Need HELP converting MKV for Xbox 360
Discussion in 'General Software' started by NdMk2o1o, Apr 27, 2011.
  1. NdMk2o1o
    NdMk2o1o
    Apr 21, 2010
    3,449 (1.85/day)
    922
    Redditch, Worcestershire, England
    Well for the last hour and a half I have been tirelessly trying to get an MKV file playing through my 360 MCE with no joy, the 1st thing I tried was downloading the DIVX codecs, this allowed me to view it in media player though not on my xbox, then I tried repackaging it into an MP4 container and it won't open with any media players. Have also tried converting it to AVI though I really CBA waiting 2+ hours (it's a 6gb video file)
    I really would like some suggestions on how to easily convert or watch MKV files on my 360
  2. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.62/day)
    1,383
    Virtual dub?
  3. NdMk2o1o
    NdMk2o1o
    Apr 21, 2010
    3,449 (1.85/day)
    922
    Says its an unknown video type, the file plays fine in VLC and media player with the right codecs installed
  4. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.62/day)
    1,383
    Avidemux it is then.
    NdMk2o1o says thanks.
  5. NdMk2o1o
    NdMk2o1o
    Apr 21, 2010
    3,449 (1.85/day)
    922
    Have somehow got it working without having to convert/extract the video. Took me the best part of 3 hours and multiple converting programs, xbox media servers and codec pack installs to get it to work. No9w there is no need to convert it is playing it natively, I assume it's because of the filters and codecs I have installed as none of the media servers are running.
    List of codecs installed:
    AC3 Filter
    CoreAAC
    Divx Codec Pack
    FFD Show
    Haali Media Spliter
    Shark007 Win7codecs
    Xvid
    Trouble is, I am not keen on having a ton of codecs installed on my rig as they have give me headaches in the past, though not sure what is actually allowing me to play it through the xbox :confused:
  6. Cybrnook
    Cybrnook
    Sep 20, 2009
    716 (0.35/day)
    144
    C:\Kitteh
    Use a program called "Handbrake" to re-encode your video to MP4. Use the "Normal" profile and you should be fine.
    That's what I use with my 360 and it works great every time.
    link: http://handbrake.fr/downloads.php
  7. digibucc
    digibucc
    May 21, 2009
    4,965 (2.26/day)
    1,516
    is it necessary to re-encode? you are trying to stream, correct?
    ps3 media server works with xbox as well, and will transcode some media for it. it doesn't work perfect but i played mkvs with it before, all the way through with no issues.
  8. slyfox2151
    slyfox2151
    Jan 14, 2009
    2,620 (1.13/day)
    526
    Brisbane, Australia
    This+1,
    PS3 Media Server will transcode ON THE FLY most video files into a format compatible with the 360.
    simply browse to the file you would like to play, then select the transcode folder using the Xbox. the PC will then transcode on the fly for your xbox.
    there is no need wait hours for a coverting software. it will play the movie straight away. it use's about 1 core @ 2.5-3ghz....
    digibucc says thanks.
  9. Mike0409
    Mike0409
    Jan 12, 2009
    1,142 (0.49/day)
    126
    Connecticut
    Not sure if Xbox supports VOB files, but you can do a quick container change from MKV to VOB using MVK2VOB (I think thats the name) usually takes about 30-1 hr depending. And you can break up the file size for Fat32 format.
Share This Page
