Monitor cleaning help required
Discussion in 'General Hardware' started by WhiteLotus, Jun 26, 2008.
  1. WhiteLotus
    WhiteLotus
    Jul 30, 2007
    6,570 (2.11/day)
    865
    What's the best way to clean a monitor with absolutely no proper products for it?
  2. panchoman
    panchoman Sold my stars!
    Jul 16, 2007
    9,595 (3.06/day)
    1,201
    isopropyl alcohol should do a good job
  3. WhiteLotus
    WhiteLotus
    Jul 30, 2007
    6,570 (2.11/day)
    865
    and that is found in what now?
  4. hat
    hat Enthusiast
    Nov 20, 2006
    17,703 (5.25/day)
    2,517
    Ohio
    Umm... you have 1120 posts here and you don't know that? :roll:
    It's rubbing alcohol.
    Crunching for Team TPU
  5. calvary1980
    calvary1980 New Member
    Dec 26, 2007
    1,801 (0.61/day)
    310
    Toronto, CA
    isopropanol/isopropyl you can find at a pharmacy it's rubbing alcohol it comes in 70% 90% 99% use a Tek or J-Cloth. you can also buy pre-applied wipes
    - Christine
  6. panchoman
    Jul 16, 2007
    9,595 (3.06/day)
    1,201
    as hat said, its commonly found in rubbing alcohol, one thing thats found in a lot of people's house.
    also, glass cleaners such as windex also work.
  7. WhiteLotus
    WhiteLotus
    Jul 30, 2007
    6,570 (2.11/day)
    865
    ah i see, and the 1220 post is because I'm learning!
    Thanks guys.
  8. calvary1980
    Dec 26, 2007
    1,801 (0.61/day)
    310
    Toronto, CA
    [​IMG] do not use windex or any glass cleaner on an LCD.
    - Christine
  9. panchoman
    Jul 16, 2007
    9,595 (3.06/day)
    1,201
    i know they're fine on glass, like crt's or imacs.. but i've use windex on my lcd without any ill effects, can you enlighten me?
  10. calvary1980
    Dec 26, 2007
    1,801 (0.61/day)
    310
    Toronto, CA
    LCD's are not made of glass it can damage the screen. "LCD Cleaner" is just 50% Isopropanol 50% Water.
    - Christine
  11. Squirrely
    Squirrely
    Mar 3, 2008
    367 (0.13/day)
    40
    I would not use that, as you do not want to wear down the outer thin pane of glass. Its thin enough, don't need to make it thinner. :p
    Edit: Thought they were, what is the outer pane made of? An acrylic based substance?
  12. panchoman
    Jul 16, 2007
    9,595 (3.06/day)
    1,201
    i know that most aren't made from glass.. and i know that most lcd cleaners are composed on isopropanol.. and im asking for an elaboration on why i cant use windex on lcd's.. cause like i said, i've done that countless times without any ill effects..
  13. calvary1980
    Dec 26, 2007
    1,801 (0.61/day)
    310
    Toronto, CA
    it's probably cheaper just to pick up the things you need at a pharmacy some commercial LCD Cleaners can run up to $30, Isopropanol/Isopropyl 70% should do it, it's mixed with 30% Water, use a lint free cloth like a Tek or J-Cloth unscrew the lid put the cloth on top, tilt it just to dampen.
    - Christine
  14. Squirrely
    Squirrely
    Mar 3, 2008
    367 (0.13/day)
    40
    Well Windex and stuff contain ammonia. It won't damage your screen much at first, but if you keep using it, it can over time.
  15. calvary1980
    Dec 26, 2007
    1,801 (0.61/day)
    310
    Toronto, CA
    probably but it's just something you learn like the 10 commandments, im not a [​IMG]
    you can probably find out via google with a tv query because windex is a no no too.
    - Christine
  16. panchoman
    Jul 16, 2007
    9,595 (3.06/day)
    1,201
    ah ok, thank you for clarifying :toast:
  17. acperience7
    Nov 26, 2007
    265 (0.09/day)
    32
    Would a microfiber cloth and bit of water be safe? I have used that once before and didn't seem to hurt anything.
  18. Squirrely
    Squirrely
    Mar 3, 2008
    367 (0.13/day)
    40
    No problem.
    Yeah. Windex is fine on CRT's since they have such a think pane of glass, but on LCD's, the thin pane is so thin, the ammonia in the Windex may/can start harming it.
  19. calvary1980
    Dec 26, 2007
    1,801 (0.61/day)
    310
    Toronto, CA
    Microfiber cloth is no good if it's been used already.
    - Christine
    acperience7 says thanks.
