Motherboard shutting down shortly after power up
johnspack
Here For Good!
5,980 (0.99/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 2x 24" 1080 displays
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Manjaro, Windows 10, Kubuntu 23.10
Benchmark Scores It's linux baby!
Honestly I'd look at the psu as well. What is that?
Cute responses, was trying to be cute myself as I've never heard of that psu... I'll remember not to do that again...
1,261 (0.31/day)
System Name Some computer stuff
Processor Mostly Intel or AMD
Motherboard ATX or mATX
Cooling Bong Cooler
Memory DDR2-4
Video Card(s) A few
Storage Plenty Platters or SSDs or USBs
Display(s) Samsung 23"
Case 5 on the floor
Audio Device(s) There's one for my M7 Gene, Oh I have 3-4 PCI 5.1 ones.Sabrent! lol
Power Supply 750-1000W
Mouse cheap
Keyboard Used ps2 from garage sales
Software Yeah
Benchmark Scores http://hwbot.org/user/schmuckley/#Hardware_Library http://valid.canardpc.com/rbjpbg
I cleared the CMOS, got the motherboard out of the case , and it still does shutdown. However when not plugging in the 12v cable it stays powered on. I tried with and without the ram, graphics card and every other component. Can we for sure say that the problem comes from the PSU ?
Have you trying using just 1 stick of RAM in each slot? If one doesn't work in all the slots,try another one ;)
also: push all the wires into the power plugs for your mobo.
LEPA is made by Enermax and..has some cheaper parts.
JonnyGuru did NOT like it. :fear:
Where can you get parts from?
2,707 (0.80/day)
On The Highway To Hell \m/
You've never heard of a LEPA PSU? I find that pretty hard to believe. They've been around for a while now.
Here I am wondering what is that? Or those? In your avatar. Here's your chance to make me look naïve as hell too.:fear:
748 (0.19/day)
Oceania
961 (0.18/day)
Currently somewhere around NSW, Australia
System Name hmmm... / lappy (ASUS Scar III)
Processor Intel Core i7-8086K / Intel Core i7-9750H
Motherboard ASUS Maximus XI Formula / ASUS G531GW
Cooling Noctua NH-D15s w/ 2 x Noctua NF-F12 PWM Chromax and 1 x Noctua NF-A15 HS-PWM Chromax Fans / Stock
Memory 4x16gb G.Skill Trident Z DDR4 3600mhz / 2x16gb Kingston Hyper X Impact DDR4 2666mhz C15
Video Card(s) 2 x EVGA GTX 1080 TI FTW3 / Nvidia RTX 2070 8gb
Storage 2 x Samsung 960 EVO Plus 1tb NVME/ 1tb Intel SSDPEKNW010T8 NVME + 2tb Samsung 860 EVO SSD
Display(s) Acer Predator X34P / ASUS 15.6" Screen
Case Fractal Design Meshify S2 White-TG + Noctua Chromax Fans / ASUS Scar III Case
Audio Device(s) Onboard + Logitech Z623 / Onboard
Power Supply Seasonic Prime Ultra Titanium 1000W + PROLINK PRO903WS / ASUS ADP-230GB B Power Brick
Mouse Corsair Vengeance M65 PRO RGB / Logitech MX Anywhere 2S
Keyboard Corsair K70 LUX RGB / ASUS Scar III Keyboard
Software Windows 10 Professional x64 / Windows 10 Professional x64
It displays 00 and instantly turns off.
I had an issue before with an Asus M5G although mine would just keep on restarting. Tested the CPU on a different board and it would display 00 on the Q-Code LEDs. I tested with parts, different PSU, different RAM (tried 1 stick, 2 sticks, 3 sticks, 4 sticks, different locations), different motherboard, different CPU, tested the parts outside the case and inside the case, and flashing the BIOS. After testing, it turned out that the motherboard and CPU were both dead. If you have a friend in the area who has a similar build, ask if you can test your parts on his/her PC. Bring it to a local computer shop if you have to check as well.
Edit: Here's the link to the thread for my problem before. It might help.
190 (0.05/day)
France
Processor 5800X3D
Motherboard MSI Prestige X570 Creation
Cooling Corsair Hydro H100i RGB Platinum SE
Memory Kingston 32Go 3600MHz
Video Card(s) Nvidia 4090
Display(s) Asus XG27UQ + Asus PG279Q
Case Corsair Obsidian 750D
Power Supply Corsair RM850x White
So I had the chance to test another PSU, had the same issue I encountered with the other one, shutting down of the motherboard less than 1 second after powering the system up. So I guess the PSU is not the problem, maybe the CPU is faulty. In this case , what can I do ?
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (2.11/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Mouse cheap
Keyboard under going restoration
Pick your board up and give it a sniff, if any part is fried you will smell it, my bet is still a faulty/cooked BIOS chip.
190 (0.05/day)
France
Processor 5800X3D
It doesn't smell fried at all. It smells neutral, like "regular hardware".
959 (0.20/day)
System Name Better than before
Processor 10400
Motherboard B460 Pro4
Cooling Id-Cooling 224
Memory 16 GB
Video Card(s) 1650 Super
Storage Swordfish 500 GB
Display(s) AOC G2
Case Coolermaster Ammo 533
Audio Device(s) Micca MB42X
Power Supply Pure Power 11
Mouse G403
Keyboard Sidewinder x4
Software Windows 10 (ugh)
You've had the computer for 3 weeks but never had a problem until you cleaned the cpu. If that's the only difference between it working, and not working, I guess you killed the mobo cpu socket or the cpu itself. No way of knowing until you get working parts and test. I hope you figure it out. Not sure why 3 week old paste needed redoing in the first place.
190 (0.05/day)
France
Processor 5800X3D
It was pre applied thermal paste from the waterblock, I wanted to see if the temperatures would have been better with MX-4. The result wasn't exactly what I expected. :(
748 (0.19/day)
Oceania
Did you see my post regarding the vrms? I thouht I quoted you but seems I didn't.
If the board only stays powered on with the 12v cpu plug removed there's a good chance the vrms are cooked. They need a power good message from the cpu. If you follow the link to legit reviews and read the article you can see that particular board a fault where vrm ocp wasn't working, consequently killing the cpu power on module.
Looks like the initial cause was PSU overcurrent, which would go hand in hand with the JohnnyGuru test resulrs
13,210 (3.81/day)
Sunshine Coast
System Name Black Box
Memory G.Skill 16GB 3600 C18
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
I can't see how changing thermal paste can kill a CPU unless you removed it completely from the system and damaged it somehow or bent a pin on the Motherboard.
Personally I find it quick and easy to remove the cooler and change the paste without removing the CPU.
as mentioned, it can be damaged VRM's, but I would check the pins on the board if you removed the CPU.
961 (0.18/day)
The best way to know which part is dead is to get/borrow working parts and test. You can try to RMA both the CPU and motherboard as well. RMA with Intel (based on my experience) is hassle free although RMA with ASUS (based on my experience) is a PITA. I hope you can borrow working parts to test your system on.
1,901 (0.34/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Aquinus
Resident Wat-man
13,147 (2.95/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
00 on the Q codes of an ASUS mother board=corrupted bios. Here's a link with how 2 instructions.
http://event.asus.com/2012/mb/USB_BIOS_Flashback_GUIDE/
You know, while I'm reluctant to think that's the case, USB FlashBack does let you flash the BIOS without a working CPU or DRAM. It may be a good idea just to flash the latest BIOS just to rule it out. The times I've had a bad BIOS, the board would usually hang, not shut back off, but it's something worth exploring. Good catch.
961 (0.18/day)
190 (0.05/day)
France
Processor 5800X3D
Thanks all, I will try the bios flashback and report results.
190 (0.05/day)
France
Processor 5800X3D
I tried with the cpu and ram connected, it didn't work. So I got everything out and tried with the 24 pin cable only , and it still didn't work. I encountered this problem
  1. If the light flashes for five seconds and turns stable, USB BIOS Flashback is not operating properly. This may be caused by improper installation of the portable storage device, an error in the file name, or incompatibility in file formats. If this is the case, restart the system until the light clears, and check the file name and format.
I tried a USB2 and USB3 key, obviously with the dedicated BIOS flashback port, with the right file name, in vain.
I really don't think what else I could do now... :(
961 (0.18/day)
RMA the parts if you're don't have or can't borrow a spare motherboard/CPU to test.
748 (0.19/day)
Oceania
Did u read the legitreviews article I linked to earlier?
http://www.legitreviews.com/intel-x99-motherboard-goes-up-in-smoke-for-reasons-unknown_150008
Exactly what you've described, to a T. :) OCP failed and the vrm's along with the CPU were fried. Either vrm ocp or psu ocp but prob vrm since same chipset.
12,130 (1.87/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I agree. If you left the CPU in its socket, that would protect the pins from physical damage. Plus the CPU would be less susceptible to ESD damage. I say less but not immune. You still need to take necessary ESD precautions by unplugging the computer from the wall and touching bare metal of the case interior to discharge any static in your body and put you and the CPU/computer "at the same potential".
I would try one stick of RAM at a time and see what happens.
190 (0.05/day)
France
Processor 5800X3D
190 (0.05/day)
France
Processor 5800X3D
I did all that. Thanks anyway.
