Need advice on first build
446 (0.10/day)
Santa Ana, Ca.
System Name Mobydick
Processor Intel i7 2600k @ 4.4
Motherboard MSI M Power
Cooling CM TPC 812
Memory patriot 8gb x 2
Video Card(s) EVGA GTX 970
Storage Kingston hyper x 3k 120ssd,Samsung 256ssd, seagate 750gb green
Display(s) Benq XL2720Z
Case Haf X
Audio Device(s) creative soundblast xz
Power Supply EVGA G2 850w
Mouse deathadder chroma
Keyboard logitech g710
Software Windows 7 64bit
Kevin117007
42 (0.01/day)
edit, if you wanna go 2011 socket, thats baller status. just saw the last post and you changed it.
I honestly just want the best processor for gaming/multitasking thats out there, while under $600. Some people are saying 3930k intel, and others 3770k(which overclocking can get to 4.5 Ghz)
Thoughts?
446 (0.10/day)
Santa Ana, Ca.
Cooling CM TPC 812
Case Haf X
im running an i7 2600k @ 4.4 and ABSOOOOLUTELY love it. my friend has a 3770k OC to 4.7 and he loves it too. either will do the job FINE, no issues.
Aquinus
Resident Wat-man
13,147 (2.96/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Nice list, that's going to be a very very nice rig. :cool:
Honestly, I doubt both my solid state and my HD drive are going to fail at the exact same time. if one fails, I always have the other. I think spending a bunch of money on backing up more than once is a mute point for me in college
Let me continue on my point for RAID, but I'm not going to push on that topic too much more because you don't seem too interested in it. It is very likely that if you have music or video that you don't want to store it on an SSD. It's a waste of space that can be used for things that actually need to load fast. For example, what I do is I installed Windows and Applications on the SSD. I store downloads, music, and video on my RAID-5 as well as intermediate backups of the RAID-0. Then I have an external 1TB drive as a secondary back-up of the RAID-5 and the RAID-0. So whenever something fails (the SSD, a regular HDD, or the external backup,) a minimum of 3 drives must fail before something really bad happens. Granted I have 6 disks between the two SSDs, the 3 1TB HDDs, and the 1Tb external (I need to upgrade this to 2TB in the near future.)
It's a matter of the data you are going to store. If you don't download a lot, or have many documents, pictures, music, or video, it most likely isn't neccessary but as the amount of data increases on your computer and you start adding things like pictures that you or someone you know has taken, your heart will sink if hardware fails and there are files that you will never see again.
Personally, I would be devastated if I lost all the pictures of my daughter since she was born which is half of the reason why I have RAID-5 + an external backup.
Also keep in mind that an external backup isn't usually current because you only backup occasionally. So you can still lose files. RAID-5 gives you an opportunity to save files before more than just 1 drive fails. I think as you use your computer more and more and you put more and more stuff on it a solution like this will make a lot more sense, but until then it doesn't.
I've seen people hit 4.5Ghz with the 3930k and I've easily been able to do 4.5ghz on my 3820.
SB-E has been under-estimated IMHO and even the 3820 is a heck of a CPU. It exceeded any expectations I had of it. In fact it blew them away and I bet that the 3930k is even more impressive. I almost got a 3930k myself, but I didn't want to pay twice as much for only 2 more cores, which is why I'm using a 3820. Plus, the stock 3820 performs somewhere between the 2600k and the 3770k (in most cases, some tasks it can do better.) so I have absolutely no complaints.
Good luck with your rig. It is definitely "built to serve." :cool:
394 (0.09/day)
Where ever the wind blows
System Name PATATAS-3XTR3M3
Processor Ryzen 5800X
Motherboard Asus ROG Crosshair VIII Dark Hero
Cooling Phanteks Glacier One 240MP
Memory 32gb (16x2) G.Skill Trident Z Neo 3600mhz
Video Card(s) Asus ROG STRIX RTX 3080 Ti UV:850@1850
Storage Boot Drive: ADATA XPG SX6000 256gb, Storage Drive: 1TB Samsung 980 x2
Display(s) Lenovo G27Q-20
Case Lian Li O11D Mini
Audio Device(s) Samson SR850 connected to a Focusrite Scarlett Solo
Power Supply Corsair SF750
Mouse Logitech G Pro X Superlight
Keyboard Akko MOD006, Durock POMS
Heya! From the looks of it you decided with a 2011 socket. I would suggest the 3770K (since this supports PCI 3.0 and would run lovely on anything) and pair with with any of the ff motherboards (I'm also picking parts for my build, with 1/4 or your budget )
ASRock Z77 Extreme9 LGA 1155 Intel Z77 HDMI SATA 6...
ASUS Maximus V EXTREME LGA 1155 Intel Z77 HDMI SAT...
ASUS Maximus V FORMULA/THUNDERFX LGA 1155 Intel Z7...
GIGABYTE GA-Z77X-UP7 LGA 1155 Intel Z77 HDMI SATA ...
my gut tells me to suggest you either the AsRock or Gigabyte board..... the gigabyte one looks awesome with that orange/theme, and the asrock has A LOT of SATA3 ports
171 (0.04/day)
New Delhi, India
System Name Devil's Hell
Processor AMD Ryzen™ 5 2600X Processor 2nd Gen 3.6GHz
Motherboard MSI X470 GAMING PRO MAX
Cooling Corsair H60 (2018) 57.2 CFM Liquid CPU Cooler
Memory Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16
Storage Segate 2 TB, WMD 250 GB M2
Display(s) Samsung T23B350AR
Case Cooler Master MasterBox Lite 5 RGB ATX Mid Tower
Audio Device(s) Motherboard
Power Supply Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply
Mouse Logitech
Keyboard Logitech
Software Windows 10 64 Bit
CPU- Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turb...
MB- MSI Z77A-GD65 LGA 1155 Intel Z77 HDMI SATA 6Gb/s U...
RAM- G.SKILL Ripjaws X Series 32GB (4 x 8GB) 240-Pin DD...
GFX- SAPPHIRE 100351SR Radeon HD 7970 3GB 384-bit GDDR5...
SSD- Crucial M4 CT512M4SSD2 2.5" 512GB SATA III MLC Int...
HD- SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cac...
PSU- XFX P1-650X-XXB9 650W ATX12V 2.2 & ESP12V 2.91 SLI... or XFX PRO850W XXX Edition Semi-Modular 80 Plus Silve... if you want to add a second 7970
Heatsink to allow OCing- COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatp...
Thermal Paste- GELID Solutions GC-Extreme Thermal Compound
KB- Logitech G110 Black USB Wired LED Backlighting Gam...
Mouse- Logitech G500 10 Buttons Dual-mode Scroll Wheel US...
Monitor- Hanns-G HL269DPB Black 26" 5ms Widescreen LED-Back...
Cost- $2,292.86 with three 26" monitors and 650 watt PSU
Add the OS of your choice, whether Windows 7 or 8. I didn't suggest a case because alot of picking a case has to do with personal choice. Better you go look at cases, then come back here with acouple choices for a case and let us pick from those cases that you picked out.
512gb SSD added as requested. Changed suggested 7970 for one with a better heatsink and about $40 less expensive.
Still seems one of the better options.....For costing reason as no one else have define the whole sys costing in that way....ya may be the sys spec won't support that upgrade thing but still if there are options the OP must be informed with costing as he stated before about the fixed budget...even I own a LGA 2011 package so costing would be as follows...
$386.246 core i7 3770k LGA 1155
http://www.flipkart.com/intel-3-5-ghz-fclga1155-core-i7-3770k-processor/p/itmd99wtkmuffh4a
$555.00 core i7 3930k LGA 2011
http://www.flipkart.com/intel-3-2-ghz-lga-2011-core-i7-3930k-processor/p/itmd4vxwxzhetpmy
and also the supported mobo will rise more cost...
171 (0.04/day)
New Delhi, India
Mouse Logitech
Keyboard Logitech
I'm not sure if the GTX 670 has 3 monitor support though? Unless I'm missing something...
@Kevin117007
Go with the link...it says Display support: Multi-monitor: 4 displays....
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-670/specifications
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_670/1.html
GTX 670 will be good enough....but yes may increase costing for sure....as it will take $369.00 for 2gb
as here EVGA 02G-P4-2678-KR GeForce GTX 670 FTW 2GB 256-bi...
Aquinus
Resident Wat-man
13,147 (2.96/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
Why do you say that? If you're going to say something like that you should at least say why you think that's the case. He has put a lot of emphasis on multi-threading and as a Comp Sci student VT-d would be nice (something k-edition skt1155 chips do not have.) On top of that, you're spending a premium on memory and the SSD when it isn't necessary.
He wants something that will last a long time and can be upgraded. skt1155 doesn't offer ANY ability to upgrade the CPU or memory if you go this route and get a 3770k.
We're talking about programming, 3D rendering, and and multi-tasking. Gaming doesn't appear to be the primary goal of this rig, in fact it needs to be capable of gaming and being a workstation, which is why I recommended a RAID to begin with.
Please, enlighten me, because I don't think I missed anything for what he wants to use this machine for and that an enthusiast platform is really what he is asking for, not a high-end mainstream platform that is at the end of its life.
Edit: Also, don't double post, there is an edit button for a reason. Thanks!
40,435 (6.61/day)
Def skt 2011 or AM3+ Machine would be up to the task.
this card would definitely fit the task at hand but probably not the bill lol
http://www.amd.com/us/products/workstation/graphics/ati-firepro-3d/w9000/Pages/w9000.aspx#3
Aquinus
Resident Wat-man
13,147 (2.96/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
http://www.amd.com/us/products/works...s/w9000.aspx#3
He's going into Comp Sci, not graphic design. I suspect that he wants to dabble with 3d rendering on the side. A professional card is completely unnecessary. In fact it will perform worse for more money because I suspect that he will be gaming more than doing 3D rendering and will be mostly programming and gaming with this rig among other every-day tasks. :toast:
171 (0.04/day)
New Delhi, India
Mouse Logitech
Keyboard Logitech
That is what my point. The costing...don't you think...the whole skt 2011 will increase costing...
:eek:
Aquinus
Resident Wat-man
13,147 (2.96/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
:eek:
Obviously it will cost more, it's a faster product, that's a given. You can't expect to get faster hardware and not pay more for it... but there are reasons why you might invest in a skt2011 system. I knew getting a 3820 would cost a little more than a skt1155 chip but it's a matter of building the machine around what you need it to do, not the price. If price was the only factor I would say get a Celeron G530. :slap:
171 (0.04/day)
New Delhi, India
Mouse Logitech
Keyboard Logitech
Ok I don't know of the 3D modelling thing apart from that the first line need of Op as he said gaming and the heavy programming can be delivered by the skt 1155 (as one of my roomie is using this)
And yes He may not be able to upgrade...
And after that if his pocket allows it what would be more nice than having a core i7 3930k , and a Asus rampage IV ext. :respect: thank you for Slap...:)
Aquinus
Resident Wat-man
13,147 (2.96/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
It's not that he may not, he won't be able to upgrade. Intel has made it very clear that Haswell is going to on skt1150.
And after that if his pocket allows it what would be more nice than having a core i7 3930k , and a Asus rampage IV ext. thank you for Slap...
The ROG boards are overrated IMHO, the P9X79 Deluxe and Pro are two very nice motherboards with plenty of features to boot.
You're also welcome for the slap. It was out of tender love and care. ;)
EasyTomatoe
27 (0.01/day)
Philippines
System Name Water Bottle
Processor Intel i7 3930K @4.5Ghz
Motherboard MSI X79A-GD65 (8D)
Cooling Noctua NH-D14 LGA2011
Memory G.SKILL Ripjaws Z 32GB (8X4GB) 1600Mhz CL9
Video Card(s) ASUS GTX 680 Direct CUII TOP
Storage Intel 330 120GB (x2),WDCBlack 1TB 7200RPM 64mb Cache (x2)
Display(s) ASUS 27" 120Hz VG278H 1920x1080 (X3)
Case Cosmos II
Audio Device(s) Asus Xonar Phoebus
Power Supply Seasonic X-1250 1250W 80PLUS Gold
Software Win 7 Ultimate 64bit
well since you got such a big budget
how about going for the intel 256 ssd?
a 850w seasonic platinum
i7 3770k
nice cooler (like cm 212 +/evo)
660 ti asus/560ti msi/570 msi should well serve the things you need to do (or a 670)
nice msi or asus motherboard
x3 monitor for 150$ each
ducky shine mx brown(green led)
roccat kone+ (or those sensei or logi alternate)
2tb samsung hdd since you will be using the ssd for boot and stuff
and like what the others said.
or if you like the lga 2011,look at my build and just arrange things around, you can get them for below 2k $, i remember building one with dual 570 msi. for 19xx $ but since you got a fat wallet, you might as well go with the 3930k, and a 670 asus and a nice asus board, 850w 80plus gold or platinum from seasonic (or corsair if they have the 850i already out) but since you will be using 3 monitors how about going with the 150$ 23" 1920x1080 monitors, should really serve you well.
you can go with the 3770k or the 3930k both are really great cpu and should perform well on all the task you take it for a spin and both go easily at 4.5ghz
40,435 (6.61/day)
Might aswell go skt 2011, expansion is the biggest player on that series. 7950 or 7970
Kevin117007
42 (0.01/day)
You read my mind. You should just build the computer for me LOL!
But in all seriousness, yes being able to dable in 3d rendering and whatnot would be great. I'm trying out game programming(3d models, animation, ect), so things like that would be useful. But like you said, most day-to-day tasks would involve programming and gaming.
293 (0.05/day)
Canada
System Name The (Modified) Futureshop Deal/The Machine
Processor Q6600 @ 2.4 (stock, see mobo)/ I5 3570k @ 4.3
Motherboard Generic Foxconn/ Asus P8z77-v lk
Cooling stock/ Antec Kuhler 620
Memory 4Gb@800/ 16gb Mushkin Enhanced Blackline Frostbyte@1600
Video Card(s) Sapphire 4850/ Gigabyte 7950
Storage Hitachi 500GB, WD Blue 500gb/ Kingston Hyperx 3K 120gb, WD green 2tb
Display(s) Acer 24" 1920x1080/ Benq VA 24" 1920x1080 and HP 24" 1920x1200
Case Acer/ Antec 302
Audio Device(s) On Board for both
Power Supply 500w OCZ Modxstream-pro/ Antec Truepower new 750w
Software W7 Home Premium 64bit for both
That ram you listed is slow (1066mhz) look for something at least 1600mhz. Also that logitech keyboard you listed is not mechanical (earlier you said you were looking for a mechanical keyboard, yes?)
Kevin117007
42 (0.01/day)
Okay, so based on what people are saying I think I will go with the 2011 socket for the main reason of upgradability.
Upgradability is a must, as I don't want to have build another computer for as long as possible. The plan is to throw down a lot of money now with the initial build, and be able to upgrade it bit by bit as needed.
To that extent, things like the Haswell and PCI being supported on the 2011 socket seem like it would be the best choice to go with.
@Aquinus
Although you have made your point for backing up data on multiple drives, I don't have anything too valuable like family pictures or the like that I'd be devastated if I lost. Most personal data things are programming projects, which are backed up various SVN repositories anyways.
I do, however, like the idea of putting two drives in RAID 0 to improve read speeds. I'd probably end up doing this with a SSD. I'd back it up once a day to my HD. Do you think this is reasonable for the cost/performance improvement, or should I just not worry about it? I believe right now that my SSD are still the bottleneck for speed, so improving them any way possible is a good idea.
On the topic of RAM, a friend of mine said that the proposed G.SKILL RAM
G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3...
wasn't that great quality. It seems that it only runs at 1066mhz(thanks for ZakkWylde for pointing that out) Any other suggestions?
Also, the motherboard suggested (ASUS P9X79 DELUXE LGA 2011 Intel X79 SATA 6Gb/s US...) supports quad-channel memory. What exactly are the benefits of this, and how can I purchase RAM to make sure I take advantage of this?
6,862 (1.17/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Benchmark Scores https://www.3dmark.com/spy/34962882
Initial build converted to socket 2011 build as requested
171 (0.04/day)
New Delhi, India
Mouse Logitech
Keyboard Logitech
Then He must go with G Skill RipJaws Z Eries 16 GB (4x4 GB)
G.SKILL Ripjaws Z Series 16GB (4 x 4GB) 240-Pin DD...
And for OP see My Specs I too build this machine with the help of TPU and I am Not sure but it may fit your budget too....(even i did'nt buy a New keyboard nd mouse) yet It may suit you
You may Replace that GTX 680 with a GTX 670 (670 is very nice with comparably low price)
and yes there are options for motherboard as Aquinus saying in the above cmnt...so go for it It will also loose cost and seriously...No need of cooling (While I too brought it even I was asked to not by eidairaman1) you will merely need that but yes do take care of the PSU as the whole system will seriously need some power
Oh I am delighted sir ji....
2,356 (0.50/day)
VT
Processor Intel i7-10700k
Motherboard Gigabyte Aurorus Ultra z490
Cooling Corsair H100i RGB
Memory 32GB (4x8GB) Corsair Vengeance DDR4-3200MHz
Video Card(s) MSI Gaming Trio X 3070 LHR
Display(s) ASUS MG278Q / AOC G2590FX
Case Corsair X4000 iCue
Power Supply Corsair RM650x 650W Fully Modular
I read he was going to do a lot of CompSci oriented work, wouldn't the improved GPGPU capabilities of the 7900 series benefit him more than the gaming performance of a 600 series?
171 (0.04/day)
New Delhi, India
Mouse Logitech
Keyboard Logitech
@Kevin117007
Basically quad-channel is four memory sticks paired up....You got it Means The Mobo will provide you 4 sticks to pin the RAM So it will surely help you to increase your RAM in future...
look it specs of @xenocide or Mine for RAM...
171 (0.04/day)
New Delhi, India
Mouse Logitech
Keyboard Logitech
@xenocide
I was saying for 600 gtx series just because I m using 680 which is costly then 670 other then that eidairaman1 also stated about the 7900 series Now it is upto OP...;)
Kevin117007
42 (0.01/day)
So my new current build is on the first page. Total cost is $2873.
My biggest question now, in trying to keep costs down, is that crossfiring 2 7970s really give a performance boost? (As opposed to buying a single 7970) Or maybe I should consider a completely different graphics card?
Again I want to be able to game on highest resolution all the newest games, ect, while also be able to handle somewhat moderate 3d work if necessary.
Graphics cards I'm considering:
670
680
7950
7970
I don't think I'm going to set up the SSDs in RAID, two expensive and doesn't really see much performance boost.
As of now, I'm good with all the parts except maybe the graphics card. Still undecided on that.
After the graphics card gets nailed down, I'm going to try worrying about the noise. I'm unsure how noisy the case/fan/PSU I choose will be. This is going to be in a small room with two people, so obv. I don't want it to be obnoxious. Does anyone have experience with these items?
