Max Payne 3 - Low FPS
Discussion in 'Games' started by RoboX, Sep 27, 2012.
  1. Enmity New Member
    Mar 18, 2009
    454 (0.17/day)
    36
    New Zealand
    also, you probably should check your tesselation settings in CCC, makign sure its not switched to something crazy like 64x, might as well leave it on amd optimised if its not already. while ur there check ur AA settings, you may have selected edge detect or something similar, change it to box and try max payne 3 after these have been checked coz with this game the main performance killers are AA and tesselation.
  2. mafia97
    mafia97
    Feb 14, 2009
    1,152 (0.43/day)
    146
    Delhi,India
    turn down MSAA if you are using that heavily, it lowers FPS
  3. RoboX
    Feb 20, 2012
    159 (0.10/day)
    9
    Italy
    I have set the FX and MA to 0...the game play at 60fps but have orrible aliasing...
    I try to force The AA (morfologic, 8x, SS MS ecc) but no way to work..
  4. Dent1
    May 18, 2010
    3,415 (1.53/day)
    1,068
    Load up Max Payne 3, play a few minutes, minimise the game and then take a print screen of your Task Manager's performance tab. Let us see the resources!
