Need Help for my Q6600 Cooling solution
Discussion in 'System Builder's Advice' started by sneddenraj, Apr 14, 2010.
  1. sneddenraj
    sneddenraj
    Apr 14, 2010
    53 (0.02/day)
    9
    On Earth...
    Hello guys need help regarding cooling for my Quad Core Rig.
    [​IMG]
    [​IMG]
    This are my normal temperature ratings without overclocking and i am using stock cooler which sucks really.
    As i live in India weather is pretty bad and damn hot out side with temperature reaching 40 degrees and my system runs 24x7 along with Folding@Home and World Community Grid so i am desperately looking for a good cooling system.
    My bro lives in US so i can get an aftermarket cooler which is best.
    So please guys suggest me the best Cooler for my Q6600 on an Intel MoBo DG33FB.
    Crunching for Team TPU
  2. Delta6326
    Delta6326
    May 21, 2008
    3,984 (1.41/day)
    724
    Iowa, USA
  3. JATownes
    JATownes
    Nov 9, 2008
    1,875 (0.71/day)
    491
    Texas
    I am using a Scythe Mugen 2 on a Phenom II 940, so I can't relate to the Q6600, but IMO the Mugen 2 is a beast of a cooler for fairly cheap.
  4. afw
    afw
    Mar 4, 2009
    643 (0.25/day)
    129
    As JATowens mentioned a scythe mugen 2 would be nice... decent price and great cooling ... else a noctua nh-d14 / prolimatech megahalems / venomousX ... expensive but awesome cooling .... :)
  5. Fourstaff
    Fourstaff Moderator Staff Member
    Nov 29, 2009
    9,304 (4.10/day)
    2,051
    Home
    +1 on Xigmatek Dark Knight, its awesome (at least the one Fits reviewed)
  6. sneddenraj
    sneddenraj
    Apr 14, 2010
    53 (0.02/day)
    9
    On Earth...
    how abt
    ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler
    is it better or
    XIGMATEK HDT-RS1283 120mm CPU Cooler/Scythe MUGEN-2 SCMG-2000 120mm
    is better.
    m totally confused now...
  7. n-ster
    Jan 11, 2009
    8,979 (3.47/day)
    1,445
    both the S1283 and the scythe mugen 2 are awesome... Haven't heard anything good on that Zalman though
  8. Kreij
    Kreij Senior Monkey Moderator Staff Member
    Feb 6, 2007
    13,881 (4.21/day)
    5,632
    Cheeseland (Wisconsin, USA)
    The Zerotherm Nirvana (in sig) that I have, used to cool my QX6700 just fine.
    Works great on my QX9650 too.
  9. a_ump
    a_ump
    Nov 21, 2007
    3,675 (1.22/day)
    398
    Smithfield, WV
    i second(3rd?) to get a xigmatek s1283. not sure bout dark knight as i have the regular version, but it works great for me. I used to use an AC Freezer Pro 7. At 3ghz my q6600 was like 58 load, 38idle. Now with the xig s1283 i run 3.4ghz with 33/34 idle 54 load. lot better
  10. sneddenraj
    sneddenraj
    Apr 14, 2010
    53 (0.02/day)
    9
    On Earth...
    thanks a lot guys
    :toast:
    i have finalized and i m goin wid
    and probably using it with Artic Silver 5 Compound.
    Should i go with some other compound or stick with Artic Silver 5
  11. n-ster
    Jan 11, 2009
    8,979 (3.47/day)
    1,445
    I like MX-2 and MX-3 and OCZ freeze and Shin-Etsu pastes alot... Try the MX-3, you'll like it!
  12. a_ump
    a_ump
    Nov 21, 2007
    3,675 (1.22/day)
    398
    Smithfield, WV
    I use AS5 for the last 2 applications and after a yr or so it seems to wear out and temps climb for me. I'm going MX-2 here soon n i'd recommend you do the same.
  13. JATownes
    JATownes
    Nov 9, 2008
    1,875 (0.71/day)
    491
    Texas
    +1 to MX-3
  14. Kreij
    Feb 6, 2007
    13,881 (4.21/day)
    5,632
    I use AS Ceramique because it's non-conductive and I'm not the neatest CPU paster. :D
    Let us know what your temps are like when you get the new cooler installed !!
    Edit : I see that the MX-3 is also non-condctive. I'll have to try that next time.
  15. sneddenraj
    sneddenraj
    Apr 14, 2010
    53 (0.02/day)
    9
    On Earth...
    Finalized
    along with
    ARCTIC COOLING MX-2 as MX-3 is not available on Newegg
    thanks a lot to all of you guys...
    will surely post my new Temperature Rates but for that probably i will have to wait till next month to get my hands on that
  16. n-ster
    Jan 11, 2009
    8,979 (3.47/day)
    1,445
    Good luck! I'm sure you will love it
  17. Delta6326
    Delta6326
    May 21, 2008
    3,984 (1.41/day)
    724
    Iowa, USA
    good luck and i also say mx-2 mx-3 love it
  18. sneddenraj
    sneddenraj
    Apr 14, 2010
    53 (0.02/day)
    9
    On Earth...
    Hey guys der is a problem...
    i vl b doin future upgrades to my pc as in may be with LGA 1156 socket or else AM3 socket
    so if i buy XIGMATEK HDT-RS1283 120mm CPU Cooler den it only supports LGA 775 socket
    so can u suggest me a cooler which can be future proof as well as dis vl b sort of one time purchase for me...
    thanks in advance
  19. n-ster
    Jan 11, 2009
    8,979 (3.47/day)
    1,445
    The Hyper 212+ is cheap and is compatible with many sockets... Else the Scythe Mugen 2 Rev.B?
  20. a_ump
    a_ump
    Nov 21, 2007
    3,675 (1.22/day)
    398
    Smithfield, WV
    sweet, picked exactly my suggestion :D woot. and no the xig supports AM2/2+/3 sockets i'm pretty sure
    EDIT: nvm it doesn't. however it does support all current intel sockets with this Xigmatek bracket retention kit.
