ATM didn't show any artifacts or stability issues.
So the question is HOW I can install the RV770 Audio Controller or WHY I cannot install the device???
Also, for what purpposes is the RV770 Audio device???, I suppose is for the HDMI interface but I'm not sure.
HELP PLEASE!!!!
Deleted member 24505
When mine did that on vista,i just went to device manager,and right click the hdaudio device and select update driver from the internet.It should install with the driver package though.
CH@NO
901 (0.15/day)
Toluca, Mexico
Case coming soon
I'm using XP, so updatin the driver via internet isn't available via device manager.
The card ran just fine 3DMark06, the audio device of the card could be damaged???
and again, It only serve for the HDMI interface or what???
1,041 (0.18/day)
Transylvania (RO) working in Barcelona (ES)
System Name Rzyen X
Processor Ryzen 7 7800X3D ^ PBO -30 ECO mode 1.15v SOC
Motherboard Gigabyte B650 Gaming X AX
Cooling Arctic Liquid Freezer II 420 A-RGB
Memory 32Gb Adata Lancer XPG 6000Mhz CL30 EXPO 1.260v
Video Card(s) Sapphire RX 7900 GRE Nitro+ OC - core 2800Mhz / mem 2600Mhz
Storage 1TB WD SN850X + 2TB WD SN770 + 2TB Adata Legend 850
Display(s) ViewSonic ColorPRO VP2776 - 27" 1440p^165Hz
Case Phanteks P600S White
Audio Device(s) Logitech Z2300 + Skullcandy Crusher Evo
Power Supply EVGA T2 1000W Titanium
Mouse RedDragon M686 RGB
Keyboard SPC GK630K Tournament
Software Windows 11 PRO
Benchmark Scores CB R23 - 18.703 pct / CB 2024 - 1.159 pct
5,214 (0.87/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
2,318 (0.41/day)
Texas
System Name Mr. Reliable
Processor Ryzen R9 5950x
Motherboard MSI Meg X570s Ace Max
Cooling D5 Pump, Singularity Top/Res, 2x360mm EK P rads, EK Magnitude/Alphacool Blocks
Memory 32Gb (4x8Gb) Corsair Dominator Platinum 3600Mhz @ 16/19/20/36 1.35v
Video Card(s) MSI 3080ti with Alphacool Block
Storage 2 x Corsair Force MP400 1TB Nvme; 2 x T-Force Cardea Z340; 2 x Mushkin Reactor 1TB
Display(s) Acer 32" Z321QU 2560x1440; LG 34GP83A-B 34" 3440x1440
Case Lian Li PC-011 Dynamic XL; Synology DS218j w/ 2 x 2TB WD Red
Audio Device(s) SteelSeries Arctis Pro+
Power Supply EVGA SuperNova 850G3
Mouse Razer Basilisk V2
Keyboard Das Keyboard 6; Razer Orbweaver Chroma
5,214 (0.87/day)
Software Win 11 Pro
Were here to help. Ya gotta be quick when your a natural helper:D
CH@NO
901 (0.15/day)
Toluca, Mexico
Case coming soon
the direct link doesn't work but I downloaded in the main site of ATi.
Didn't knew that using XP needs an extra driver for the HDMI interface, after all this is my first VGA that comes with a dedicated HDMI port though.
MANY thanx for the help, the problem is now fixed.
TPU ROCKS!!! :toast::toast: :rockout::rockout: :respect::respect:
CH@NO
901 (0.15/day)
Toluca, Mexico
Case coming soon
