Need help ASAP. Normal idle temps of E6400 at stock speeds.
Discussion in 'Overclocking & Cooling' started by JC316, May 21, 2007.
  1. JC316
    JC316 Knows what makes you tick
    Jan 24, 2006
    9,362 (3.03/day)
    903
    Got my E6400 rig today and I am using the stock cooler with the stock compound and running stock speeds. My idle temps were 51*C. I placed silver compound on it and it's still running 51*C idle. Is that normal?
  2. anticlutch
    anticlutch New Member
    Sep 9, 2006
    995 (0.35/day)
    32
    SoCal
    You might want to check if the heatsink is put on correctly.
    Just wondering, but what is the room temp?
  3. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,414 (7.26/day)
    4,483
    Youngstown, OH
    And to add to anticlutch: Are you using any software or bios controlled fan speed settings?
  4. JC316
    Jan 24, 2006
    9,362 (3.03/day)
    903
    Room temps are 77*F. What is the limit on these chips anyway. Heatsink is pretty much idiot proof, just snap it down.
  5. JC316
    Jan 24, 2006
    9,362 (3.03/day)
    903
    Nope no bios or software. Is there fan speed settings in there?
  6. anticlutch
    Sep 9, 2006
    995 (0.35/day)
    32
    SoCal
    I think the upper limit is around 60C. If your room temp is 25C, you should be getting mid 40's at most... I think that you should try to reseat the heatsink, and put only a rice grain sized amount of thermal compound.
  7. JC316
    Jan 24, 2006
    9,362 (3.03/day)
    903
    Will do. BRB with results.
  8. JousteR
    JousteR
    May 2, 2007
    168 (0.06/day)
    35
    Cant help ya i'am on water..And not clocked runs @ 28 idol and 38 after hour or so in bf2142.
    But my m8 who runs a E6600 says his runs a little warmer than his old Amd rig..?
    Ps:I run the E6420 btw..
  9. JC316
    Jan 24, 2006
    9,362 (3.03/day)
    903
    Now I am cooking with gas. One of my pins wasn't seating properly on my heatsink. Looking at 43*C idle, which coming from an X2 3600 is HOT.
  10. JrRacinFan
    Mar 17, 2007
    19,414 (7.26/day)
    4,483
    Youngstown, OH
    Heya JC, check out speedfan, you may be able to crank up the rpm's of that stock HSF and cool it down a lil better. Linky!
  11. JousteR
    JousteR
    May 2, 2007
    168 (0.06/day)
    35
    Wicked ..result..!
Share This Page
