MSI 680 Lightning and Power Edition (flashed) for SLI
231 (0.04/day)
Atlanta, USA
I was holding out for Titan, but decided to play around with 680 Lightning SLI for similar coin. I grabbed one Lighting at a good price and took a gamble that the Power Edition would accept Lightning BIOS flashes.
Well it did, and I'm I'm running them with LN2 BIOS in SLI. They boost to 1203 or so, fine for now with OC room later. Thought I'd post that the Power Edition has two working BIOS(s) like the Lightning. MSI simply installed the downclocked BIOS on both.
GPU-Z ASIC Quality:
Lightning - 73%
Power Edition - 71%
Pics:
Mindweaver
Moderato®™
8,194 (1.49/day)
Charleston, SC
System Name Tower of Power / Sechs
Processor i7 14700K / i7 5820k @ 4.5ghz
Motherboard ASUS ROG Strix Z690-A Gaming WiFi D4 / X99S GAMING 7
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / CORSAIR Hydro Series H100i Extreme
Memory CORSAIR Vengeance LPX 32GB (2 x 16GB) DDR4 3600 / G.Skill DDR4 2800 16GB 4x4GB
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / ASUS TUF Gaming GeForce RTX 3070 V2 OC Edition
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / Samsung 870 PRO 500GB M.2
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, ViewSonic 32" 72hz 1440p / 2x ViewSonic 32" 72hz 1440p
Case Phantek "400A" / Phanteks “Enthoo Pro series”
Audio Device(s) Realtek ALC4080 / Azalia Realtek ALC1150
Power Supply Corsair RM Series RM750 / Corsair CXM CX600M
Mouse Glorious Gaming Model D Wireless / Razer DeathAdder Chroma
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (128gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 10 Pro x64
Benchmark Scores Yes
Nice! I just bought one of the PE GTX680, and it's by far the best graphics card I've bought to date. I'm running mine easily @ 1100 and it pushes 3x 22" 1680x1050 monitors in surround sound great. Other than the default clocks being higher, what's the biggest reason for flashing over just overclocking? I may try to flash mine if it's that much better. :toast:
231 (0.04/day)
Atlanta, USA
Thanks! Yea I've wanted a Lightning card for some time. I mainly flashed the PE to get Lightning stock clocks:
N680 PE: 1019MHz base, 1084MHz boost
680 Lightning: 1111MHz base, 1176MHz boost
3,145 (0.69/day)
Processor 8700k Intel
Motherboard z370 MSI Godlike Gaming
Cooling Triple Aquacomputer AMS Copper 840 with D5
Memory TridentZ RGB G.Skill C16 3600MHz
Video Card(s) GTX 1080 Ti
Storage Crucial MX SSDs
Display(s) Dell U3011 2560x1600 + Dell 2408WFP 1200x1920 (Portrait)
Case Core P5 Thermaltake
Audio Device(s) Essence STX
Power Supply AX 1500i
Mouse Logitech
Keyboard Corsair
Software Win10
The older GTX 680 Lightning BIOS gives you voltage control over MSI AB, Nvidia forced MSI to step down and change the BIOS on newer SKUs so you could not overvoltage your GPU.
Mindweaver
Moderato®™
8,194 (1.49/day)
Charleston, SC
I may load this bios as well then. Thank :toast:
3,145 (0.69/day)
Mouse Logitech
Keyboard Corsair
Software Win10
