Media Player Classic crashing (all versions)
454 (0.07/day)
System Name celer
Processor Pentium 4 650 3.4GHz 2MB L2
Motherboard MSI PM8M3-V
Cooling Thermalright SI-128 SE
Memory 2048MB OCZ 2-3-2-5 2T at 200Mhz
Video Card(s) Sapphire Radeon R9100
Storage 250G Samsung 850 PRO (MZ-7KE256BW) - 1024G WD Black (WD1003FZEX)
Display(s) 19' iiyama ProLite E1980SD 1280x1024 75Hz DVI
Case Eurocase moded
Power Supply Enermax 620W Liberty
Mouse Logitech MX510 red
Keyboard eTech PS/2 keyboard
Software Win XP SP3
Benchmark Scores http://hwbot.org/submission/2455634_
I have weird problem. In one of my older recapped computers (JetWay V266B http://capsmod.net/forum/viewthread.php?tid=69 ) I having weird problems with Media Player Classic. It keep crashing on start, even when I deleted the *.ini file with prefs. Even different versions, including the latest. Version 6.4.7.5 (Unicode) - because of the bink support:
Or the version 6.4.9.0:
I tried recently even the latest betaversion with the very same result...
The machine using AXP 2800+ Barton CPU, it is 100% Prime CPU/RAM/PWM tested stable and does not crash at all. Not even overclocked much higher that I run it day by day.
Using Windows 2000 SP4 Czech with FFDshow installed (ffdshow_20071119.exe) and also with WMF9_dist.exe installed.
Tried regsvr32 quartz.dll to make GSpot happy to did not complain, tough no change with the Media Player Classic problem. Using BSplayer w/o troubles - except for mpeg1 video, but that it likely not related problem.
SSE enabled in the BIOS on the AXP CPU. No idea what went FUBAR. Any suggestions where to look?
T
thraxed
Most likely id say you have a codec conflict. Uninstall all your codecs. See if mpc launches then.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
uninstall any and all codecs, this can include video converting programs, including ones you wouldnt expect like nero.
