Need help choosing Themal Compound
Discussion in 'Overclocking & Cooling' started by HumanXJT, Feb 19, 2009.
  1. HumanXJT New Member
    Jan 22, 2009
    17 (0.01/day)
    12
    So I'm currently using Arctic Silver 5 and it's been used for at least a year and i believe it has dried out due to increased temperatures. I need help deciding which thermal paste i should use. I can't buy over the internet and so i'm stuck to my local store.
    Sadly they only have:
    1. Coolermaster Thermal Compound
    2. IceFusion
    3. Arctic Silver 5
    4. Noctua NT-H1 Pro-Grade
    5. Antec Silver Thermal Compound
    So which of these Thermal Compoud you guys think should be best?
  2. FlclAdam12
    FlclAdam12 New Member
    Jan 2, 2009
    99 (0.04/day)
    2
    New York
    I use arctic silver 5, works fine for me. I hear it is really good.
    HumanXJT says thanks.
  3. Kursah
    Kursah
    Oct 15, 2006
    8,182 (2.65/day)
    1,938
    Missoula, MT, USA
    I use AC MX-2 anymore, easy to use, doesn't need to set for best results, I've used for fairly long periods w/o it drying up, you get more for the money, and it seems to rate pretty well. Though really my opinion of the best TIM anymore is, as long as I have something to put between the heatsink and the processor I'm fine, a couple degrees are so really doesn't matter if you have even somewhat decent cooling and airflow.
    I still have a tube of AS5 floating around, have yet to use it since I got my tube of MX-2, which is also nonconductive, so that's definately a plus!
    :toast:
  4. HumanXJT New Member
    Jan 22, 2009
    17 (0.01/day)
    12
    I've been reading comments of AC MX-2 with great results, but unfortunately I'm only able to choose between the five in the first post.
  5. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.69/day)
    639
    Wangas, New Zealand
    AS-5.
    Just don't use it on GPUs if you are clumsy.
  6. nafets New Member
    Jul 26, 2008
    611 (0.25/day)
    133
    You really need to use Google some more.
    Here is a review, at our very own Techpowerup, of the Noctua NT-H1 TIM.
    It looks to be a great replacement for AS5, if it's reasonably priced. Otherwise, just stick to AS5.
  7. HumanXJT New Member
    Jan 22, 2009
    17 (0.01/day)
    12
  8. ShadowFold
    ShadowFold New Member
    Dec 23, 2007
    16,921 (6.38/day)
    1,644
    Omaha, NE
    AS5 is outdated and has many downsides compared to newer compounds. You have to reapply AS5, you need to let it break in, it dries up easy, it's conductive, need I go on?
  9. Ether New Member
    Feb 13, 2009
    29 (0.01/day)
    0
    Thermal
    I bought some 18ct diamond compund which boasts way better heat transfer than any other...go check it:toast:
  10. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (2.87/day)
    862
    Dorset, UK
    +1 on AC-MX2, from my personal experience, it performs better than AS5, has no curing time, and does not need reapplying
  11. Thrackan
    Thrackan
    Oct 10, 2008
    3,482 (1.47/day)
    656
    Of your list, I'd try the Noctua compound. You need to be prepared that it's a lot more viscose if I remember correctly, so make sure to spread it before you apply the heatsink.
  12. johnnyfiive
    johnnyfiive
    Apr 17, 2008
    3,892 (1.53/day)
    876
    Tucson, AZ
    Noctua FTW, IMO. :D
  13. h3llb3nd4
    h3llb3nd4 New Member
    Feb 15, 2009
    3,323 (1.49/day)
    307
    Durban, South Africa
    Choose AC-MX2
  14. MoonPig
    MoonPig
    Aug 7, 2008
    5,730 (2.36/day)
    886
    Wakefield, UK
    ^^ Seconded. I'm using it, and i prefere it over AC5. You get alot more for less money too... :-/
Share This Page
