need a better water block
Discussion in 'Overclocking & Cooling' started by fullinfusion, May 13, 2008.
  1. fullinfusion
    fullinfusion 1.21 Gigawatts
    Jan 11, 2008
    8,635 (3.16/day)
    2,408
    I just installed a Thermaltake Big water 760i and the water block that was included looks real cheap and had a small bur on the bottom side of it..
    All is working fine but I'd like to get advice on a good water block to buy.
    Besides how tight are you suppose to tighten the block down?
    Dang manual didn't even say..
  2. jbunch07
    jbunch07 New Member
    Feb 22, 2008
    5,261 (1.96/day)
    614
    Chattanooga,TN
    fullinfusion says thanks.
  3. spearman914
    spearman914 New Member
    Apr 14, 2008
    3,339 (1.27/day)
    502
    Brooklyn, New York 11223
  4. Fitseries3
    Fitseries3 Eleet Hardware Junkie
    Oct 6, 2007
    15,509 (5.48/day)
    3,107
    Republic of Texas
    im selling a dtek fuzion that is brand new.
  5. spearman914
    Apr 14, 2008
    3,339 (1.27/day)
    502
    Or is the dtek fuzion V2 is a better choice?
  6. fullinfusion
    Jan 11, 2008
    8,635 (3.16/day)
    2,408
  7. spearman914
    Apr 14, 2008
    3,339 (1.27/day)
    502
    The article posts all the pros about the waterblock but not the cons so I really can't help you with that. Overall thats a great waterblock although I haven't seen that one.
  8. fullinfusion
    Jan 11, 2008
    8,635 (3.16/day)
    2,408
    well thanks ppl...
    How long does it take to get all the air bubbles out of the water block?
    The system was been running for about an hour now:)...
  9. calvary1980
    calvary1980 New Member
    Dec 26, 2007
    1,801 (0.66/day)
    310
    Toronto, CA
    Enzotech makes pretty good memory heatspreaders. they are only one of 2 or 3 companies that actually make copper heatspreaders.
    how much money are you looking to spend?
    - Christine
  10. hat
    hat Enthusiast
    Nov 20, 2006
    17,197 (5.46/day)
    2,198
    Ohio
    Danger Den is a good brand to look into for this kind of thing...
  11. rangerone766
    rangerone766
    Aug 18, 2007
    1,036 (0.36/day)
    111
    i vote dtek fusion v1 or 2 doest matter both are good blocks. it will take a few hours for all the large bubbles to work out. altho the small bubbles take a bit longer. the small ones almost make the fluid look milky. if you turn the pump off for 10 or 15 minutes every hour or so it will speed up the process.
    all the blocks listed by the other posters are good blocks, way better than the TT one you have now. all will perform withing a close amount to each other, and cost about the same. so the choice really is which one you prefer looks wise.
  12. fullinfusion
    Jan 11, 2008
    8,635 (3.16/day)
    2,408
    Hey Christine money really isn't an issue here... I just want something thats going to work best of the best... the only reason i installed a on board h2o cooler is for portability... I'll be soon adding a second radiator to the back of the tower just to give me the additional heat dissipation and more liquid volume.
  13. fullinfusion
    Jan 11, 2008
    8,635 (3.16/day)
    2,408
    Thank you Rangerone and Hat.
    :toast:
  14. theonetruewill New Member
    Nov 12, 2006
    2,996 (0.95/day)
    240
    London - Close your eyes and you'll see me
    Fully agree with Spearman. There is a copper version of this too (GTX Cu), but all in all either is a fantastic choice, the cream of the crop. (Note. do not get the Apogee GT, make sure to get the GTX)
  15. fullinfusion
    Jan 11, 2008
    8,635 (3.16/day)
    2,408
    thanks Theonetruewill.... I checked and didn't see adapters for the Amd2
    I'm running the Asus m3a32-mvp 790fx
    it talks about Intel and Amd but didn't see the amd2 support.
    First day in the pool and for what i have and with the amd o/d stress and multiple programs running It's at a solid 50c.... Beats the 65c using the V1 fan...
    My office is pretty warm though with a reef tank in here causing high humidity
    You think adding a rear bolt on radiator with a 120mm fan on the rear of the case piped in with the 760i will drop the temps even more?
  16. philbrown23
    philbrown23 New Member
    Dec 22, 2007
    1,231 (0.45/day)
    147
    vermont
    the EK supreme/Dtek fuzion/ Apogee GTX are all great blocks, with the Dtek pulling ahead by at least 5c. I would PM fitseries3 and make a deal with him for that dtek fuzion.
  17. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.61/day)
    3,778
    With that Thermaltake pump, avoid the EK Supreme like the plague. It's a high restriction block, and I can almost guarantee that TT pump will either fall on it's face, or die in short order.
    Get the DTek Fuzion.
  18. tkpenalty New Member
    Sep 26, 2006
    6,958 (2.17/day)
    345
    Australia, Sydney
    +1. Don't go for high restriction blocks! (Damn you Wile E... beat me to it).
  19. Grings
    Grings
    Nov 16, 2006
    2,303 (0.73/day)
    187
    Blighty
    Why not the GT, its still one of the best blocks on the market, and is a hell of a lot cheaper than the all copper (and prohibitively expensive) gtx, and a bit cheaper than the fuzion or ek supreme
    Heres some tests of apogee gt/gtx and fuzions for comparisons
    http://www.xtremesystems.org/forums/showthread.php?t=130142
    http://www.hardwarecanucks.com/foru...gtx-vs-storm-vs-fuzion-vs-apogee-vanilla.html
    obviously the Copper GTX is a better block than the GT overall, i just dont see it being worth it (dunno about US prices, but here an all copper GTX costs around £62 (here and here), certainly far too much to spend on a thermaltake 760
  20. fullinfusion
    Jan 11, 2008
    8,635 (3.16/day)
    2,408
    ok dtec... i'll check into if my local shop can get it in... but what one? v1 or v2
  21. ZenZimZaliben
    ZenZimZaliben
    Mar 4, 2005
    2,762 (0.73/day)
    642
    I have had a lot of success with Swiftech. The Appogee GT, GTX, and GTX Cu all perform about the same. 4 Degrees Difference at the top for the GTX Cu, however not the most cost effective compared to the GT.
    $80 vs $50 and only 3-4 Degree Celcius difference.
  22. echo75 New Member
    Apr 11, 2008
    456 (0.17/day)
    46
    Denmark
    there are 2 metal " H " plates one for behind the mobo and the other for the front , then put 4 screws and thiert bolts..presto.
    see pics here- http://www.techpowerup.com/reviews/Thermaltake/Bigwater760i/4.html
  23. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.61/day)
    3,778
    Either one will be fine. If you can find V1 for much cheaper, get it. If they are around the same price, you might as well get V2.
  24. fullinfusion
    Jan 11, 2008
    8,635 (3.16/day)
    2,408
    Ok sweet the v2 is what i'll order..
    Thanks everyone
    :toast:
  25. driver66
    driver66
    Jun 4, 2007
    1,053 (0.36/day)
    115
    indiana
    :confused:
Share This Page
