Motherboard shutting down shortly after power up
20,787 (3.41/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
Software Gentoo Linux x64
Best of luck with the RMA.
961 (0.18/day)
Currently somewhere around NSW, Australia
System Name hmmm... / lappy (ASUS Scar III)
Processor Intel Core i7-8086K / Intel Core i7-9750H
Motherboard ASUS Maximus XI Formula / ASUS G531GW
Cooling Noctua NH-D15s w/ 2 x Noctua NF-F12 PWM Chromax and 1 x Noctua NF-A15 HS-PWM Chromax Fans / Stock
Memory 4x16gb G.Skill Trident Z DDR4 3600mhz / 2x16gb Kingston Hyper X Impact DDR4 2666mhz C15
Video Card(s) 2 x EVGA GTX 1080 TI FTW3 / Nvidia RTX 2070 8gb
Storage 2 x Samsung 960 EVO Plus 1tb NVME/ 1tb Intel SSDPEKNW010T8 NVME + 2tb Samsung 860 EVO SSD
Display(s) Acer Predator X34P / ASUS 15.6" Screen
Case Fractal Design Meshify S2 White-TG + Noctua Chromax Fans / ASUS Scar III Case
Audio Device(s) Onboard + Logitech Z623 / Onboard
Power Supply Seasonic Prime Ultra Titanium 1000W + PROLINK PRO903WS / ASUS ADP-230GB B Power Brick
Mouse Corsair Vengeance M65 PRO RGB / Logitech MX Anywhere 2S
Keyboard Corsair K70 LUX RGB / ASUS Scar III Keyboard
Software Windows 10 Professional x64 / Windows 10 Professional x64
I would have noticed it, and just checked using my flashlight. I will RMA the parts.
I wish you the best of luck with Asus. I hope you get better service than what I experienced.
748 (0.19/day)
Oceania
Been doing a bit reading, seems a few X99's use analogue PWM controllers...X99-A is one, so is X99 SLI Plus..
The thing with analogue is they tend to overshoot the target voltage....even the OCP limit if LLC + vcore is high enough. Wonder if that played a part and not so much total OCP failure?
Only speculation ofc.....:)
13,210 (3.80/day)
Sunshine Coast
System Name Black Box
Memory G.Skill 16GB 3600 C18
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
17 (0.01/day)
London
Processor 2500k @ 4.6ghz
Motherboard Asus P8Z77-V LE PLUS
Cooling Corsair H60
Memory 16GB Corsair CMX8 1600 C9
Video Card(s) EVGA GTX 970 FTW
Storage 2 x 840 evo 240gb RAID 0, 2 x Samsung Spinpoint F1 1TB RAID 0 + 64GB Intel 510 Cache
Display(s) Dell U2913WM
Case Lian Li PCV-2000
Power Supply Corsair 650w
Benchmark Scores 10154 - Firestrike
Bit late to the party, but as your board is RMA'd I'd check the underside of your CPU. I've known a tiny spot of thermal paste to get onto the underside of the cpu and effectively block one of the contact points. This would give you the same symptoms as you originally described.
Good luck
20,787 (3.41/day)
System Name Pioneer
I detect sarcasm :eek:
I hope it all goes smoothly, despite reports otherwise.
Maybe a little, but I do honestly hope it goes well...
1,901 (0.34/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
They take weeks, I had many issue's with the flash back. Took me several tries to get it to go, the board should have dual bios, right?
190 (0.05/day)
France
Processor 5800X3D
Motherboard MSI Prestige X570 Creation
Cooling Corsair Hydro H100i RGB Platinum SE
Memory Kingston 32Go 3600MHz
Video Card(s) Nvidia 4090
Display(s) Asus XG27UQ + Asus PG279Q
Case Corsair Obsidian 750D
Power Supply Corsair RM850x White
I never knew RMA could have been so long, as I never had issues with any of my hardware parts. As it turns out, it isn't going well. They sent me the following CID (Customer Induced Damage) repair table :
Given the state of my motherboard, they can't repair it under warranty (bolded CIDs in table). Here are the pictures they provided :
What do you think ?
190 (0.05/day)
France
Processor 5800X3D
OneMoar
There is Always Moar
8,746 (1.70/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Cooling Enermax ETX-T50RGB
Storage ADATA SX8200PRO NVME 512GB, Intel 545s 500GBSSD, ADATA SU800 SSD, 3TB Spinner
Mouse Kone burst Pro
Keyboard EVGA Z15
ASUS Will reject anything with visible damage
that being said
1. the damage shown in the pictures should not be fatal (the second picture looks like somebody hit it with sand paper or some other abrasive tool )
2. ASUS Techs aren't known to be very careful if the damage didn't exist when you sent the board out its likely they did it and are blaming you for it (asus has a bit of a history with this)
push for escalation and tell them the damage didn't exist when it was sent to them
if they complain point them to this thread AND this one http://www.techpowerup.com/forums/threads/not-super-pleased-with-asus.213921/
the last thing they want is to have two very public cases of repair-center induced damaged on a very public site
1,901 (0.34/day)
Processor 5930K
Cooling WATER
Mouse DEATH ADDER
Software W10HB
Broken traces in the first photo
OneMoar
8,746 (1.70/day)
Rochester area
Keyboard EVGA Z15
1,901 (0.34/day)
Processor 5930K
Cooling WATER
Mouse DEATH ADDER
Software W10HB
they aren't broken it just looks like some of the epoxy is scrapped away
Clearly you need glasses! And don't know what your talking about!
I can tell by your spamming.............
OneMoar
8,746 (1.70/day)
Rochester area
Keyboard EVGA Z15
hey sonny that black line is where some of the pcb/coating epoxy is intact
continue to run your mouth at your own peril if it was broken you would see exposed silicon
and quick way to tell is to put a meter on each side of the trace there and check the resistance
if its good throw some clear nail polish over it and then go figure out what is really wrong with it
(something asus didn't do )
now it could very well be damaged enough to cause a issue but
if you read the thread the all the op did was pull the cooler and re-paste it unless he took the board out and threw it across the the room its either shipping damage (doesn't look like that) or asus's did the dirty themselves
1,901 (0.34/day)
Processor 5930K
Cooling WATER
Mouse DEATH ADDER
Software W10HB
It's people like you who put food on my plate, I'm not here to be right but I was trying to help the OP with his board.
I'll see it again, maybe even buy it....................................
190 (0.05/day)
France
Processor 5800X3D
Just a little update here. They did refuse my motherboard as a warranty repair and returned it. I afterwards bought the X99-A/USB 3.1 motherboard. I now have my system back, almost two months later :shadedshu:. Anyway, I thank you all for the provided help! :)
tabascosauz
7,568 (2.34/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Memory 64GB 6000CL30┃32GB 3600CL14
Storage 8TB of SSDs┃1TB SN550
Display(s) 43" QN90B / 32" M32Q / 27" S2721DGF
Case Caselabs S3┃Lazer3D HT5
Wait...are you just going to leave that Maxbron there?
The damn thing received a 4 from OW.
That's a lot of money you spent on X99 and I don't want to see you have to replace anything again because, in part, of the PSU. Just because 1000W is plenty of overkill for your system doesn't mean that it gets off the hook with that kind of ripple. I also wouldn't have gone back to Asus and bought another board from them after that shitty RMA job they did, but hey, what's done is done and it can't possibly be as dangerous as using that Maxbron.
9,795 (1.90/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
sorry to hear that, sometimes rma process is shitty and they just point all is customer fault then case closed.
Aquinus
Resident Wat-man
13,147 (2.94/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
This wouldn't be the first time ASUS has been careless with hardware then called it user error. Next time you ever need to send hardware back for RMA to them, take a lot of close-up pictures of the hardware so you can tell them that it was okay when it left your place and that they're lying to you. I hate to say it but, out of all the companies, ASUS seems to have the worst RMA experience of any any manufacturer in the business.
@Solaris17 : Sound familiar?
