need help building pc / selecting parts
Discussion in 'System Builder's Advice' started by webJockey, Jan 4, 2010.
  1. webJockey
    Jan 4, 2010
    66 (0.03/day)
    0
    Hi guys, I am building a new computer for myself. I have not got much hardware knowledge. I have selected all parts based on the forums research. Big bang for buck been major concern in selection. I really need you to review them. Any feedback will be highly appreciated. Also please tell where can I save or where should I spend more
    Thanks in advance.
    Purpose: Performance PC/ HD Video Editing/ Multimedia PC.
    NO GAMING AT ALL.
    Budget: To save as much as I can while not compromising with quality so much.
    OC: Yes. Up to safe mode. 3.5Ghz
    Platform: WIN 7 Ultimate X64 (I already have it)
    Parts Selected
    Processor: i7 920
    Mobo: Asus P6T
    RAM: Corsair 6GB XMS3 1600 Model: TR3X6G 1600C8G
    HDD: I already have 1TB Segate SATA HDD. 7200 rpm
    GPU: ASUS Radeon HD 4670
    Comments: I need HDMI output and1980X1024 true resolution in the end.
    PSU: Corsair 650w CMPSU-650TX
    Comments: Is that enough or over to run the components mentioned above?
    DVD Writer: Liteon
    Comments: I’ll upgrade to Blue-Ray writer when prices go down.
    PC Case: Gigabyte Setto 1024 AXBS11-CNB
    Comments: I don’t wanna spend too much on case at this stage. I’ll upgrade the case later otherwise I really liked Cooler Master HAF 932RC–932M-KKN1-GP.
    Monitor: Asus MS246H.
    Comments: Anyone knows another good design monitor 2ms response, Res:
    1980X1024, HDMI input and with built in TV Tuner at a budget price.
    Speakers: Logitech X530 5.1
    Webcam: Microsoft LifeCam VX5000
    Keypad Mouse: Gigabyte GK-KM7500
    Comments: I prefer Ultra Slim Design. I Don’t use hot keys.
  2. SNiiPE_DoGG New Member
    Apr 2, 2009
    582 (0.25/day)
    135
    The PSU is solid, If you want a good professional end LCD that one is not your best bet, but you will need to spend much more to get the quality your looking for. I would look at NEC if you decide to go for a true professional display.
    Not much reason to get windows ultimate over professional except a waste of money.
  3. majestic12
    majestic12
    Dec 26, 2009
    554 (0.27/day)
    158
    boondocks, Michigan
    That power supply is more than enough for your setup. How many hard drives are you planning on running? That's a pretty snazzy monitor. I'm impressed with its 50,000 to 1 contrast ratio... You might save a little bit if you switch your Windows 7 down to premium instead of ultimate. The main difference is that Ultimate adds a bit locker and native support for more languages.
    webJockey says thanks.
  4. assaulter_99
    assaulter_99
    Dec 7, 2009
    1,793 (0.86/day)
    277
    I'd even say "overkill".
  5. webJockey
    Jan 4, 2010
    66 (0.03/day)
    0
    I got WIN 7 Ultimate already.
    I have 1TB Segate SATA HDD. 7200 rpm I reckon
  6. webJockey
    Jan 4, 2010
    66 (0.03/day)
    0
    how much should be the right PSU in wats. I wanna save here then
  7. webJockey
    Jan 4, 2010
    66 (0.03/day)
    0
    How much should be the PSU in wats u reckon???
  8. kurosagi01
    kurosagi01
    Mar 21, 2009
    4,275 (1.81/day)
    472
    Northampton,UK
    a 550w corsair will do the trick or a 450w modular corsair.
  9. jjFarking
    jjFarking New Member
    Nov 30, 2009
    456 (0.22/day)
    92
    Brisbane, Australia
    I'd say the Corsair 550w should do fine.
    Just out of curiosity:
    - considering your needs, why the interest in OCing?
    - if you're going to do some HD editing, why do you insist on a resolution that isn't native to 1080p?
    Also, the response time for a LCD for your needs is far less important than to a gamer - you'd be better served getting a monitor that has the highest clarity & colour reproduction, with response time a secondary consideration. On that note, most monitors that purport to be 2ms, are really 5ms true, with the 2ms being grey-to-grey..
  10. assaulter_99
    assaulter_99
    Dec 7, 2009
    1,793 (0.86/day)
    277
    You could settle for a quality 450 but 550 would be the sweet spot, in case you might wanna game with a powerful card later.
  11. majestic12
    majestic12
    Dec 26, 2009
    554 (0.27/day)
    158
    boondocks, Michigan
    I agree the 450-550 are ideal but be sure to get a modular if possible -the Corsair HX450 or HX520 are really good and you can have a cleaner setup for better airflow when overclocking!
  12. webJockey
    Jan 4, 2010
    66 (0.03/day)
    0
    Great. thanks for that. But I wanna use it for watching HD movies n stuff too, n also TV. Can u please recommend a mid range LCD or LED.
    For OCing I thought that'll help editing faster. well that's what i have studied from posts. But as I said, i dont kno much abt hardware stuff. Please help selectin right monitor
  13. hat
    hat Enthusiast
    Nov 20, 2006
    17,302 (5.39/day)
    2,258
    Ohio
    If I were you, I woudn't stop at 3.5GHz. To to 3.8GHz—that appears to be the i7 920 sweet spot. 1.15-1.20v
    Crunching for Team TPU
  14. webJockey
    Jan 4, 2010
    66 (0.03/day)
    0
    550w would be enough even if I do OCing. has it got anything to do with that???
  15. webJockey
    Jan 4, 2010
    66 (0.03/day)
    0
    cool, i'll get that. actually one of my mates gonna do that for me. I have not had much idea about that. All i know is, i wanna keep it upto safe mode
  16. surfingerman
    surfingerman New Member
    Jan 1, 2010
    209 (0.10/day)
    59
    looks pretty good.. if your really concerned about money you could go 1156 socket MB w/ Intel Core i5-750.. over 920 and save a good chunk of cash cash... but maybe loose a little in upgradability and just a little speed.. depends on how budget you want it
  17. webJockey
    Jan 4, 2010
    66 (0.03/day)
    0
    I wanna stick to this cpu, I dont wanna go that far too save cash
  18. webJockey
    Jan 4, 2010
    66 (0.03/day)
    0
    accepeted that. we'll do that
  19. webJockey
    Jan 4, 2010
    66 (0.03/day)
    0
    will buy HX520
  20. majestic12
    majestic12
    Dec 26, 2009
    554 (0.27/day)
    158
    boondocks, Michigan
    Good choice for your build!
  21. smashed_99cbr New Member
    Jan 15, 2009
    323 (0.13/day)
    54
Share This Page
