Low Power consumption (% of TDP) on GTX670
Discussion in 'NVIDIA' started by wolf, Dec 19, 2012.
  1. wolf
    wolf Performance Enthusiast
    May 7, 2007
    5,547 (1.85/day)
    847
    So basically as the title suggests the pwoer consumption shown in GPU-Z as the % of the TDP of the card is always very low, around 30-35% under maximum stress like farcry 3 and MSI kombustor.. rig as shown in specs and 310.70 WHQL. I thought it might have been the beta drivers so I moved to WHQL with no change.
    thoughts? could this be affecting my max oc which seems to be relatively low at right around 1200mhz max boost clock.
    EDIT: I've had it show the max reading after running some MSI Kombustor
    [​IMG]
  2. wolf
    May 7, 2007
    5,547 (1.85/day)
    847
    Bumpity bump, ideas anyone?
  3. Frick
    Frick Fishfaced Nincompoop
    Feb 27, 2006
    11,579 (3.37/day)
    2,917
    Why is it an issue? And based on this I wouldn't say the OC is "relatively low". It's smack in the middle.
    Unless you're having issues i wouldn't worry.
  4. Steevo
    Steevo
    Nov 4, 2005
    9,028 (2.54/day)
    1,632
    TDP is the heat output of a core, Themal Design Power. Its just the amount of total power consumption that is going to be "wasted" as heat to allow proper voltage control
    10 Million points folded for TPU
  5. wolf
    May 7, 2007
    5,547 (1.85/day)
    847
    It's just not what I expected to see, I'd have thought that overclocked it would end up somewhere between 100 and 120% but if it's not an issue thats good.
    I do know what TDP is and what it stands for... still it appears to be incorrect.
    Just needed a couple of opinions is all haha cheeeers
  6. Slizzo
    Slizzo
    Aug 2, 2011
    403 (0.28/day)
    89
    Is the card performing as it should? If it is then forget about what you're seeing.
    wolf says thanks.
Share This Page
