System Name | Juliette // My HTPC |
Processor | Intel i7 9700K // AMD Ryzen 5 5600G |
Motherboard | ASUS Prime Z390X-A // ASRock B550 ITX-AC |
Cooling | Noctua NH-U12 Black // Stock |
Memory | Corsair DDR4 3600 32gb //G.SKILL Trident Z Royal Series 16GB (2 x 8GB) 3600 |
Video Card(s) | ASUS RTX4070 OC// ASUS RTX 4060 OC |
Storage | Samsung 970 EVO NVMe 1Tb, Intel 665p Series M.2 2280 1TB // Samsung 1Tb SSD |
Display(s) | ASUS VP348QGL 34" Quad HD 3440 x 1440 // 55" LG 4K SK8000 Series |
Case | Seasonic SYNCRO Q7// Silverstone Granada GD05 |
Audio Device(s) | Focusrite Scarlett 4i4 // HDMI to Samsung HW-R650 sound bar |
Power Supply | Seasonic SYNCRO 750 W // CORSAIR Vengeance 650M |
Mouse | G903 and a Master Mouse MM710/No mouse, MS game copntroller |
Keyboard | EVGA / Logitech K400 |
Software | Windows 11 Pro // Windows 10 Pro |
System Name | Felix777 |
Processor | Core i5-3570k@stock |
Motherboard | Biostar H61 |
Memory | 8gb |
Video Card(s) | XFX RX 470 |
Storage | WD 500GB BLK |
Display(s) | Acer p236h bd |
Case | Haf 912 |
Audio Device(s) | onboard |
Power Supply | Rosewill CAPSTONE 450watt |
Software | Win 10 x64 |
System Name | Indis the Fair (cursed edition) |
Processor | 11900k 5.1/4.9 undervolted. |
Motherboard | MSI Z590 Unify-X |
Cooling | Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans |
Memory | G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v) |
Video Card(s) | EVGA 2080 Super Hybrid (T30-120 fan) |
Storage | 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB |
Display(s) | BenQ XL2546K, Dell P2417H |
Case | FD Define 7 |
Audio Device(s) | DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5 |
Power Supply | Seasonic 860w Platinum |
Mouse | Razer Viper Mini, Odin Infinity mousepad |
Keyboard | GMMK Fullsize v2 (Boba U4Ts) |
Software | Win10 x64/Win7 x64/Ubuntu |
http://www.overclock.net/t/891696/a-short-power-phase-design-explanation
Someone correct me if I'm wrong but I believe Haswell handles power better then previous chips.
Yes, you r right
but for overclocking, more power phases is good, because the load on each phase is reduced. that mean they generate less heat, so makes them more efficient and stable
System Name | Gaming System / HTPC-Server |
Processor | i7 8700K (@4.8 Ghz All-Core) / R7 5900X |
Motherboard | Z370 Aorus Ultra Gaming / MSI B450 Mortar Max |
Cooling | CM ML360 / CM ML240L |
Memory | 32Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz |
Video Card(s) | Zotac RTX 3080 / Colorful GTX 1060 |
Storage | 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe |
Display(s) | LG 27GN800-B 27'' 2K 144Hz / Sony TV |
Case | Xigmatek Aquarius Plus / Corsair Air 240 |
Audio Device(s) | On Board Realtek |
Power Supply | Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum |
Mouse | Logitech G502 Hero / K400+ |
Keyboard | Wooting Two / K400+ |
Software | Windows 10 x64 |
Benchmark Scores | Cinebench R15 = 1542 3D Mark Timespy = 9758 |
so... more phases power is good for overclock?
As I said it depends on other components in the VRMso... more phases power is good for overclock?
Benchmark Scores | Faster than yours... I'd bet on it. :) |
System Name | Computer of Theseus |
Processor | Intel i9-12900KS: 50x Pcore multi @ 1.18Vcore (target 1.275V -100mv offset) |
Motherboard | EVGA Z690 Classified |
Cooling | Noctua NH-D15S, 2xSF MegaCool SF-PF14, 4xNoctua NF-A12x25, 3xNF-A12x15, AquaComputer Splitty9Active |
Memory | G-Skill Trident Z5 (32GB) DDR5-6000 C36 F5-6000J3636F16GX2-TZ5RK |
Video Card(s) | ASUS PROART RTX 4070 Ti-Super OC 16GB, 2670MHz, 0.93V |
Storage | 1x Samsung 990 Pro 1TB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay) |
Display(s) | Dell S3220DGF 32" 2560x1440 165Hz Primary, Dell P2017H 19.5" 1600x900 Secondary, Ergotron LX arms. |
Case | Lian Li O11 Air Mini |
Audio Device(s) | Audiotechnica ATR2100X-USB, El Gato Wave XLR Mic Preamp, ATH M50X Headphones, Behringer 302USB Mixer |
Power Supply | Super Flower Leadex Platinum SE 1000W 80+ Platinum White, MODDIY 12VHPWR Cable |
Mouse | Zowie EC3-C |
Keyboard | Vortex Multix 87 Winter TKL (Gateron G Pro Yellow) |
Software | Win 10 LTSC 21H2 |
The Z87 boards from gigabyte nearly all used IR355x series power stages, so 4 phase power designs were completely adequate. My H87-D3H has 4 IR3553s, which is complete overkill for a board which doesn't support overclocking at all. You could easily run an 8 core xeon of one of those VRMs. Then look at the Z87x-UD4H... That has 16 IR3553s, which at 40A each means a maximum current of 640A, over 6 times what you can expect for heavy air overclocking...With the prior generation of Gigabyte, the phase count was lower because they used a higher quality phase than much of the competition. Not sure if thats still the case.
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
+1. Absolutely.No that's true, the IR power stages are by far the best for VRMs and IMO Gigabyte really went backwards with the Z97 boards.
