Need help in setting up sound
Discussion in 'Audio, Video & Home Theater' started by Yin, Sep 5, 2011.
  1. Yin
    Yin
    Feb 19, 2006
    542 (0.16/day)
    32
    Hi Guys,
    I'm having a weird issue with my sound configuration my current setup is a X-FI soundcard which came with my motherboard (Asus Rampage II) paired with Logitech Z-5500 Speakers.
    I decided to purchase myself an optical cable thinking I'll get better sound quality but I'm running into all sort of weird issues while using it.
    1. For sound to come out I have to set the "SPDIF Interface" as my default Playback device in Windows 7 otherwise I don't hear anything. I see a "Digital Output" shouldn't it be set to this?
    2. When I attempt to do a surround speaker test I don't hear any noise coming from my speakers but I do see sound outputting on my "Speakers" device in my control panel>sound.
    3.Not exactly related but my creative volume panel from the system tray has disappeared and I would like it back any idea on how to do this?
    I am running windows 7 64-bit
  2. Yin
    Yin
    Feb 19, 2006
    542 (0.16/day)
    32
    Okay I've found the reason why it isn't working as I thought it was.
    The Asus Supreme X-fi Sound card doesn't really have a optical digital output its only SPDIF and SPDIF thought an optical cable which is very disappointing.
  3. caleb
    Sep 15, 2004
    1,554 (0.41/day)
    206
    Poland,Slask
    huh? SPDIF =digital
  4. caleb
    Sep 15, 2004
    1,554 (0.41/day)
    206
    Poland,Slask
  5. Jetster
    Jetster
    Jan 17, 2010
    5,624 (3.01/day)
    2,414
    Oregon
  6. caleb
    Sep 15, 2004
    1,554 (0.41/day)
    206
    Poland,Slask
    Thats why speakers have Dolby Digital / DTS decoder. So it should work both coax/optical.
    What else would he want?
  7. Yin
    Yin
    Feb 19, 2006
    542 (0.16/day)
    32
    Sorry if I haven't made myself clear, As I'm getting confused myself.
    @caleb the little switch on the back is set to 6 Ch
    @jetster so with an optical cable I don't get surround sound? that doesn't make sense to me.
    edit: Also jetster I have been reading that thread but It doesn't solve my problem.
  8. caleb
    Sep 15, 2004
    1,554 (0.41/day)
    206
    Poland,Slask
    Check the manual if this somehow doesn't switch speaker decoder totally to analog mode (or just try it out with off).
    Your card needs to be setup to output DolbyDigital/DTS through that COAX/Optical.
  9. Yin
    Yin
    Feb 19, 2006
    542 (0.16/day)
    32
    I don't think the issue is with the speakers, I think it's a software issue?
    It sends the surround sound through the analogue cables
  10. caleb
    Sep 15, 2004
    1,554 (0.41/day)
    206
    Poland,Slask
  11. streetfighter 2
    streetfighter 2 New Member
    Jul 26, 2010
    1,658 (0.99/day)
    732
    Philly
    SPDIF is digital.
    By using optical/coax/SPDIF you are relying on the fact that your Z-5500 has an internal decoder (which it probably does). Once it's connected you should close down any movies/music you're listening to, as they may interfere with the output, and run the Windows/Creative sound configuration utility.
    Your output is only as good as your source so if you want 5.1 out of a stereo signal you'll need something like AC3Filter. Additionally if you are playing a blu-ray it will downmix from HD because SPDIF does not support HD audio formats.
    Yin and BumbleBee say thanks.
  12. BumbleBee
    BumbleBee
    Mar 6, 2009
    5,062 (2.32/day)
    1,451
    Cybertron aka Canada
    ever seen the Buckley's cough syrup commercials?
    [​IMG]
    that's how I feel about stereo upmix :laugh:
  13. Yin
    Yin
    Feb 19, 2006
    542 (0.16/day)
    32
    Here is a picture of my sound
    [​IMG]
    1. What is making me scratch my head is why do I have a digital output from my sound card what is that for?
    2. Why is when I right click on the SPDIF output I don't see the configure speaker options?
    3. When I attempt to test the surround sound in Creative Sound settings the program seems to output it on the speaker output regardless that I have the SPDIF Interface set as the default playback device?
    Edit: Okay I fixed my volume panel problem
Share This Page
