nocomplaints
- Feb 26, 2006
- 2 (0.00/day)
Hi all,
Need some help with my laptop please!! Have a Gateway 8550GB (original Specs 1.73 Pentium M, 1GB Ram, X700 mobility) which is now Pentium 2.26, 2GB and X1900. Initial results with Overclocking 2.5Ghz on the Cpu and 450 on the Gpu gave a 3410 on 3DMark 06 which was good but the problem is that the CPU temperature sensor only reads correctly at idle or for short periods of time under high load but then reads to 35oC and stays there until the CPU is unloaded again meaning the fan doesn't spool up cooling it correctly. If I set NHC to run the CPU flat out on the clock speed the temp reads fine until actually loaded up i.e run Prime 95 or a Game etc. It doesn't appear to be a sensor fault since if I block the fan off the Cpu temp reads fine unless loaded up then once under full load it read 35oC again even without any overclocking. Once unloaded the temperature reads correct again after a few seconds. The Main board is Intel 915 PM Pheonix Bios 59.04 (Think Gateway use there own modified version of Pheonix Bios). Any ideas gratefully recieved?
Thanks
Gaz
Thanks
Gaz
