NEC Develops World's Fastest SRAM-Compatible MRAM With Operation Speed of 250MHz
malware
5,422 (0.76/day)
Bulgaria
Processor Intel Core 2 Quad Q6600 G0 VID: 1.2125
Motherboard GIGABYTE GA-P35-DS3P rev.2.0
Cooling Thermalright Ultra-120 eXtreme + Noctua NF-S12 Fan
Memory 4x1 GB PQI DDR2 PC2-6400
Video Card(s) Colorful iGame Radeon HD 4890 1 GB GDDR5
Storage 2x 500 GB Seagate Barracuda 7200.11 32 MB RAID0
Display(s) BenQ G2400W 24-inch WideScreen LCD
Case Cooler Master COSMOS RC-1000 (sold), Cooler Master HAF-932 (delivered)
Audio Device(s) Creative X-Fi XtremeMusic + Logitech Z-5500 Digital THX
Power Supply Chieftec CFT-1000G-DF 1kW
Software Laptop: Lenovo 3000 N200 C2DT2310/3GB/120GB/GF7300/15.4"/Razer
NEC Corporation today announced that it has succeeded in developing a new SRAM (Static Random Access Memory) - compatible MRAM that can operate at 250MHz, the world's fastest MRAM (Magnetoresistive Random Access Memory) operation speed. MRAM is expected to be the dominant next-generation memory technology as it realizes ultra fast operation speeds, nonvolatility - ability to retain data with the power off, and unlimited write endurance. Verification at the SRAM speed level proves that the newly-developed MRAM could be embedded in system LSIs as SRAM substitutes in the future.
The unique MRAM was designed and fabricated by NEC and has a memory capacity of 1 megabit. Incorporating a memory cell with two transistors, one magnetic tunnel junction, and a newly-developed circuit scheme, the new design achieves an operation speed of 250MHz; double that of conventional MRAMs and almost equivalent to that of recent LSI-embedded SRAM. Tests carried out using an internal signal-monitoring circuit demonstrated data output time of 3.7 nanoseconds from a 250MHz clock edge.
MRAM are expected to generate new value and applications for future electronic devices thanks to their nonvolatility, unlimited write endurance, high speed operation, and ability to cut memory power dissipation in half. For example, these features could enable instant start up of PCs and prevent drive recorders from losing data after a sudden break in power in the future. As substitutes for system LSI-embedded SRAM, MRAM can provide even more value as they are expected to enable extremely low power dissipation of system LSIs because they can sleep when they are not in use and wake up instantly.
NEC has been actively carrying out MRAM research since 2000, and has succeeded in the development of many groundbreaking technologies, such as MRAM cell technology suitable for embedding in next generation system LSIs, in recent years. These efforts have culminated in the successful demonstration of SRAM-compatible MRAM, which open the door to realization of extremely low power system LSIs. NEC will continue to design and fabricate MRAM toward realization of an MRAM-embedded system LSI to achieve high performance, next generation system LSIs.
NEC's research is partially supported by the New Energy and Industrial Technology Development Organization's MRAM technology development project for realization of high-speed and non-volatile memory embedded in system LSIs.
7,197 (1.12/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
Oh nice. That means "flash" ram that is as fast as regular ram. Superb! This will be amazing for low power devices like PDA's, or even small board computers and embedded devices.
11,690 (1.73/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Storage Samsung 990 2TB, 2 SP 2TB SSDs and over 10TB spinning
Display(s) 56" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
And better cheaper faster more energy efficient SSD's for laptops and desktop thin clients.
OnBoard
3,033 (0.47/day)
Finland
Processor Core i5-750 @ 3.6GHz 1.136V 24/7
Motherboard Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby!
Cooling Alpenföhn Brocken HeatpipeDirectTouch
Memory Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24
Video Card(s) Gigabyte GTX 460 1GB OC (mostly stock speeds)
Storage OS: Samsung F3 500GB Games: Samsung F1 640GB
Display(s) new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD
Case new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans
Audio Device(s) new! ASUS Xonar DG & JVC HA-RX700 headphones
Power Supply Cougar CM 700W Modular
Benchmark Scores Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging
So a couple hundred gig SSD of this and a computers wouldn't need memory at all? At least laptops with big enough virtual mem space. Not that they'd boot without mem, but some teenyweenylittle memchip like 64MB would be enough.
ryboto
289 (0.04/day)
Processor Opteron 170 [2.8ghz@1.4v|1.25ghz@1.025v]
Motherboard Abit AT8 32x
Cooling HR-03, TR Ultra-120, 3xScythe S-Flex
Memory 2gb Crucial Ballistix PC4000
Video Card(s) Ati Radeon X1950 pro
Storage 150 GB WD Raptor/500GB WD
Display(s) Acer AL2032WA 20'' Widescreen LCD
Case Lian Li PC-A05b
Audio Device(s) On board Audio/Plantronics USB Headset
Power Supply Enermax NoiseTaker EG495AX-VE 485W
Software Windows XP SP2 bblean shell/Ubuntu
MRAM! haven't heard anything in the headlines about MRAM for like 3-4 years. Good to know someone's cooking up something with it.
