My First Adventure in H2O Cooling
Discussion in 'Overclocking & Cooling' started by bogmali, Jun 9, 2009.
  1. denice25 New Member
    Feb 24, 2009
    316 (0.15/day)
    17
    wow, great parts....
    bogmali says thanks.
  2. bogmali
    bogmali Moderator Staff Member
    Mar 16, 2008
    6,674 (2.66/day)
    4,145
    Pacific NorthWest
    Update:
    Finally got some quality time to start putting it together. Ran into a problem as the Scythe Ultra Kaze's are too thick for the rad bracket and is hitting the NB cooler. Had to swap one fan out of the case and replace it with the Kaze for the exhaust function. Still need a second fan to complete the rad and fan assembly so I'll get that tomorrow:eek:
    Some shots of the build:
    QuestionS:
    1. Looking at the case, where do you guys think I should mount the Res? Pump?
    2. On the pump, there are two power wires one is a 2-pin molex and a smaller one. Do those get hooked up together or one or the other?
    Thanks.
  3. phanbuey
    phanbuey
    Nov 13, 2007
    5,219 (1.98/day)
    987
    Miami
    your temps would be better if both fans were pulling air into the case through the rad...
  4. Bjorn_Of_Iceland
    Bjorn_Of_Iceland
    Jan 2, 2008
    3,178 (1.23/day)
    376
    Hmm.. k.. how will you route pump intake with the pump's layout?
    EDIT:
    oh i see, its not final yet. hmm. I suggest standard layout i guess.. pump at the bottom, then the res at the drivebay. In anycase, ima feels that thin rad will have problems dissipating heat from the water on an i7 @ OCd values.
  5. Icewind31
    Feb 11, 2006
    220 (0.07/day)
    30
    Boston Area, MA
    That looks like a standard Black Ice rad (DD rebranded)... I would definitely not pair that w/ an I7.
    Inregards to Fit's comment about <80cfm sucking, I think radiators w/ low fin density work well and are designed for the quiet low cfm fans w/o too much of a performance hit (not to say that more would hurt). Such as the Thermochill, XSPC, and TFC rads
    However I wouldn't bother w/ 80cfm fans if I liked my ears or if I get something w/ a high fin density like a Blackice GTX rad (or any Blackice rad for that matter).
    Everything else is pretty much spot on.
    Note: Fan placement works best if it's possible for you to fit a shroud between the radiator and fan (kills deadspots)
    Never ever mix copper + aluminum!
  6. bogmali
    Mar 16, 2008
    6,674 (2.66/day)
    4,145
    Pacific NorthWest
    UPDATE:
    Got everything put together, ran a leak test and bled the system;) Did not find any major leaks except for one of the res's connector plug which I fixed with some teflon tape. I guess part of putting together a WC loop also involves being "creative" and I did not take that into consideration so this is what I can come up with and I will continuously tweak/upgrade as need be.
    Bjorn of Iceland-Are you Pinoy Dude? (Paranaque in your location)
    Full System:
    [​IMG]
    CPU Block/Rad:
    [​IMG]
    Pump:
    [​IMG]
    Reservoir (I couldn't find a suitable place to mount this sucker:D):
    [​IMG]
    Thoughts, suggestions, and recommendations are always welcome;)
  7. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,416 (6.74/day)
    4,493
    Youngstown, OH
    Nice Bog but ......
    [​IMG]
    ... looking throughout your setup you may want to switch these 2 hoses around. Will help the water flow from your res to the pump a little easier. Other than this it looks VERY VERY nice!
  8. Icewind31
    Feb 11, 2006
    220 (0.07/day)
    30
    Boston Area, MA
    JR's right, the lower port of the res is the "out" (that way no air gets into the pump)
    Also, consider using the holes for the 5.25 drives to mount your res so it sit vertically correctly (it'll help in getting rid of air bubbles in that res)
  9. bogmali
    Mar 16, 2008
    6,674 (2.66/day)
    4,145
    Pacific NorthWest
    I'll take the advices and will fix them accordingly. I'll see what I can do with the Res mounting it vertically.
  10. Icewind31
    Feb 11, 2006
    220 (0.07/day)
    30
    Boston Area, MA
    o yea... forgot to respond in regards to the power connector question, the 4pin bigger connector is for power, the smaller 3 pin connector (w/ only 1 wire coming out) is for RPM sensor, whether's it's on your motherboard or fan controller/monitor
  11. sapetto
    sapetto
    May 17, 2008
    409 (0.17/day)
    47
    Bulgaria
    I like it. I am considering of making a water loop too
  12. intel igent
    intel igent New Member
    Jun 5, 2005
    4,641 (1.32/day)
    434
    Toronto, Canada
    his temp's would be better if he didn't use fesser cool....
  13. phanbuey
    phanbuey
    Nov 13, 2007
    5,219 (1.98/day)
    987
    Miami
    :laugh: also true.
  14. bogmali
    Mar 16, 2008
    6,674 (2.66/day)
    4,145
    Pacific NorthWest
    :laugh: I did not use that stuff though, I used this
  15. Fitseries3
    Fitseries3 Eleet Hardware Junkie
    Oct 6, 2007
    15,509 (5.80/day)
    3,107
    Republic of Texas
    dood theres plenty of room in that case for my pa160.
  16. bogmali
    Mar 16, 2008
    6,674 (2.66/day)
    4,145
    Pacific NorthWest
    But I can't use it......:D
  17. Fitseries3
    Oct 6, 2007
    15,509 (5.80/day)
    3,107
    Republic of Texas
    why not?
  18. intel igent
    Jun 5, 2005
    4,641 (1.32/day)
    434
    Toronto, Canada
    that's the same stuff pretty much with a different label :laugh: been watercooling for MANY year's and never had a leak :toast:
    i even distill my own water for my loop :roll:
    never find any slimey's on my tube's or in my block's either, sometime's my loop is up for a year or 2 steady before i even service it! i just top up the T-line when it goes down :roll:
    to each there own :toast:
  19. phanbuey
    phanbuey
    Nov 13, 2007
    5,219 (1.98/day)
    987
    Miami
    I don't know if i would ever actually distill my own water, but only because im lazy and the store is across the street.
  20. Fitseries3
    Oct 6, 2007
    15,509 (5.80/day)
    3,107
    Republic of Texas
    i use bottled water. just make sure it doesnt have a bunch of vitamins added.
  21. intel igent
    Jun 5, 2005
    4,641 (1.32/day)
    434
    Toronto, Canada
    boil some of your favorite water and add a couple drop's of bleach and presto! :eek:
  22. sneekypeet
    Apr 12, 2006
    21,788 (6.77/day)
    6,318
    Sorry to say that is nowhere near "distilled". If you have hard water and you boil it and add bleach, you get hot, hard water with bleach in it, nothing more.
    To actually distill the water, you need a dome to collect the steam and condence it. It drips down the sides into some sort of collection vessel. That is distilled water.
  23. Assassin48 New Member
    Oct 21, 2008
    3,450 (1.50/day)
    515
    95350
    go to a savemart they have 1 gallon of distilled water for $1
  24. Fitseries3
    Oct 6, 2007
    15,509 (5.80/day)
    3,107
    Republic of Texas
    i've used ozarka, deja blue, and a few others for years. never had any algae, scum or ionization in any of my loops.
    only problem i've had was with dyes. i've told ppl this time and time again, dont use dyes, they gunk up your loop. if you must have colored water use premixed water like feser sells, NOT a dye.
    oh... ask CD what he uses.... dasani or deja blue iirc. ;)
  25. intel igent
    Jun 5, 2005
    4,641 (1.32/day)
    434
    Toronto, Canada
    what ever :laugh: it work's and it's damn near free! and give's better temp's than the $15-$20+ per bottle stuff ;)
    you want some proper distilling come by during the season and i'll give ya some screech :rockout:
Share This Page
