Lowest Power consumption PC with i5/i3
Discussion in 'General Hardware' started by michael, Aug 11, 2014.
Thread Status:
Not open for further replies.
  1. Toothless
    Toothless
    Mar 26, 2014
    2,286 (4.37/day)
    1,449
    Bremerton, WA
    I might be able to test one out tomorrow. We have a ChromeBook that isn't used so I'll check it out in the morning.
    Crunching for Team TPU
  2. michael
    michael
    May 2, 2013
    621 (0.73/day)
    15
    India
    Hi Guys,
    Thanks a lot for your replies. I am just about to order Intel Celeron N2820 .
    Just I want to know about below stuff:-
    1. Which RAM should I use in order to stick to Low Watt system? Will 8GB beneficial or useful on such system?
    Specs Given:-
    SYSTEM MEMORY
    • One DDR3L SO-DIMM slot for memory expandability
    up to 8 GB
    • 1.35V, 1333/1600 MHz (down clocked to 1066 MHz)
    2. Hard disks
    Is there any SSD which comes with 3 Gb/s speed ? What if I connect Gb/s speed SSD ?
    Specs Given:-
    1x SATA port (3 Gb/s) for internal support
    for 2.5¨ HDD or SSD
    Edited:-
    What if i connect this SSD 6 Gb/s
    It also saying "
    • Ultra Low Power Consumption for Longer Battery Life" in it's description.
    http://www.snapdeal.com/product/samsung-840-series-120-gb/1412846#bcrumbSearch:|bcrumbLabelId:283
    Please advise.
  3. Recca29
    Mar 19, 2014
    155 (0.29/day)
    208
    Delhi India
    Why not a Intel Celeron J1800?
    1. 4GB ram is enough
    2. No issue when u connect a SATA 3Gb/s device to a SATA 6Gb/s or the other way around.
    michael says thanks.
  4. michael
    michael
    May 2, 2013
    621 (0.73/day)
    15
    India
    No way man... I did read all about these. but decide against it as it would require SMPS....:banghead::banghead::banghead:
  5. Recca29
    Mar 19, 2014
    155 (0.29/day)
    208
    Delhi India
    won't a Intel Celeron N2820 require SMPS?
    How will You power it?
  6. michael
    michael
    May 2, 2013
    621 (0.73/day)
    15
    India
    It takes small adaptor..... and not that box type SMPS.
  7. Recca29
    Mar 19, 2014
    155 (0.29/day)
    208
    Delhi India
    So basically you are buying a NUC with Intel Celeron N2820.
    great.:toast:
  8. michael
    michael
    May 2, 2013
    621 (0.73/day)
    15
    India
    Certainly yes.
    There are various types of system we can choose from which I learnt about from these thread:-
    1. Intel Celeron NUC N2820 (Good PC and can handle day to tasks with 1080P 13watts max.)
    2. AMD AM1 with with AC adaptor compatible motherboard (Lowest AMD PC max 25 Watts)
    3. Intel Celeron J1800 the one you specified but it would require Mini ITX box with box size SMPS.
    4. Intel NUC i5 model, I guess, this is "too must" have for all as this is more powerful and less size, bit expensive with all req. parts though.
    My idea is to have Intel NUC N2820 and hook it up behind 23" LED monitor (max 18 Watts) so combine desktop using experience won't cause me more than 30 Watts in total more over I can use it as All in one PC too.
    In short my total power consumption should not exceed 25 - 30 Watts.
    xvi and Recca29 say thanks.
  9. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    21,594 (6.05/day)
    7,492
    I just set up a laptop with an N2830(faster than the N2820), and it was super slow.
  10. Garage1217
    Garage1217
    Aug 26, 2012
    255 (0.23/day)
    180
    Az
    Just chiming in a 2nd, 3rd and more time for the 5350 AM1 even though it looks like you made a choice :) Just built a similar power sipper and I am very pleased for a basic surfing / streaming business machine. And surprisingly it is quite snappy - quick for a budget non gamer.
    http://www.techpowerup.com/forums/t...ni-itx-desktop-build-business-machine.204060/
    On another note, if you run the maths the difference between 25w and 15w used 10 hours a day at an average of .11 cents per kwh is only $4.01 a year :D
    $10 total electric cost rounded per year for the amd
    $6 total electric cost rounded per year for the Intel
    Your current setup if using 88w used for 10 hours a day at .11 pkwh is only costing $35 rounded a year so really not all that much. Or at 109w 10 hours a day equals just $44 rounded a year.
    Do you have crazy high electrical costs in India?
    Good review / Comparison AM1 vs Intel competition. AM1 is considerably better for a lot of things such as multimedia, offers 6gbps sata and more. Smarter low power choice IMO
    http://us.hardware.info/reviews/533...l-d-review-cheap-desktop-platforms-conclusion
    Comparison.. 5350 even being low end wipes the floor with a N2820
    http://www.cpubenchmark.net/compare.php?cmp[]=2195&cmp[]=2145
  11. xvi
    xvi
    Nov 10, 2006
    3,138 (0.98/day)
    2,830
    Washington, US
    ..but that's nearly twice as much! :laugh:
  12. GhostRyder
    GhostRyder
    Apr 29, 2014
    2,364 (4.84/day)
    1,201
    Texas
    But its much more powerful lol
    He has made his choice it sounds which should suffice for what he's wanting to do.
    xvi says thanks.
  13. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    43,533 (10.94/day)
    10,716
    Australalalalalaia.
    we'll find out sooner or later. this thread reminded me to go power test my new laptops wattages.
  14. james888
    james888
    Jun 27, 2011
    5,287 (3.47/day)
    2,640
    I may be saying something redundant because I only read the first page and the last page of this thread. You say the intel g2020 uses 55w but that is tdp now power usage. By g1620 uses 14w according to hwinfo, which I can confirm is pretty darn close using my kill-a-watt wall meter. I have even undervolted it enough where it will use 8w according to hwinfo.
  15. Garage1217
    Garage1217
    Aug 26, 2012
    255 (0.23/day)
    180
    Az
    Just running some general measurements on the AM1H-ITX mobo and 5350...
    - Idle is 19-20w
    - General usage 22-25w (browsing and so forth)
    - Streaming Netflix 28 - 32w
    No undervolting. I could undervolt the ram but no options for the cpu with this mobo. So with my combo - it is what it is.
  16. Mussels
    Oct 6, 2004
    43,533 (10.94/day)
    10,716
    Australalalalalaia.
    I just tested my i5 laptop
    Intel i5 3210m (35W TDP), 8GB 1600MHz ram, 60GB intel 520 SSD, not sure if its running the intel IGP or AMD GPU at idle, tbh.
    11W idle (screen off)
    13W idle (screen on)
    1080p, H264 10bit video file, streamed over wifi N 150, software decoded via CCCP and LAV filters - 21W.
    so you know, the TDP numbers dont tell the whole story.
  17. Garage1217
    Garage1217
    Aug 26, 2012
    255 (0.23/day)
    180
    Az
    Good info and low power! Had me curious as to my I5 laptop as well. A dell E6420. It has a lil 2540M cpu. Just tested with the battery at 100% / wifi ON / Screen at 100% / 180gb corsair gt SSD / 8gb 1600 / current drivers / Keyboard on dim / in performance mode as I keep it all the time
    - Idle is 16-17w
    - General usage 25-27w (browsing and so forth)
    - Streaming Netflix 28 - 30w
    - When charging 45-46w (just verified it on my wifes dead 6420)
    Overall much better than I suspected. And the 2540 wipes the floor with the 5350 as anyone would figure
    http://www.cpubenchmark.net/compare.php?cmp[]=812&cmp[]=2195
  18. Recca29
    Mar 19, 2014
    155 (0.29/day)
    208
    Delhi India
    My current system running ~10 hrs daily costs $13-15 a month.
    So the electrical costs is a little high. ~8cents per kwh.
  19. Garage1217
    Garage1217
    Aug 26, 2012
    255 (0.23/day)
    180
    Az
    8 cents US? Wow... Ouch.
  20. Mussels
    Oct 6, 2004
    43,533 (10.94/day)
    10,716
    Australalalalalaia.
    Thats low - we pay about 25-30c per KWH here.
  21. james888
    james888
    Jun 27, 2011
    5,287 (3.47/day)
    2,640
    I pay less than a penny per KWH with all this cheap hydro power around me.
  22. xBruce88x
    xBruce88x
    Oct 29, 2009
    2,516 (1.18/day)
    756
    im on a fixed budget for my electric. its about $200 a month, however its split by my other room mates. This includes the cost of running 3 window unit A/C systems, 2 are 5000btu and one is 12000. and in winter we use a lot of electric space heaters 3-4 of them each about 750-1500w (i like the quartz ones), though i only use them in the rooms i happen to be in at the time, sometimes I open the oven (gas). no central heating and air. we have switched over to the newer CFL lights which has helped a lot. I plan to again switch to LED lighting when it gets more affordable.
    as far as the OP build... an intel NUC unit sounds reasonable, perhaps even an all-in-one based on an intel NUC with a celeron 1900 (the quad core one)
  23. michael
    michael
    May 2, 2013
    621 (0.73/day)
    15
    India
    I didn't get what you are referring to..? :confused:
  24. Mussels
    Oct 6, 2004
    43,533 (10.94/day)
    10,716
    Australalalalalaia.
    that he's using the hardware he mentioned and its slow.
    power efficient doesnt mean fast.
    xvi says thanks.
  25. xBruce88x
    xBruce88x
    Oct 29, 2009
    2,516 (1.18/day)
    756
    in fact power efficient is generally slower... though tech has come far enough that low power devices can be quite powerful performance wise... well more so than they used to.
Thread Status:
Share This Page
