need help choosing cpu cooler!
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
fish00
150 (0.03/day)
Processor AMD Phenom II x3 720
Motherboard GIGABYTE MA77OT-UD3P
Cooling Zerotherm
Memory 4 GIG DDR3 Gskill
Video Card(s) EVGA GTS 250 1GIG
Storage one 1TB and one 250 GIG
Display(s) Viewsonic Q20wb (20in WS)
Case CM Storm Scout
Audio Device(s) Creative X-Fi Xtremegamer
Power Supply OCZ 600watt stealth
Software XP pro 32bit
yeah one typhoon would be fine but id get the san ace personally. its a great fan. best built fan out there and they will never die
how loud is the san ace?
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
really quiet. a nice hum. stick it on a fan control though. its much nicer on a fan controller
fish00
150 (0.03/day)
Cooling Zerotherm
Case CM Storm Scout
i have no fan controller can u link me to a cheap one?
also i looked at ur created post and found a pic of the fan on ur heatsink, it looks really thick
would it clear all ram slots on this motherboard?
ASUS P7P55D LGA 1156 Intel P55 ATX Intel Motherboa...
i doubt i will use all 4 but in the future if i want 4 more gigs of ram or something
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
well just get ram with low heat spreaders not the high ridiculous ones
http://www.performance-pcs.com/cata...ge=product_info&cPath=36_48&products_id=27855
cheap fan controller
and the fan is 38mm thick its not the normal 25mm thick like normal case fans. this is because its meant for heatsinks and radiators. the thicker the fan the more of an angle there is with the fan making the air being pushed much more stronger hense the better static pressure
fish00
150 (0.03/day)
Cooling Zerotherm
Case CM Storm Scout
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
lol where do you wire that thing? does it just sit in the case?
and btw thank you so much you have been a massive amount of help haha
thats what im here for. and the wire gets plugged into the little black thing and then into the motherboard cpu fan slot then to the fan. and yeah it just sits at the bottom of the case.
fish00
150 (0.03/day)
Cooling Zerotherm
Case CM Storm Scout
hmm i dono if i like it just sitting at the bottom, looks a lil messy lol
i found this one tho
http://www.performance-pcs.com/cata...ge=product_info&cPath=36_48&products_id=25026
you can mount it at the front of ur case using a 3.5 drive bay, which my case doesnt exactly have a 3.5 but you can use a converter that came with the case to make it a 3.5
that would look much better in my eyes.
what level should i have the fan at with the fan controller tho?
like 3/4 on the dial?
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
its really not that bad. i have the same one and i just route the cable behind the motherboard tray and then back in at the top where it plugs into the fan. its quite nice
and that evercool one isnt very good it cant do full 12v output power.
fish00
150 (0.03/day)
Cooling Zerotherm
Case CM Storm Scout
hmm i didnt even think about the 12v thing lol
where do you have the lil fan controler thing in ur case exactly?
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
sitting at the bottom right next to the PSU. you can get double sided tape and tack it up on the 3.5 hard drive bay wall. thats what we did with my friend cm scout
fish00
150 (0.03/day)
Cooling Zerotherm
Case CM Storm Scout
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
hmm i still dont know about that haha i would like easy access to it
what about this one?
Scythe KQ01-BK-3.5 "KAZE Q" Fan Controller
that would also look rly nice with my case i think
i can understand that. and that fan controller is garbage. i had another scythe controller and it broke after like the first couple months. no bueno! Id really just stick it out and the the gelid one i showed you. you can even take out a pci e slot cover and hang it out the back of your case and take double sided tape to tack it to the back of your case or something.
fish00
150 (0.03/day)
Cooling Zerotherm
Case CM Storm Scout
yeah haha
how long have u had the fan controller?
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
fish00
150 (0.03/day)
Cooling Zerotherm
Case CM Storm Scout
3 years lol
i dono if this will make any sense to you but behind the removable front panel there is a hole that i could wire the fan crontroller to the bottom of the front pannel out to the side of my case and use double sided tape to mount it on the side. because their is a little indent at the bottom of the front pannel to grab it to full it off
if you want i can take pics and show u what im talkin about. i dono how good it would look tho. i could always try that
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
thats sounds fine dude.
fish00
150 (0.03/day)
Cooling Zerotherm
Case CM Storm Scout
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
fish00
150 (0.03/day)
Cooling Zerotherm
Case CM Storm Scout
nah your fine
Would you mind if i gave you a little tip on how to apply TIM to a cooler like the 212 since the heatpipes are shown at the base??
do i mind? that would be amazing haha :)
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
alright so you see those little grey strips in between each heatpipe?? well take a your tube of tim and put a thin nice line of TIM on each of them.(except for the 2 far outside ones). this allows the TIM to spread all the way across in a nice layer for best heat transfer to the heatsink
3,016 (0.55/day)
vermont
System Name The wifes worst enemy
Processor i5-9600k
Motherboard Asrock z390 phantom gaming 4
Cooling water
Memory 16gb G.skill ripjaw DDR4 2400 4X4GB 15-15-15-35-2T
Video Card(s) Asrock 5600xt phantom gaming 6gb 14gb/s
Storage crucial M500 120GB SSD, Pny 256GB SSD, seagate 750GB, seagate 2TB HDD, WD blue 1TB 2.5" HDD
Display(s) 27 inch samsung @ 1080p but capable of much more ;)
Case Corsair AIR 540 Cube Mid tower
Power Supply EVGA GQ1000W MODULAR
Mouse generic for now
Keyboard generic for now
Software gotta love steam, origin etc etc
Benchmark Scores http://hwbot.org/user/philbrown_23/
the 212 is basically a xigmatec or sunbeam cooler. its a decent mid range cooler. you'll get good temps up to like 4ghz on a 750. on my venomous x i would get 60max at 4ghz that cooler should get a bit more probably 70 max. personally i would use 2 fans in push pull config
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
what? sunbeam coolers are garbage. and the xigmatek dark night is really nice one. the hyper 212 is comparable to a TRUE
fish00
150 (0.03/day)
Cooling Zerotherm
Case CM Storm Scout
so just 3 thin strips of thermal grease?
MxPhenom 216
ASIC Engineer
12,945 (2.60/day)
Loveland, CO
