Need Hardware help to improve my machine
Discussion in 'General Hardware' started by mof42, Jun 12, 2009.
  1. mof42 New Member
    Jun 12, 2009
    2 (0.00/day)
    0
    CA
    I am a newbie and trying to find what I can do to boost the performance on this little HP I got a while back. I have done nothing to modify the BIOS yet and would entertain any suggestions from the group.
    I am a hardware engineer and I am running multiple OS's in Virtualbox VM's. I do PCB Signal integrity analysis using Cadence Allegro 16.2 , 3d modeling using solidworks and thermal modeling using IcePak and Flowtherm each running in their own VM.
    I am open to any suggestions other than using MicroCrap Vista.
    Thanks
  2. Melvis
    Melvis
    Mar 18, 2008
    3,613 (1.37/day)
    537
    Australia
    A Quad core of some kind maybe? like a Q9550 or higher?
    And maybe update the Quadro with a newer version? or go with a ATI equivalent?
    Otherwise the rest of your system seems to be pretty good to me.
    Edit: Ooops sorry also....Welcome to Techpowerup Forums :)
  3. mof42 New Member
    Jun 12, 2009
    2 (0.00/day)
    0
    CA
    Thanks
    This is a 2 quad core zeon processor system. I tried a couple of ATI Radon video cards but for the live of me I could not get them to work in Ubuntu 9.04. I have seen that ATI has sent 3 catylist updates since but I spent so much time with the xorg.conf file that I do not want to do that again. Do you know nvidia has SLI cards that can be linked that are Jaunty compatable?
  4. Melvis
    Melvis
    Mar 18, 2008
    3,613 (1.37/day)
    537
    Australia
    O ok sorry i wasn't sure if it was a Quad or a Dual core, well you can only go to about 3.2GHz i think with a Xeon Quad? Otherwise you would have to go with the new i7 Quad core CPU's but that will need a new Motherboard and DDR3 RAM.
    I agree ATI and Linux/Ubuntu doesn't seem to work very well as my Brother also runs Ubuntu and sticks with Nvidia, works well. So i would look up for a new Quadro would be ya best bet?
    Not sure on the SLi thing, but there be a good chance id say.
    Sorry i cant help ya much more.
    mof42 says thanks.
  5. Namslas90 New Member
    Aug 27, 2006
    4,851 (1.52/day)
    555
    Earth
    mof42 says thanks.
  6. theorw
    theorw New Member
    Jul 5, 2007
    771 (0.27/day)
    50
    Athens GREECE
    Actually every card that xan be flashed in its workstation version if u find the correct bios for it.
    This FIRE GL is identical to a 3870 in shape and specs so buying a 3870 and flashing it with fire gl 7700 bios should make it workstation ready!!:toast:
    mof42 says thanks.
Share This Page
