MY X1300 PCI Problems And Questions
Discussion in 'Graphics Cards' started by vampire622003, Nov 8, 2007.
  1. vampire622003
    vampire622003 New Member
    Mar 6, 2007
    136 (0.04/day)
    1
    Austin
    MY X1300 PCI Problems And Questions (ALL ANSWERED)
    All my problems have been answered. Thank You!
    System Specs
    ____________________
    P4 2.2GHZ 1.5GB RAM Win XP Home and Pro (dualboot)
    80Gig WD and 40 gig WD
    sound blaster live 5.1
    visiontek radeon X1300 PCI
  2. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    22,699 (5.91/day)
    8,612
    The x1300 use regular DDR, IIRC. Which means it is probably only going to be good for about 300MHz MAX and that is if you are lucky. 275MHz is probably already close to the max the memory will do.
    The core, however, is the same one that is used on the x1300 Pro, which stock speed is 600MHz, so getting yours up to 620 isn't surprising. I find that a lot of the cards below the x1300 that use the same core are lower cards because of the memory's inability to clock to higher levels, not the core.
    10 Year Member at TPU Crunching for Team TPU
  3. vampire622003
    Mar 6, 2007
    136 (0.04/day)
    1
    Austin
    Oh K, I see. I was looking on the box and it said it had 256MB GDDR2 memory, doesnt that mean the clocks are only half, or does that have to do with something else?
  4. DaMulta
    DaMulta My stars went supernova
    Aug 3, 2006
    16,135 (4.50/day)
    1,458
    Oklahoma T-Town
    DDR is times 2
    so if its 200 then it really is 400.
  5. newtekie1
    Nov 22, 2005
    22,699 (5.91/day)
    8,612
    Well DDR means you double your real clock speed to get the effective clock speed. DDR2 is just a better form of DDR. If you have DDR2 on the card then it should go higher than 283, but not always.
    If you real clock speed was 275, your effective clock speed would be 550. Depending on what DDR2 they put on your card, it should be good for up to 400MHz. But, like I said, if the starting clock was so low, it might only be good for up to ~300MHz with their setup, and that is only if you are lucky.
    vampire622003 says thanks.
  6. vampire622003
    Mar 6, 2007
    136 (0.04/day)
    1
    Austin
    Ok, thanks! :) I have been enlightened.
    And one more thing. If I remove cards from my PCI bus will that improve performance for my video card?
  7. DaMulta
    Aug 3, 2006
    16,135 (4.50/day)
    1,458
    Oklahoma T-Town
    No
    With a 1300x don't expect much. It's one of the lower end cards.
    If you could take it back I would and get somthing better over at http://www.newegg.com
  8. vampire622003
    Mar 6, 2007
    136 (0.04/day)
    1
    Austin
    Ok Thanks
