Lowest Power consumption PC with i5/i3
Status
Not open for further replies.
4,180 (1.15/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
May this mini itx
http://www.asus.com/Motherboards/AM1IA/
dont know why they keep giving those outdated old mouse and keyboard connectors.
I agree with Rcoon that an AM1 platform for 1080p videos and web surfing at low power consumption is the best option other than a laptop. If you factor in price for a machine like that its a steal in all honesty.
Try something like this:
Athlon 5350
Asrock AM1H-ITX (Can run off a laptop AC adaptor with that DC in)
Gskill 1600 4gb (2x2gb)
Thermaltake MITX Case
Asus DVD Drive
Sandisk 120gb SSD
That right there is about $300 bucks total for the system and after that you would either grab a small PSU or just a laptop style ac adaptor to run it for about 50 bucks more. Won't get much more low voltage than that.
MxPhenom 216
ASIC Engineer
12,944 (2.61/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
696 (0.17/day)
India
System Name To be ALL IN ONE MACHINE. but not yet
Processor i7 3770k
Motherboard Asus P8Z&&-V Deluxe
Cooling Thermalright Silver Arrow
Memory Gskill Ripjaws 1600Mhz 8GB *4 = 32GB
Storage Samsung pro 840 256GB, Segate 3TB and 1TB
Display(s) LG 23" Full HD LED
Case Antec LanBoy Air
Power Supply Cooler Master M2 Silent Pro 850 Watts
Software Windows 7 ulimate 64bit
Hi Michael,
See http://www.silentpcreview.com/forums/viewtopic.php?f=28&t=64394 for an idea of what is possible. Have search around the web and I think that you will find that the idle power consumption of an 3770K is about the same as an i3 or i5 so I guess that the rest of your system is what is drawing power. If were to put up you system specs I may be able to pinpoint.
Mark
here it is..
4,180 (1.15/day)
Texas
Mouse Logitech G5
Are you wanting to reuse parts from your rig or start from scratch with this low power system? Either way you can save the SSD and HDDs and slap them into your new system and it will be still low power with extra storage and save some bucks.
4 (0.00/day)
At a first guess without doing a websearch, which you can do yourself if you want, the motherboard maybe consume quite a lot because the model name suggests lots of bells and whistles which as well as being a Z chipset will all add up. Intel boards tend to have the lowest consumption - you may be able to sell your ASUS for not much less than buying a new Intel - do check what features you want and reviews before changing. For surfing you probably only need 8GB of RAM as long as you have your browser configured properly (e.g. Firefox with Adblock Plus) and don't have crazy numbers of tabs open; each stick of RAM might use 2W. If you go too low on RAM you might end up swapping data onto your HDD which will make things worse. You might try to manage with only one of you HDDs in use normally, with the other in a caddy to be used if you need to, as these might be using approx 5W or more each (http://www.silentpcreview.com/article29-page2.html) - as GhostRyder indicated the Samsung PRO is probably the most efficient SSD out there - at least in 2.5inch form factor. If the PSU is this one http://www.techpowerup.com/reviews/CoolerMaster/Silent_Pro_M2_850W/5.html then that may be adding another 5 Watts at low loads especially with it being a 850W model. The Cooler Master V550S seems to be the most efficient ATX PSU at the moment, for web surfing and not bad for gaming. So a good number of things to try before you spend any money or embed more carbon by buying new stuff - for an experiment try removing your both of your HDDs and three sticks of RAM to start.
newtekie1
Semi-Retired Folder
28,472 (4.25/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I just built a AM1 Athlon 5350 machine. During HD playback it averages 20w, under full load with OCCT is stays under 30w. I say go for that.
696 (0.17/day)
India
Processor i7 3770k
First of all thanks for your detail explanation.
No, I will not remove anything from these machine this is my favourite machine , it also has 11 tri LED 120mm fans, red led tube below the case and green strip led around inner border of case with individual power off options with remote switch ON/OFF more to add to this. I would be curious to know how much watts that motherboard eats....?
(Have we ever come across i7 3770/3770k with minimal watts operating with some kind of lower end boards..?)
I wonder if hard disk really takes extra watts because whenever I click on say, 1 TB disk it takes time to open , seems that it gets activated or so and gets/consumes more power.
Yes I am sure my 850Watt PSu eats more watt but I have no options as I am having lot of, lot of lightings on my case which requires more connectors.
I also used to use APC 1500 Pro UPS which now just resting in side of table idle as it used to bring huge bills when connected.
I thought You will be pointing towards some BIOS setting which will result in some low wattage.
Thanks for your detail reply. (hey you joined today only....... :D :toast:)
696 (0.17/day)
India
Processor i7 3770k
I just built a AM1 Athlon 5350 machine. During HD playback it averages 20w, under full load with OCCT is stays under 60w. I say go for that.
Yeah! Could you be so kind to share your whole system specifications with 5350 please? What is OCCT ?
Thanks.
696 (0.17/day)
India
Processor i7 3770k
No, as I said below this is my mod case.
696 (0.17/day)
India
Processor i7 3770k
Athlon 5350
Asus DVD Drive
Sandisk 120gb SSD
Thanks for specs:-
I have some questions:-
1.Can we put wireless Lan card for wifi in that big PCI slot ?
2. Is 120GB SSD enough though it is cheap about RS. 6000 =$ 100 , I think installed Win 7 64 bit takes more than or close 120GB (my current system takes this much) on 256 SSD) for installed space . ?
3. Can you play 4 youtube 1080p videos at same time on different tabs?
4. Can you play 15GB to 20GB movie file on it without any lag ?
Thanks.
Mussels
Freshwater Moderator
58,413 (8.21/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
mobos vary a lot - with a higher overclock and more powerful hardware, my brother uses 30W less at idle due to a more efficient/newer chipset mobo.
HDD's use 5-12W (or zero if powered down)
all those LED's use 1-2W each, maybe 5-10W for a CCFL.
3770/3770K arent high wattage. with undervolting you can get them <50W at load.
696 (0.17/day)
India
Processor i7 3770k
300 (0.08/day)
Delhi India
Processor Ryzen 1700 (3.75 GHz)
Motherboard Asus ROG STRIX B350-F GAMING
Cooling Corsair Hydro H100x + 3x120MM fans
Memory 32 GB Corsair Vengeance LPX 3600Mhz @3000MHz (CL16)
Video Card(s) Asrock 6600XT 8GB
Storage Samsung 960 EVO 250GB Nvme + 2TB HDD + 2 x 1TB HDD + 480GB Crucial MX500 SSD
Display(s) Acer Nitro VG270P IPS 27 inch 144 Hz - Full HD
Case Deepcool Dukase v3
Audio Device(s) On Board
Power Supply Corsair 600X
Mouse Logitech mx 518
Keyboard Logitech K230
Thanks for specs:-
Thanks.
If u are living in Delhi; it would be hard to find an Asrock board. only Asus and Gigabyte boards are available.
1. You can get a WIFI card PCIE1X (Rs. 750 ~ 12$) for the Asus board i recommended earlier. its about RS. 2850 ~ 48$ for the board on ebay.
2. 120GB is enough. Just disable the hibernate. Try Samsung 120 EVO it costs Rs. 5500 ~ 92$
3. Get a single 4GB RAM as the processor support only single channel.
4. will be able to answer the 3rd and 4th points after 4-5 days when i get the motherboard.
Mussels
58,413 (8.21/day)
Oystralia
  • Like
Reactions: xvi
12,062 (2.77/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Thanks.
3. Probably, I haven't tried it, because it's a fairly impractical a stupid thing to do.
4. Yes, I watched Desolation of Smaug bluray and Captain America in the last week on my friend's (SSD'd) 5350 machines just for kicks.
With the correct codecs utilising the full APU, it runs at around 40% during Bluray playback.
4,180 (1.15/day)
Texas
Mouse Logitech G5
Thanks for specs:-
Thanks.
1: yes
2: windows install takes like 12gb roughly off the top of my head (Don't really pa attention to the size much). If you need more space, just get the next size up.
3: don't see why not? But I don't see why you would do that lol.
4:yes
newtekie1
Semi-Retired Folder
28,472 (4.25/day)
Indiana, USA
Bo$$
Lab Extraordinaire
5,656 (1.04/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
Give example/numbers of AM1 chips please.
Edited:-
are these you talking about?
View attachment 58333 View attachment 58334
Ohh they run on 25 watts...? G2020 need 55 watts as per specifications.......
Thanks.
5350 + Asus AM1 motherboard is the way to go.
got 2.5GHZ with a Volt increase, this increased temps by like 2 degrees.
Plays HD video with ease with only 14% cpu usage
696 (0.17/day)
India
Processor i7 3770k
No just try it, sometimes browser gets hang, I do this normally when I need to see all reviews one by one on one product, sometimes it takes time to get streamed so I open all in one attempt. then watch first then 2nd and so on or select which one is best to watch......
Frick
Fishfaced Nincompoop
18,914 (2.86/day)
Piteå
System Name Black MC in Tokyo
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
So you are not watching them at the same time.
Mussels
58,413 (8.21/day)
Oystralia
in which case he wants to buffer four videos at the same time, which 100% comes down to his local network and internet connection.
696 (0.17/day)
India
Processor i7 3770k
Guys, Please excuse me for possible lengthening of this topic.. But I have some new interrelated query for you all, as the latest information shows as below,( yes AMD AM1 chip looks good but I see more options) :-
http://www.asrock.com/mb/Intel/H81TM-ITX R2.0/?cat=CPU
Is this xeon E3-1220LV3(C0) available in market, being xeon and just 16W and that too with this motherboard looks great... this might just be useful for me to keep some virtual machine online all the time. Can you all have you comments and suggestion about this please...?
Thanks a lot.
Mussels
58,413 (8.21/day)
Oystralia
performance might be a bit weak at 1.6Ghz. you could achieve that by underclocking and undervolting any CPU.
866 (0.25/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
well seeing that you still are considering your build i found some more info on the intel NUC power consumption that i suggested earlier. also i think the celerons are even lower haven't checked yet but i would think they are.
http://www.anandtech.com/show/7566/intels-haswell-nuc-d54250wyk-ucff-pc-review/6
27.02 watts with load
6.84 watts idle
the NUC is good for everyday web surfing and low setting gaming (if you dont mind). i have a 3rd gen i5 nuc i use at my bros place with one of his spare monitors, mouse and keyboards.
Status
