motherboard works outside case but not inside
bigboi86
1,442 (0.22/day)
techPowerUp!
System Name Just getting started....
Processor Athlon II Propus 620 @ 3.51ghz (quad core) L3 cache enabled
Motherboard ASUS M4A785TD-V EVO
Cooling Cooler Master Hyper 212 (great heatsink, 40c max load overclocked)
Memory Kingston HyperX DDR31600 4gb 2x2
Video Card(s) ATI Radeon HD 4850 by XFX
Storage Western Digital Caviar Blue WD3200AAKS 320GB SATA
Display(s) Acer 21.5 inch viewable G215H 1920x1080p, AOC 22inch 1680x1050
Case Antec 300, stock for now
Audio Device(s) Onboard, Turtle Beach headphones / crappy logitech desktop speakers
Power Supply Corsair 650 watt PSU <3
Software Windows 7 x64
How does a mobo touch the PCI slots? Lol. Only the PCI cards and graphics cards should be touching them.
I'm like 100% sure the I/O shield is conductive, It's made of steel. I have no multimeter around to test it though.
panchoman
Sold my stars!
9,595 (1.57/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
well it is, so if theres something wrong with the mobo, like the electricity flows through the i/o panel, and the electricity gets onto the shield, it'll go to your case you know, and thus your mobo is grounded,
and mobo's can touch the pci slots, some mobos have an onboard sound card which fits into the first pci slot instead of the i/o shield, so hah, im not wrong. though i meant the grafix card which is hooked to the mobo.
175 (0.03/day)
Processor Intel Core 2 Duo E6400
Motherboard Asus P5W DH-Deluxe
Memory 4Gb of 2GB random
Video Card(s) EVGA GTX 750
Storage WD Black 1TB
UPDATE: I tried putting paper cut outs as washers and i still have the exact same issue. Any other ideas?
panchoman
Sold my stars!
9,595 (1.57/day)
i was going to suggest just that actually. scary:wtf:. so this means that the problem isn't with the standoffs so it might be the i/o sheild, try putting the i/o shield onto the mobo when its outside..
2,573 (0.40/day)
N.Ireland
Processor Core I5 4440 / 4430
Motherboard Asus z87-k / Gigabyte ga h97- d3h
Cooling Arctic freezer / Generic
Memory 8 gb Mushkin / Various
Video Card(s) Radeon 7850 cf / Gtx 690
Storage Samsung 850 EVO 250 gb / 2x1 terabyte hdds Wd 256 gb nvme
Display(s) Technika 32" / Asus 24` ips
Case Corsair
Audio Device(s) X-fi Titanium
Power Supply Corsair 850 w
My computer will post outside my case with mem,motherboard,cpu and gpu attached. I also get stuff on the screen when its outside the case.
what sort of "stuff" ? and didja check the cpu ( was seated correctly)
175 (0.03/day)
I got an error saying no hd attached. Yes i checked the cpu.
175 (0.03/day)
Check your HD connectors and maybe swap the cable. Also check the jumper settings in the back of HD.
:toast:
Thats not a problem i just got that error because i didn't have it plugged in. I get something on the screen outside the case but nothing when the mobo is in the game.
2,276 (0.36/day)
Cairns QLD, Aussie
System Name GaMEr / HTPC
Processor FX8320 4.5ghz so far NB- 2815mhz / X2 255 @ 3.2ghz (Temp till BD)
Motherboard 990FX-UD5 / GA-MA785GPMT-US2H
Cooling XSPC - 240rad 480rad 5 x 120mm out, 6 x 80mm in / H220-edge 1/2" & 2 x 120mm Magma
Memory 4gb PI 6,8,6,18 1T 1706mhz / 4gb Crucial D9's 1400 @ 6,6,6,18,1T
Video Card(s) 3gb HD7950 / Onboard
Storage 2 x 120gb Sandisk ultra plus 2tb WD / 60gb vertex 2 + 2 x 2tb WD Greens
Display(s) 3x24in Dell Ultra (portrait) / NEC 32" FullHD LCD
Case LL PC71A Full tower / Antec fusion black with Imon remote Modded for WC
Audio Device(s) OB / Auzentech cinema 7.1
Power Supply TT 700w TR2 / TT 600w Litepower modded with Noctua S12 fan.
Software 7 Ult / 7 premium x64
has anyone thought about the gfx card not being slotted in correctly when the mb is installed in the case..
maybe it is not engaging the pci slot enough and therefore not working...
bigboi86
1,442 (0.22/day)
techPowerUp!
Well.... grounding is so that IF there is electricity flowing throughout the motherboard in an unordinary fashion... it will go straight to ground and prevent any injuries or shock or fires.
Graphics cards and sound cards are supposed to be grounded like that. If there is something wrong with the hardware then it needs to be replaced, not ungrounded.
ex_reven
5,217 (0.81/day)
it tells you when your gfx isnt plugged when it posts.
It tells you to hit any key then it shuts down for you to fix your card.
2,276 (0.36/day)
Cairns QLD, Aussie
ah roger that... :banghead:
175 (0.03/day)
When i forgot to put in my power cable to my gpu i heard a loud beep but i don't have a speaker in my case. So does that mean my gpu is working okay?
5,197 (0.76/day)
Kansas City, KS
System Name Dell XPS 15 9560
Processor I7-7700HQ
Memory 32GB DDR4
Video Card(s) GTX 1050/1080 Ti
Storage 1TB SSD
Display(s) 2x Dell P2715Q/4k Internal
Case Razer Core
Audio Device(s) Creative E5/Objective 2 Amp/Senn HD650
Mouse Logitech Proteus Core
Keyboard Logitech G910
uh, how was there a beep without the speaker plugged in :confused:
are you sure the microwave didnt go off or something? :roll:
Most mobos have an onboard speaker.
Was it a long BEEEEEEEEEEP?
Memory.
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
Onboard as in built into the mobo itself? Or just the little microspeaker plugged into the board.
Ive never seen a speaker built into a mobo...:eek:
I have i will take a pic and send it to you in a PM
hat
Enthusiast
21,731 (3.42/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Yeah most newer mobos come with a built in speaker for that kind of thing.
bigboi86
1,442 (0.22/day)
techPowerUp!
My 6800 had a speaker on it lol.
panchoman
Sold my stars!
9,595 (1.57/day)
so what do you guys think his problem is?
175 (0.03/day)
Any other ideas?
bigboi86
1,442 (0.22/day)
techPowerUp!
You have to be installing it wrong.. there's no way a motherboard could work outside of a case just fine.. but not inside of a case.
I'm sure you're grounding something that you're not supposed to be... or shorting something out somehow.
The back of the motherboard is not touching ANY metal?
6,771 (0.97/day)
Republic of Asia (a.k.a Irvine), CA
System Name ---
Processor FX 8350 @ 4.00 Ghz with 1.28v
Motherboard Gigabyte 990FX-UD3 v4.0, Hacked Bios F4.x
Cooling Silenx 4 pipe Tower cooler + 2 x Cougar 120mm fan, 3 x 120mm, 1 x 200 mm Red LED fan
Memory Kingston HyperX DDR3 1866 16GB + Patriot Memory DDR3 1866 16GB
Video Card(s) Asus R9 290 OC @ GPU - 1050, MEM - 1300
Storage Inland 256GB PCIe NVMe SSD for OS, WDC Black - 2TB + 1TB Storage, Inland 480GB SSD - Games
Display(s) 3 x 1080P LCDs - Acer 25" + Acer 23" + HP 23"
Case AeroCool XPredator X3
Audio Device(s) Built-in Realtek
Power Supply Corsair HX1000 Modular
I had the same kind of issue. The mobo drived me nuts for a month and then I gave up. RMAd it and got a replacement that works fine. Its the internal circuit that is shorting when it is placed in a case.
Any other ideas?
Is it a refurbished board u got as a replacement? Call them and explain. Create RMA and get another one. May be another defective one.
My first mobo (Biostar Tforce S754) overclocked like mad. This replacement (I think is brand new mobo) which is a newer version is a dum ass. Doesn't want to overclock the RAM past 200 FSB from 166. For some reason in CPUZ the ram frequency keeps changing when the processor is in load (memory speed goes down when on load and goes up when not). The first one took all the way to 240FSB.
175 (0.03/day)
BIG UPDATE: i just pulled the mobo and everything out of the case i don't get anything on the screen.(from outside the case). I also tried a pci gpu and i still get nothing on the screen. I think i am going to rma the mobo again.
