Low Gaming FPS after SSD AHCI
74 (0.02/day)
Processor i3 4160 @ 3.60Ghz
Motherboard ASUS B85M-E/BR
Memory 2X4GB Crucial Ballistix Sport 1600Mhz
Video Card(s) GALAX 1060 3G
Storage Samsung 840 Evo 120gb / Seagate 500GB
Case Thermaltake M9
Mouse Multilaser MO206
Hey guys,
Yesterday i installed as main Storage Samsung 840 EVO 120GB. Putted on it World of Warcraft OS and KIS2015.
I followed the instructions of turn off the page file and change from IDE to AHCI.
So after that i ran WoW to check if will Load Screen faster.
But actually was much more slower than the mechanical one.
And the WoW was running about 10fps.
I have no idea why.
Some people said: SSD doesnt have anything about with the VGA.
Why low fps so?
I ran the DXDIAG and to my surprise it says i have about 5gig on VGA. What?!?!? My MSI R5770 Hawk only has 1024MB. Not 4850 MB.
What just happened? I already unistalled the VGA driver and installed again. Keeps the same.
MY PC SET
MOBO: ASROCK H55M-LE
CPU: I7 860 @2.80GHZ
MEMORY: 2X4GB CRUCIAL BALLISTIX SPORT 1600MHZ
VGA: MSI R5770 HAWK 1GB GDDR5
MAIN STORAGE: SAMSUNG 840 EVO 120GB
SECOND STORAGE: SEAGATE 500GB
Here are the log from DXDIAG:
System Information
Time of this report: 1/13/2015, 14:48:16
Machine name: KÁBELINS
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_r3.140827-1500)
Language: Portuguese (Regional Setting: Portuguese)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz (8 CPUs), ~2.8GHz
Memory: 8192MB RAM
Available OS Memory: 8184MB RAM
Page File: 4405MB used, 3777MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
Display Devices
Card name: AMD Radeon HD 5700 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x68B8)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV_68B8&SUBSYS_21401462&REV_00
Display Memory: 4850 MB
Dedicated Memory: 1010 MB
Shared Memory: 3840 MB
Current Mode: 1360 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: SyncMaster
Monitor Id: SAM0598
Native Mode: 1360 x 768(p) (60.015Hz)
Drive: D:
Free Space: 0.1 GB
Total Space: 0.1 GB
File System: NTFS
Model: ST500DM002-1BD142
Drive: E:
Free Space: 364.4 GB
Total Space: 476.8 GB
File System: NTFS
This posabovet isnt going to do anything for you. Its best to leave the ssd alone when you install a fresh os on it, dont touch the paging file (no need to in w7-10). Also if you had a hdd plugged in as a second drive during windows install it has a tendency of putting boot files on secondary drive.
Ahci should be enabled before any os is installed
Friend, use [*code] tags when putting that much information in... holy crap (reported the post so the mods will hopefully do it).
As eider said, leave the page file alone. Put a fixed size on it is the only change I would make (make it 2048 or 4096MB is my suggestion).
Ok but i'm concerned about the VGA.
Weak CPU and weak GPU on CPU limited game = poor FPS.
Typically an SSD has nothing to do with your VGA, true. However, if you are playing an MMO, like WoW, and it loads from your HDD, it can cause significant hitching.
Forgive me, I deleted most of the original post, it was unnecessary and would probably actually stop some people making the effort to help.
Hey guys,
System Information
Memory: 8192MB RAM
Display Devices
when you have more ram on board its just sharing with gpu
Don't turn the pagefile off, but put it on a HDD and let Windows manage it.
As others said, it's better to have AHCI enabled before you format. There is a way to make it work anyway by changing some registry keys, but the best way is still to just format with AHCI enabled.
What just happened?
It says 4850MB because it did math, 1010MB (VRAM) + 3840MB (Shared Memory) = 4850MB. Your card really has 1GB of ram, it is normal and fine.
Some programs need a page file to run correctly due to the way they were programmed, turn it back on but make sure it's size is not too large.
I may sound like an asshole on this but tbh you screwed big time.
No way in hell would i believe that 5770 and an i7-860 would run World of warcraft at 10 frames or less, that's not possible. I've checked a review of your gpu and it can even run crysis at a decent fps.
Here's the thing - WoW can be ran even on toasters, it even ran well back when i had something like Pentium 4 single core at 3.0 ghz, 512 ram and a 8600 gt with 256 mb memory.
Simple advice - get someone who knows what the hell he's doing, because clearly, you, do not.
Bad prOn site got ya maybe? j/k. 4g of ram. Is that really enough for your rig? 8g is the norm in '14/'15.
I formated the SSD this time with AHCI enabled. Now the system is much more faster. By default my gpu is 850Mhz Clock and 1200Mhz other stuff. I installed the MSI afterburner and it says everytime i minimize WoW i the 850 goes to 300Mhz and the 1200Mhz goes to 400Mhz. It seems to me a "sleep mode" when the game is minimized. What i realize i had to remove the GPU in order to set the sata cables. Is there any possibility of this screw up the GPU? When i said that the 4850MB of GPU this info wasn't there before i installed the ssd. I believe somehow after doing this process of removing the gpu or power cord and put back again, may screwed stuffs. Is that possible?
Just to be clear, before installed the ssd, with graphic on recommended (good) the game was about 50-60fps, 4x Anisot and everything else on good.
After formated i didn't change this one. It remains original (Automatically)
I know. I think that happened after i remove gpu and put it back.
Oh thanks, didn't know that. My memory last week was 2x2gb, now is 2x4gb.
That happened after removing the gpu and put it back. Should i try again?
The performance looks like the games are running onboard. But the VGA are pluged on the gpu. That's why i thought weird the shared memory.
have u tried display onboard gfx in your bios and then see if WoW will use your AMD card?
Run GPUZ
the HD 5770 has 3 different power modes and will throtle up and down as required.
REREAD what has already been posted.
Nope. I can only check that 5 hours from now. If that wasn't the problem what else could be? ( I don't want to be without alternative after doing you advise)
This here should "force" Windows to only use ur AMD card, if it don't there is something else wrong.
i never used Intel onboard graphics on a desktop pc at home before i got my small test box, so i always disabled onboard, when using a graphic card in my pc's like with my gaming rig have a GTX 970 and i disabled onboard.
Run GPUZ
Nothing new after rereading. Already answered all. I'll install GPU-Z again and after have the results. I'll post here.
Understood.
Use radeon pro to max certain cards clocks so they dont drop speed while gaming
Seriously... use the EDIT button instead of quadruple + posting man... my god.
It's not as CPU limited anymore. WoD put a lot of the load on the GPU.
Please learn to edit your posts or use the multi quote feature like I have done here. There is no need for a quadruple post like what you did.
My bad! :(
My bad! :(
My bad! :(
Run GPUZ
Ok. I got the gpu off, remove all cables and put back again.
Problem solved (-.- )
No idea why.
Everything fine now. Thanks for all the help.
Perhaps you had a bad connection on the PCI-E connector so not all lanes were connected? Seems unlikely, but I can't think of anything else. Glad it's working. :)
