LUXA2 Launches P1 7000mAh High Capacity Battery & Charger
4,784 (1.06/day)
Still on the East Side
LUXA2 announces the launch of their power bank P1 7000 mAh High Capacity Battery & Charger, marking the company's first portable power solution for the iPhone and iPad accessories market. LUXA2's P1 external battery is designed to deliver a portable power solution for Apple device users who are always on-the-go. With a 7000 mAh power capacity, it is a powerful external power source available for iPhone and iPad on the market.
LUXA2's P1 power bank was expertly engineered to provide high output charging in a very compact design. It is also compatible with most USB devices on the market, including the iPad, iPhone and iPod touch. With this power source, you can charge an iPhone 3.5 times from empty to full. You can also charge an iPad from empty to 78% fullness, which will give you 7 extra hours of usage time. Its lightweight and portable design also makes for easy carrying so users never have to go without power.
Key features and benefits of P1 7000 mAh High Capacity Battery & Charger include:
High power capacity
7000 mAh gives you enough juice to charge an iPhone 3.5 times and an iPad 78% from empty to full.
Dual port 1A outputs with rapid charging
P1 has two outputs so you can charge two devices simultaneously. With this ultra portable back up battery, you can enjoy more talk and play time with your mobile device.
iPhone, iPad, iPod touch and USB Device Compatible
Quick charge the iPad, iPhone, iPod and virtually any other USB device or smart phone.
Compact and Ultra-Portable
Design with easy portability in mind, P1 is a powerful back-up battery pack that is also lightweight and small. You can bring it everywhere with you so you can stay powered on-the-go.
4 Light LED Battery Status Indicator
P1 7000 mAh battery takes about 8 hours to receive a full charge. The integrated LED status indicator lets you know how much charge power is remaining.
9,232 (1.65/day)
Montreal, Canada
System Name Homelabs
I like how they make it as if it was an Apple only charger that is specifically compatible with this product and that product. It's a battery/charger that has 2 USB ports that can reach 1A...
Mussels
Freshwater Moderator
58,413 (8.18/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
and high end apple devices like the ipad require 2.1A ports to quick charge...
7000mAh is fantastic, but the 2x1A is just par for the course, and definitely not 'for apple users'
6,471 (1.40/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
Yo_Wattup
788 (0.18/day)
Brisbane, Australia
System Name Desktop/Gamer/Digital Audio Wokstation ||| HTPC
Processor 2500k @ 4.65ghz ||| AMD A8 @ 3.6ghz
Motherboard ASUS P8Z68-V Pro
Cooling Noctua NH-D14 with single Blue Antec Tri-Cool 120mm ||| Stock
Memory 16GB G.Skill Ripjaws X 1600 @1900mhz 8-9-9-24 ||| 8GB G.Skill 1600 CL9
Video Card(s) 2x HIS HD6950 2GB Crossfire, 6970 clocks ||| HD6550D
Storage 120GB Intel 320 series SSD + 2TB storage ||| 1TB Seagate
Display(s) 32" Sony Bravia LCD 1080p ||| 50" Hitachi Plasma 1080p
Case Raidmax Raptor modded to 7 fans ||| A compact HP Case
Audio Device(s) Firewire audio interface + two 9" studio monitors, 450 REAL watts ||| onboard
Power Supply Corsair TX 750W ||| generic 400W
Software Win 7 Ultimate + Win 8 consumer preview||| Win 7 Pro
Benchmark Scores Never drops below 60fps Battlefield 3 everything on max, fov 90. :D
Wow, i thought 4500mAh was good... Prices of this one?
Mussels
58,413 (8.18/day)
Oystralia
