Modular power supply question(S)
Discussion in 'General Hardware' started by newconroer, Jun 19, 2008.
  1. newconroer
    newconroer
    Jun 20, 2007
    3,347 (1.17/day)
    397
    Going to be installing a GTX 280 soon and have to dish out for a new PSU.
    I am considering a modular unit, yet I've never worked with them before. All I know is that it allows for better cable management, yet the electrical resistance can decrease power output.
    Is this a self-explanitory situation, or will I need proper voltage tools to test the leads?
  2. oli_ramsay
    oli_ramsay
    Sep 22, 2007
    3,480 (1.25/day)
    569
    UK
    No, the voltages will be fine, don't know where you heard that :confused:
    I would suggest a corsair modular PSU as they are know to be the most stable, well built and silent PSUs around. I would suggest a HX620W at least for a GTX280 or maybe higher
    Check out this review http://www.hardwaresecrets.com/article/371
    newconroer says thanks.
  3. newconroer
    newconroer
    Jun 20, 2007
    3,347 (1.17/day)
    397
    Thanks for the reply and recommendation.
    I'm already going with a Silverstone DA750.
    It's good to hear I won't have to anything extreme. I just can't see myself in my mind plugging in the leads, much like you would when thinking of computer build.
    I suspect there will at least by some markings or documentation to tell me where to plug things in.
  4. oli_ramsay
    oli_ramsay
    Sep 22, 2007
    3,480 (1.25/day)
    569
    UK
    Yea, it's pretty foolproof. You should be OK and happy gaming with your new card :toast:
  5. EnergyFX
    EnergyFX New Member
    Nov 22, 2007
    1,554 (0.57/day)
    340
    Annapolis, MD
    yeah, the whole 'power loss' and 'increased resistance' through the connector concept was mostly people over scrutinizing and trying to find fault in the concept. Modular is a proven method.
Share This Page
