Metro 2033 Black Screen Problem... help pls
1,221 (0.25/day)
Canada
System Name Brutus
Processor i5 4690k @4.7Ghz (Watercooled)
Motherboard z97 MSI Gaming 5
Cooling NZXT Kraken x61 AIO watercooler
Memory Gskill Ripjaws 8gb (2x4gb) 1600mhz 7-8-7-24
Video Card(s) MSI Gaming GTX 980ti x2 (sli)
Storage 1 SSD 64GB (OS) + 2x500GB WesternDigital RAID 0
Display(s) YAMAKASI Catleap q270 SE 27inch Glossy 2560x1440
Case NZXT Phantom
Audio Device(s) ASUS Xonar DX
Power Supply Antec TPQ 1200w
Software Windows 7 (64 bit)
Hey guys, look @ my specs first...
I'm playing metro 2033 on windows 7 64 bit with crossfire 6950 2gb...
And I have this problem:
Whenever I'm in very dark areas, my whole screen turns black... Can't even see the Fraps FPS counter when that happens...
Would like to know if this happened to anyone else and how to fix it... It's making my gameplay real hard... I noticed sometimes I can lift that effect by zooming with a scoped gun...
731 (0.13/day)
System Name WhiteWalker2020 / LAN Box
Processor Intel i7 6900K 4.4GHz / 2500K i5@4.5GHz
Motherboard MSI X99A Krait / Gigabyte Z68-UD3P
Cooling Full custom liquid / XIGMATEK HDT-Aegir
Memory G.Skill 32GB DDR4 3000MHz/ 4x4GB G. Skill DDR1866 Sniper
Video Card(s) EVGA GTX1080Ti SC ACX 2.0, EVGA GTX 1070 SC ACX 2.0
Storage 950 Pro 512GB M.2, 960GB SanDisk Ultra II, Intel 730 480GB and 240GB, 850 EVO 250GB, 17TB Mechanical
Display(s) 39" AMH 399A (no glass) UHD , Wasabi Mango 42" UHD IPS, Samsung 55" 4K
Case Thermaltake Core x9 / HAF 932 Red
Audio Device(s) Realtek HD-Audio On-Board
Power Supply EVGA Supernova 850W / Corsair 650TX
Mouse 2x Logitech 610
Keyboard Razer DeathStalker / Logitech G910 Orion Spark RGB Mechanical
Software Windows 10 Pro / Windows 10 64bit Professional
It's your monitors active backlight. When it knows its displaying a lot of very dark areas the backlight will dim. This can be turned off it its settings, so make a user profile and turn it off and set the colors the way you like em.
13,791 (1.93/day)
Yeah, this is an artificial way to boost contrast ratio (not a particulary good one). I have the same thing on my Samsung. Easiest way to test this is to have 1 fully white image and 1 fully black one. Then maximize both of them on desktop and switch between them and observe window frame and Windows taskbar. If the brightness of those elements changes when you switch between both images, the monitor is doing that.
1,221 (0.25/day)
Canada
System Name Brutus
Case NZXT Phantom
Aha! That's the b..** that was causing the problem... Thank you guys so Much !! lolzz :O)
